LG 42LG3000 (White Screen with Sound)
  • gbyrne2011
    • 3
    • Ireland
    Hi all, first time posting here hopefully you can help..
    I have a 42" LG TV around 3 - 4 years now and is now randomly turning on to black and slowly fading up to white with sound still working, no tv options show up when you press any buttons.
    It's an odd one as I could go down now and turn it on and it'll work all day and then turn off and back on and then black to white and again off and on and works.. been like this a few days now.
    Attaching video of what happens (http://www.youtube.com/watch?v=_HU8hsfUKNY)
    Any help you can provide will be much appreciated..
    Regards
    Garret
    Last edited by gbyrne2011; 01-17-2013, 01:01 PM. Reason: Turn on option for notification
    Re: LG 42LG3000 (White Screen with Sound)
    I would take a look at the "LVDS cable". This runs internally from the main board (with the video inputs on it) to the T-con board, which is at the top of the LCD panel on most models. I have seen this when LVDS is loose. If it's not that, I'd consider the T-con itself.
    • gbyrne2011
      • 3
      • Ireland
      Hi Tom, thank you for your quick responds..
      I have a picture here not taken myself it's from another user on the board.
      Is the cable your talking about from the main board to the t-con board, is that the board that is connected to the screen itself??
      • selldoor
        Slow Learner
        • 7870
        Its the red one
        • gbyrne2011
          • 3
          • Ireland
          Cheers.
          Thanks to both of you, I will look into this now and take out the wire and reseat and if it's still the same I'll look into replacing the t-con.
          • Techstar
            Tv Restoration
            • Dec 2012
            • 122
            • United Kingdom.
            I had one similar fault on lcd where it was the flat panel it self due to faulty tab bonding. Faulty supply to the t- con or t con board faulty.
            • cosmindaniel
              • Oct 2013
              • 9
              • Romania
              For me doesn't work, cable is fine, do you have any ideea??
              Thks
              • cosmindaniel
                • Oct 2013
                • 9
                • Romania
                So, yesterday i was to LG service. I have a 42LG3000 television, with this simptoms white screen but good sound. Actually i try to change T-con Module, i bought a new one, i replace all condensators, finally from service sad me this: YOUR DISPLAY IS DEAD, ACTUALLY , the matrix from this is broken, its necessary to buy a new one, but may be you need to buy a new tv.
                So if you this problem, don't try to change some parts from inside, because 99% the display is broken............
                Good Luck.
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • EazyBone
                  Sharp LC-65Q620U White Screen
                  by EazyBone
                  Another TV topic!!
                  I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                  The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                  Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                  08-21-2024, 12:56 PM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • hcinne
                  Dell G15 ryzen edition black screen 2 amber 1 white
                  by hcinne
                  I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                  07-23-2024, 07:56 AM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
