Possible Polaroid TLX-04244B Purchase....
  • Paul678
    • Nov 2011
    • 402
    The lady told me:
    "My husband turned it on one day and then i think the electric socket shorted. The blue light turns on when you turn the tv on but the screen is just black, that same week our PS3 died that was plugged into the same outlet."
    She also claimed that the sound was still there, and that she has the original
    remote and the power cord.
    We agreed to $10.
    I'm thinking that the +24V going to the inverter has died out, or perhaps
    a fuse on the inverter has opened.
    What do you guys think?
  • bigdozer
    • Jan 2011
    • 46
    Re: Possible Polaroid TLX-04244B Purchase....
    Give her 5 bucks for the Ps3.
      $10 ain't bad. I struggle to get TVs for 4x that.
      • Paul678
        • Nov 2011
        • 402
        How about FREE? Haha! She just gave it to me
        to pick up!
        Spent about $2 in gas so far.......
        But there doesn't seem to be any sound, just the blinking
        blue LED, and no picture at all (even when I hold a bright
        flashlight to the screen, I cannot see anything).
        So my problem is a bit different than the other threads
        on this same model.
        Thanks for any advice.....I'm gonna check voltages.
        • Paul678
          • Nov 2011
          • 402
          Ok, the +24V is there, as is the +12V and +5V.
          The "STB" was +3.8V, which is a bit over 3.3, but
          might be ok.
          "APWM" going to the main board was +4.5V, and the
          "BK_ON" was zero volts.
          So it looks like the power supply may be good, although
          I didn't check the high voltage inverter output, which
          is integrated on the power supply, but I have a feeling
          it's the main board that is bad.
          Anyone have any experience with this model?
            I'll suggest jumping BL ON to 5V via a resistor to see if it kicks the backlights on, this lets you rule out the power supply.
            • Paul678
              • Nov 2011
              • 402
              Yes, good idea.
              I used a 1k resistor, and the backlights turn on, so definitely
              the power supply/inverter is good. I tried using the jumper
              with the main still hooked up, but the main was pulling the
              BK_ON side short to ground, so I had to disconnect the main
              board first.
              I tried to do the fluorescent lamp trick of holding one conductor
              to the inverter output, to see if the lamp lights, but when i
              disconnected the real CCLFs, a red LED on the PS started
              blinking, and there didn't appear to be a high voltage on the
              output.
              Ok, according to this site:
              http://www.justanswer.com/tv-repair/...lue-light.html
              ....I have a bad main board. Unfortunately, it's a gamble, because someone else replaced the main board, and while the picture came up, it was
              distorted badly:
              http://www.tomshardware.com/forum/54...olaroid-04244b
              Since I got this set for free, I suppose I could gamble on the main
              board on Ebay......
                That only happens if the panel setting is set incorrectly.
                Make sure the main board panel setting matches what is installed. A good seller will list what panel board was pulled from.
                Even better, sometimes it will let you change the setting.
                • Paul678
                  • Nov 2011
                  • 402
                  Ok, I don't see any DIP switches on the main board, and I
                  don't know where to look for the panel setting.
                  Here are some pics:
                  http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
                  The is a marker, "DIP SMD" silkscreened on the board....dunno it that
                  is what you're talking about.
                    Panel setting is almost always in EEPROM, on main board.
                    There is the possibility of transplanting EEPROMs. Do ya feel lucky punk? Well, do ya?
                    • Paul678
                      • Nov 2011
                      • 402
                      Shit, well should I cancel my ebay order then?
                      It doesn't sound like a good gamble to me.....
                      • gilly1984
                        • Jun 2012
                        • 751
                        Similar to what my bush was doing, except, blue light means its in standby, no light meant it was on, but had no lights or sound.
                        Had an ipos psu in it too.
                        https://www.badcaps.net/forum/showth...highlight=bush
                        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
                        • Paul678
                          • Nov 2011
                          • 402
                          Fuck yeah!!! The main board was bad!!!
                          Watching this killer picture!! The biggest set i've
                          fixed yet!!! 42"!! Huge!!!
                          • martyparish
                            • Dec 2012
                            • 313
                            That's a sweet deal Paul! I also got very lucky with a 55" proscan lcd for $40. Turned out to be a few bad caps
                            • Paul678
                              • Nov 2011
                              • 402
                              You just HAD to rain on my parade, and brag about how
                              much bigger your TV is!!
                              I spent $40 on the main board on Ebay, so about the same
                              as you.
                              kick ass!! i love this hobby/job!
                              time to make some $$$$$$$$$!!!!!!!! hHAHAHAHAAA!!!
                              • martyparish
                                • Dec 2012
                                • 313
                                Haha, no any (almost) free flat screen is a good one! I'm constantly on the prowl for TVs now lol. I won't be selling any until all of my kids and other close family members have nice TVs
                                  My dad now has a 50" NEC plasma because of me, and he loves it. It looks frigging awesome. So I'm on the hunt for a 42" or 50" Panny plasma (I'd settle for NEC though!) for student dorms...
                                  • martyparish
                                    • Dec 2012
                                    • 313
                                    I love my panny plasma(50"). Had to pay retail for that one though! ($1000 three years ago)
                                      But it'll probably last another 10 years or 20 years no problem... Their newer sets are quite unreliable though , older ones built like tanks.
                                      • eccerr0r
                                        inverter H tree driver imbalance in an AC inverter
                                        by eccerr0r
                                        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                        Today, 12:34 PM
                                      • x_orange90_x
                                        Vizio E55-E1 bad backlights or bad inverter?
                                        by x_orange90_x
                                        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                        I don't know how exactly to test the inverter itself. Is it...
                                        01-29-2025, 09:24 PM
                                      • Gentian
                                        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                        by Gentian
                                        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                        03-06-2023, 07:07 AM
                                      • valvashon
                                        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                        by valvashon
                                        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                        01-04-2024, 01:44 PM
                                      • eccerr0r
                                        A modified sine wave inverter + a grid tie inverter?
                                        by eccerr0r
                                        If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                        Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                        08-31-2023, 09:14 PM
