Tips on how to remove a very stuck memory chip on a GPU?
  • woody-009
    • Sep 2021
    • 26
    • australia
    Hi Everyone
    I'm after some tips on how to remove a VERY stuck memory chip on an RTX2070. I am a beginner with this size chip so I bought an old non working GTX960 and I can remove and refit the memory chips to that with ease.
    So far I have cranked my hot air station to as high as it will go (It says 450C but I have no way to confirm that but its hot... its a cheap ebay unit. And I have a large square nozzle and have tried smaller nozzles.) I cant get the solder balls under the chip to melt. It has taken some flux in under it but still wont move. I have chipped one of the edges of the chip away by putting my tweezers under it whilst heating it. I've tried taking the top layer of the chip off but still cant get the solder to melt. I have shielded the GPU from the heat with some aluminum foil as I have gotten the board as hot as I dare (heated for a few mins @ 450C and pre heated the board before I started).
    Has anyone got any tips? Different flux? trying to get some solder flowing under it? just give it all the heat in the world??? I'm really not sure how to do it from here, so hoping for some experienced hands to help me out. Sorry if this is in the wrong section too
    Thanks in advance, Kurt
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Tips on how to remove a very stuck memory chip on a GPU?
    You might be able to get away with using a bottom heater to hold the board around 100c and your cheap hot air station but ideally you need a decent hot air station like an Atten 862D or the Quick 861DW.
    I struggled to do some jobs with my cheap station but don't now i have the Atten.
    • woody-009
      • Sep 2021
      • 26
      • australia
      I don't have a board heater. I was just heading it with the station. It just seems weird to me that I can take the 960 chips off with ease but not the 2070. Maybe they changed the solder? Thankyou for the suggestions on the hot air station I think I'll invest in one of those
      • diif
        • Feb 2014
        • 6978
        • England
        I guess it's because the 2070 has a much higher peak power requirements so has thicker/larger ground and power planes sucking away the heat.
        • Junior†
          ((pro))ficient
          • Dec 2020
          • 14
          • United States of America
          If at all possible using low melt solder and I just bought this one (haven't used yet) but northridgefix uses this hot air station: https://northridgefix.com/product/at...ith-4-nozzles/
          • diif
            • Feb 2014
            • 6978
            • England
            You can't get low melt solder under ics that use BGA. The gap is to small and the solder too thick.
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • tranquility
              Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
              by tranquility
              i want to repair an Onkyo TX-NR809 receiver.
              symptoms:
              on power on, display appears and i hear one click. enue functions is given.
              - no hdmi output
              - audio output not tested, but i think it is not there
              - usb sticks are not recognized
              if i read out the chips with display+standby button + tone+
              both dts show only ????
              chip is D830K013BZKB4
              things i have done:
              - reflow of the dts chip without taking off and reballing
              - changed the aluminium caps without the big one with 25v because i dont...
              08-25-2025, 01:04 AM
            • gusto
              How do I remove the chip from the board
              by gusto
              I am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
              Fortunately, I'm testing it on old network switches to see how it works.
              What am I doing wrong?
              I've seen a lot of videos on youtube and everyone got the solder melted and the...
              10-08-2024, 10:55 AM
              Common SPI bios chip programming Questions and Answers
              by SMDFlea
              Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
              A: If you can`t read from it how do you expect to write to it ?.
              Q: Why is my bios chip unreadable ?.
              A: The programmer is faulty or has a worn or broken zif socket.
              The USB cable is frayed,connector pins worn or some other physical damage.
              Not enough amperage or voltage to power the programmer properly.
              Bad...
              09-02-2021, 04:40 PM
