Panasonic TX-37LX85P blink 3 times
+ More Options
Posts
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, i have problem with Panasonic LCD TV, when pluged in there is no picture just red LED blink 3 times. I think it's a faulty PSU.
    I upload the picture of power suply board, on output i got 5V and 1.1V, all other pin are 0.
    PSU model is: TNP8EPL90
    ...the quieter you become the more you are able to hear...
    Re: Panasonic TX-37LX85P blink 3 times
    Here is SM:
    http://www.tgohome.com/ServiceManual...&Search=Submit
    3 blinks - A Board SOS.
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      oh thank you, i take it and have a look, and i see some burned SMD resistor. but don't know whats wrong.
        The A Board 3 blinks SOS is built around a circuit shown on page 49, see AG_SOS. If one of the resistors in that area is burnt out the A Board may mis-detect a fault and do the 3 blinks.
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          I remove the burned resistor, and mark it on picture. How can i find it on TV manual scheme. There is no designation on resistor. I look under page 49, but can't understand the markings.
          • selldoor
            Slow Learner
            • 7870
            Which board are you on?
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              I am on A-board (TNP8EAL90), back side.
              • selldoor
                Slow Learner
                • 7870
                can you read the part numbers on the two 8 legged devices?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  1st part
                  tpc8105
                  h 7:43
                  2nd part
                  3544
                  8g77
                  • selldoor
                    Slow Learner
                    • 7870
                    Clutching at straws here but you can see TP1028 in your pic. If you open the manual pdf and search for TP1028
                    it comes to page 50 of 70 If you pan to the right past c1020 16v 0.1 - check if that is the value of the round blob on your picture? (Clearer pics required) then it says
                    L1029 ( That is an inductor probably black surface mount) then it says TV-SUB-ON. Well just below that is a resistor R1007 47 It is the only Resistor showing in that area. So that is my guess, but its only a guess.
                      How sure were you of it being a resistor?
                      Could have been a ferrite bead.
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        i am not sure, i think it's a resistor. It was black with no marks
                          That is a ferrite bead.
                          Value is not critical.
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            so i can use similar? and then test it?
                              Yes, you can use basically any ferrite bead as a replacement. As long as it is the correct size.
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                i replace it, but no change, still 3 red blink
                                  OK, please locate test point TP7022 and check the voltage there.
                                    Oh, I just realised TP7022 isn't visible, but you can test the pins of Q5615, which is in section D4 (near IC5600)
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      all 3 pins are 0V
                                        OK, there should be a capacitor marked 100 (metal can) nearby. Can you check the voltage across it? Can you post a picture of the area around that transistor?
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • BachPhi
                                          Probook 450 G6 Blink 5 times - No boot - NEED HELP!
                                          by BachPhi
                                          • Issue:
                                            Notebook blinks 5 times on power-up and does not boot.
                                            Actions Taken:
                                            • Tried multiple reset key combinations: V, B, Win, Win+V, Win+B.
                                            • Removed and inspected all components on the mainboard (Part No. DA0X8JMB8E0).
                                            • Replaced the RTC battery (CR2016W).
                                            • Swapped in a different RAM module.
                                            • Checked the BIOS chip (Winbond 25Q128JVSQ):
                                              • Measured Vcc = 3V
                                              • /CS signal stays high after power-on (no activity).
                                          08-24-2025, 07:10 PM
                                        • AdrenalinTL
                                          Caps and num lock blink 4 times
                                          by AdrenalinTL
                                          I am sitting with a very similar issue.
                                          Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
                                          Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
                                          Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
                                          Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
                                          04-09-2024, 10:34 AM
                                        • SentraDude
                                          (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                          by SentraDude
                                          Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                          I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                          Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                          04-04-2023, 04:24 PM
