vizio vp50
  • heavymachines
    • Mar 2011
    • 1028
    Re: vizio vp50
    Originally posted by heavymachines
    how did i know you were gonna say that LOL? yes it was 200k ohm range
    say if its a 100k pot shouldn't it range from 0.00 to 100k?
    could another device suppressing the pot in circuit?
      Re: vizio vp50
      If there's excessive parallel load, or if the pot is damaged, you could see those readings.
      • heavymachines
        • Mar 2011
        • 1028
        Re: vizio vp50
        i tested the VS pot and it does not go infinite and this is a good working circuit...
        VA pot climbs to infinite very slowly it a clue i think.......
          Re: vizio vp50
          Definitely a place to consider. I'd order a compatible replacement & see if it goes.
          • heavymachines
            • Mar 2011
            • 1028
            Re: vizio vp50
            tryng to test pots in breadboard can't get readings on either one...?
            but safe to assume i am doing it wrong...
            • heavymachines
              • Mar 2011
              • 1028
              Re: vizio vp50
              okay got it figured...both pots adjust and no infinite reading in breadboard works perfect far as i can tell so double confirmed ...guess i will have to wait till tomorrow to do power test on tl431...
              • heavymachines
                • Mar 2011
                • 1028
                Re: vizio vp50
                UPDATE::::
                ok still low VA still at 14 volts and has different TL431 and measurement at,
                TL431 pin 1 and 3 is 26.6 volts at location U531 on pcb
                  Re: vizio vp50
                  There might be a problem around the feedback area of the TL431 and potentiometer.
                  But I don't know...
                  • heavymachines
                    • Mar 2011
                    • 1028
                    Re: vizio vp50
                    Bummer ....that don't sound very confident...umm there is got to be a silly reason why there is low va..... you say feedback area... do you happen to have schematic's on this beast? i have had no luck just owner's manual just about useless...not ready to give up on it yet...power boards too expensive...
                    does the TL431 sound high on voltage? er close to the limit of it's capacity..
                      Re: vizio vp50
                      No schematics as far as I am aware. The part # is LJ44-00132A right?
                      The feedback is the signal sent back to the SMPS controller to regulate the output. For some reason it's coming out low or the controller is interpreting it as low. Normally I'd have a board in front of me to diagnose, pretty hard to do it over the 'net.
                      • heavymachines
                        • Mar 2011
                        • 1028
                        Re: vizio vp50
                        close.. it's LJ44-00132B
                        (Samsung PSPF561A01A)
                        the set full model number is VP50-HDTV20A
                        well now that i figured out macros on that camera i can get better pictures for you if you need...Thanks for sticking it out with me i understand your frustration not having it in front of you...i will do what i can to ease that pain...take better pic's and try by best to fallow instructions... and do some research on my end which i have been doing ....
                        0
                          Re: vizio vp50
                          I'm going to go out on a limb and suggest swapping the Vs and Va pots; see if the problem then moves to Vs. The circuits for both will be similar; the only real difference is one is 200V and the other is 60V, so try and see if there are any obvious differences between the parts: burn marks etc.
                          • heavymachines
                            • Mar 2011
                            • 1028
                            Re: vizio vp50
                            just so you know i had both pots out and put in breadboard and both read 0.00 one way and approx 25 ohm other way both were within 1 ohm of each other...but still will do pot swap if you insist...
                            • Baileybum1234
                              • Sep 2012
                              • 245
                              Re: vizio vp50
                              Sometimes you can find another tv with a simular board.
                              0
                              Repaired: LG50PQ6000
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #135
                                Re: vizio vp50
                                this thread says a Sanyo DP50747 (Chassis P50747-00) uses the same power board does the sanyo manual have a psu diagram in?
                                https://www.badcaps.net/forum/showthread.php?t=11682
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Re: vizio vp50
                                  This is weird I just posted this thread:
                                  https://www.badcaps.net/forum/showthread.php?t=25766
                                  • heavymachines
                                    • Mar 2011
                                    • 1028
                                    Re: vizio vp50
                                    Originally posted by Baileybum1234
                                    yeah sometimes you can but sometimes it hard to find what all share same parts, shop jimmy gives clues sometimes but not always...
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      Re: vizio vp50
                                      and led does not blink at all on ps, i suppose i could take that jumper off... i will tinker with it more on next sunrise..and re read voltages etc...i have a feeling there may be more wrong with the set...but will git-r-done.
                                      • heavymachines
                                        • Mar 2011
                                        • 1028
                                        Re: vizio vp50
                                        And thanks for the suggestions gives me lil more leads one of the post i already seen...but as they say anything is better then nothing..
                                        • heavymachines
                                          • Mar 2011
                                          • 1028
                                          Re: vizio vp50
                                          Man i am such an idiot...
                                          va is fine mistaken it for vg duhh,,,, yes tom do yell i deserve it...
                                          anyways latest update i removed upper buffer and now the set turns on only bottom half screen lights up can't see the menu to switch input to hdmi , put the buffer back in and no dice and those pair of resisters tom we looked at earlier started smoking!!!!!
                                          turned the set off i remeasured those resistors and it still shows 5.5 to 5.6 ohms those are some tough resistors...and removed upper once again and bottom half of screen lights up still... so
                                          most likely dumb question but if i buy a upper buffer is there anything in the y-sustin that could take out the replacement upper buffer? should i check the y-sustin for issues?
                                          my guess would be if it lights up y-sustin is ok most likely but i could be thinking like an idiot again ....???
                                          • u666sa
                                            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                            by u666sa
                                            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                            Platform: ipa32 la-m024p rev 1b
                                            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                            I found a short on the other side:
                                            10-04-2025, 05:03 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • supermattch
                                            HP 15dy-2021nr wont power on mystery volts
                                            by supermattch
                                            Hi everyone.
                                            I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                            09-23-2025, 12:13 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
