Looking for couple tips please
  • ohmmy
    • 182
    Re: Looking for couple tips please
    Great. If the psu has both a ps_on and backlight on pin, do both need to be triggered on with a resistor?
      Yes, each resistor for each signal pin, and sometime the Dimming pin also.
      • ohmmy
        • 182
        Could someone's briefly explain what voltages you normally look for on a t-con and what they do?
          5V/12V/13V input typically
          Logic supply voltages: 1.2, 1.5, 1.8, 2.5, 3.3, 5V.
          Panel source driver voltage: AVDD (15~16V)
          Panel common voltage: VCOM (AVDD/2 or 7~8V)
          Panel gate driver voltages: VON/VGH (+20V to +35V) and VOFF/VGL (-5V to -10V)
          Gamma voltages are monotonic around VCOM.
          • ohmmy
            • 182
            Awesome Tom! Why are there negative voltages?
              Ground is relative.
              The way I understand an LCD panel is that the negative voltages take the TFT pixel gate way past the bias point, making sure it stays off. The positive voltages turn the transistor (TFT) from off to conductive, the amount of conduction dependent on the voltage between gate and source.
              tl;dr: ground is relative.
              • ohmmy
                • 182
                Cool. I've read conflicting information about when light is passed through that the TFT is off (non conducting) and others have said that when light is passed through its on (conducting).
                Which is it?
                  Some info.
                  • ohmmy
                    • 182
                    Can you explain what all those labels mean in terms of tcon operation goes? Im only really aware of the low negative and positive signal voltages coming from LVDS cable
                      VON/VGH is used to make a row on the panel take pixel information, VOFF/VGL is used to deselect it. The panel is updated rapidly and continuously. AVDD goes to the SOURCE drivers and controls the pixel intensity. Gamma voltages make the pixel colours look even and accurate. VCOM is used to avoid panel DC bias, leaving burned images. Poor VCOM causes violent visible strobe effect.
                      • randtek
                        • Oct 2011
                        • 280
                        • US
                        #31
                        A quick tip about adjusting Vs and Va (and a good practice for most types of electronic adjustment)
                        You should always operate the TV for about 20 minutes to allow it to come to full, normal operating temperature before performing the adjustment. This allows for the most accurate adjustment.
                        • ohmmy
                          • 182
                          Awesome. Thanks for the info.
                          I'm curious, does running an LCD backlight at full intensity lessen the ccfls lifespan?
                            Yes, but it's not worth worrying about. Typically 50,000 hrs can be achieved by most backlights.
                            • ohmmy
                              • 182
                              Hi guys, curious.. Why do some lcd tvs have master/slave inverters? Does each board drive different ccfls?
                              • ohmmy
                                • 182
                                Still wondering about this
                                Also I've been meaning to ask, what are all these solder lines over traces underneath power supplies? Are they a type of shielding? Thanks to anyone in advance!
                                  They are bare copper traces covered with solder so the trace can handle more current.
                                  • estabilito
                                    Tips geting oxidized when using wick
                                    by estabilito
                                    Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                                    i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                                    Temperature: 350-365celsius
                                    station: jbc cd-2bqe
                                    Wick: edsyn
                                    flux: warton hf rework jelly
                                    Do you have any tips?...
                                    04-12-2025, 11:55 AM
                                  • nothinghyper
                                    Blackscreen after couple of hours playing (PC)
                                    by nothinghyper
                                    Hi Everyone,
                                    After couple of hours playing a game i get blackscreen , i can still hear the sounds and i can move the character but the image doesnt come back until i reset the computer. I have tried running Furmark 1080p settings fullscreen for 7 hours and didnt encounter the same problem. It used to give me an error as driver not responding so i have installed only the driver itself and not the radeon software since than that message doesnt come up anymorre but i still have the same issue. Sometimes it happens after 30 mins gaming time , sometimes after 3 hours , sometimes even after...
                                    08-27-2025, 07:23 AM
                                  • corrize
                                    Quality solder iron tips and Kapton ?
                                    by corrize
                                    Hello, I have a solder iron pen (50w) with tips « 900m » (hollows ones, standard). I'm searching to replace mines because it's impossible to tin, they remain black and impossible to unsolder a mini SMD capacitor with. Bad ones.
                                    I'm looking to replace the iron tips but, on Amazon, Ebay… all no names, the sames. Sold by 10, 15 or more at low price and « pro » websites only one Hakko tips sold 20 dollars. I'm lost.
                                    Do you have brand of qually tips pls ?
                                    Same question for Kapton (for my other hot air iron), do you have brand or good place to buy, the true...
                                    05-24-2021, 11:35 PM
                                  • SolomonMan
                                    A Couple Quick Battery Questions...
                                    by SolomonMan
                                    All,
                                    I have 4 laptops all the same HP Elitebook model. These are now close to 8-10 years old now but they all were high end software development machines (ie 16GB ram (32 max) and all now have been upgraded to 1TB SSD). They are used throughout my house (family).
                                    I recently bought a Software Defined Radio setup (SDR) and I will use it with one of the laptops but the batteries appear to be all dead.
                                    The replacements seem reasonable at the sub $30 range (some as low as $20 shipped).
                                    So I am thinking of replacing them all.
                                    So the question...
                                    04-16-2023, 07:41 AM
                                  • woody-009
                                    Tips on how to remove a very stuck memory chip on a GPU?
                                    by woody-009
                                    Hi Everyone
                                    I'm after some tips on how to remove a VERY stuck memory chip on an RTX2070. I am a beginner with this size chip so I bought an old non working GTX960 and I can remove and refit the memory chips to that with ease.
                                    So far I have cranked my hot air station to as high as it will go (It says 450C but I have no way to confirm that but its hot... its a cheap ebay unit. And I have a large square nozzle and have tried smaller nozzles.) I cant get the solder balls under the chip to melt. It has taken some flux in under it but still wont move. I have chipped one of the...
                                    05-10-2022, 02:54 AM
