Sylvania lc320ss2 LCD TV keeps blowing fuse
  • kevinm34232
    • May 2012
    • 1884
    Re: Sylvania lc320ss2 LCD TV keeps blowing fuse
    Yes
      25V will be fine... it is just preventing mosfet gate exceeding 30V on transient and start up.
      • Beowulf
        • Dec 2012
        • 175
        Sorry I've been a little away, little sick.
        If you still need help I can provide more info of what I did, if it's not already here.
        I dont have the TV with me anymore.
        Also keep in mind that in my case I may have had more defective components than I should since somebody went and installed a higher rated fuse that I assume may have contributed to mess up some extra components.
        Regards,
        • kevinm34232
          • May 2012
          • 1884
          Yes I can still use some help. I replaced 2 shorted diodes D604 and D607, open R608,shorted Q600 and Q601, and plugged it in using a light bulb.
          Bulb lit up for a second then went out. I had 120vac and 160vdc at main cap.
          So I decided to replace fuse and see what happens. Plugged in and TV still dead, but fuse did not blow. After a little bit a saw a puff of smoke coming from area where I replaced the parts.. I unplugged it, and the heat sink for Q600 was VERY hot.. I think most of the components I replaced shorted out again, the 2 cement resistors are showing open now and were find before.
          • kevinm34232
            • May 2012
            • 1884
            There are 3 SMD capacitors on the bottom of the board close to other shorted components, 2 show low resistance in circuit around 20 ohms, the other is around 250 ohms.
            • kevinm34232
              • May 2012
              • 1884
              Well looks like Q600 Q601 D607 R602 R611 went bad this 2nd round time. 2 resistors R605 and R606 also read too low and out of spec. Read thru entire thread again and saw you had shorted D640 on secondary side bottom of board, mine was also shorted. So maybe this was what I missed before, will order the parts and try again.
              I'd appreciate any other info you can share about what you replaced though, I did not replace photocoupler IC601 it seems to be OK. I pretty much tested everything else I could find..
              • kevinm34232
                • May 2012
                • 1884
                As Im waiting on more parts for this one to arrive, I just have a question regarding the 4 SMD capacitors on the bottom of the board (these are the only components on the on the bottom of the hot section of the board except for 3 SMD 220k ohm resistors that test good. 3 are in close proximity to the shorted components C605 C606 and C608. The only way I know to test these is with my ESR meter in circuit and it shows open circuit/low capacitance not sure if that's correct way to do it tho, don't really wanna remove them and I heard they dont go bad too often..
                Is it possible if one of these was bad to cause a major short the would short out the transistors and diodes?
                • Beowulf
                  • Dec 2012
                  • 175
                  I didn't have any defective surface-mount component other than the diode D640. I dont believe those smd caps are part of your problem.
                  Regards,
                  • kevinm34232
                    • May 2012
                    • 1884
                    Finally got the parts and this TV is back to life. Here is the complete list of what I replaced:
                    Q600 - FET MOS TK10A50D - Mouser
                    Q601 - TRANSISTOR 2SC2120-Y(TE2 F T) - Ebay
                    D604 - DIODE ZENER 27BSB-T26 - Part # 568-5893-1-ND
                    D607 - SWITCHING DIODE 1SS133(T-77) - Part # 1SS133T-77CT-ND
                    D640 - DIODE SCHOTTKY SMD SK2B-TR - Part # SS210-TP
                    R602 - CEMENT RESISTOR 5W J 2.2 OHM H 10MM - Part # 280-CR5-2.2-RC
                    R605 - RES CARBON FILM T 1/4W J 220 OHM - Part # 291-220-RC
                    R606 - RES CARBON FILM T 1/4W J 180 OHM - Part # 291-180-RC
                    R608 - METAL OXIDE FILM RES. 2W J 0.18 OHM - Part # PNP300JR-73-0R18
                    R611 - CEMENT RESISTOR 5W J 2.2 OHM H 10MM - Part # 280-CR5-2.2-RC
                    • microvibe
                      • Mar 2013
                      • 275
                      • canada
                      #110
                      i have same tv with power supply issue, i have replaced the shortedcomponents, i need q600 - tk10a50d. i have a bunch fet here can i substitue a tk10a60d instead of the tk10a50d. or what others would work
                        There should be no problem with that substitution, the breakdown voltage is higher on the second part.
                        • microvibe
                          • Mar 2013
                          • 275
                          • canada
                          #112
                          i replaced d640 that was shorted and also q600, pluged it all in andnothing, at least its not blowing fuses anymore but i get no clicking when power plugged in and no lights ethier. there is nopower at q600 fet any suggestions where to start
                          • kevinm34232
                            • May 2012
                            • 1884
                            Did you check the list of parts in post #109, likely you have more bad components in the area..
                            • microvibe
                              • Mar 2013
                              • 275
                              • canada
                              #114
                              i checked that list best i can , not very experienced testing the electronics but i can replace them. i had this board in for testing all they told me was q600 and d640, so i started testing the list on 200 ohm setting and i get no readings on the cement resistors, the other resistors check out, i dont have diode test function so i cant test the zener or switching diodes. i am not sure how to test the transistor as well.
                              are there other substitutions one can use for the cement resistors, i have tons of broken circuit boards i would like to salvage what i can. nothing i have has cement resistors that size and shape.
                              thanks
                              • kevinm34232
                                • May 2012
                                • 1884
                                Most of those components will show short between pins if bad. The cement resistors are 2.2ohm resistors if you get no reading they are bad:
                                http://www.mouser.com/ProductDetail/...G8M/MHAUC2dQ==
                                • Lockley
                                  • Jul 2013
                                  Can someone tell me where to get the 1ZB36 D610 on board? Dave
                                  • Hombre
                                    • Jul 2013
                                    • 231
                                    • Croatia
                                    #117
                                    It's a 36V zener diode (http://html.alldatasheet.net/html-pd...3/2/1ZB36.html), try ebay, mouser, digikey...
                                    • gthorn
                                      • Jul 2013
                                      • united states
                                      #118
                                      When testing the power supply on this tv or one like it (lc320em2f ) emerson ,does it need to be hooked up to the other boards or will it blow the fuse ? I read most of the posts about it and they are very helpful. I have parts on order and hope this fixes it. does anyone have a schematic or diagram for this tv? Thanks you've been a great help already.
                                      • chris1123
                                        • Jan 2010
                                        #119
                                        I'm about to repair one and was wondering has anyone changed out D610
                                        1ZB36 and used 1N4753A-T as a replacement? If not, does anyone know where to get the 1ZB36?
                                          1N4753A will be fine, it is 36V 1 Watt rating.
                                          • Dannyx
                                            UC3842 Power Adapter Blowing Fuse
                                            by Dannyx
                                            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                            12-05-2023, 12:06 PM
                                          • Tips
                                            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                            by Tips
                                            Looking for some assistance please.
                                            Trying to repair a PD27AOQ samsung power board.
                                            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                            Testing it the fuse blows immediately power is turned on.
                                            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                            any assistance, guidance would be appreciated.
                                            04-11-2024, 11:24 AM
                                          • RogerH58
                                            Samsung 46" TV LE46B530 blowing fuse
                                            by RogerH58
                                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                            06-10-2023, 10:27 AM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • Bootleg1
                                            Samsung UN65KS9800FXZA T-con fuse blowing
                                            by Bootleg1
                                            Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
                                            02-04-2020, 01:05 AM
