Sanyo CRT, DS27780, hard to find dipped mica capacitor.
  • Poxy
    • Dec 2012
    • 4
    • U.S.A
    Does anybody know where I can buy about 3 of these caps online? I searched everywhere with no luck.
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Sanyo CRT, DS27780, hard to find dipped mica capacitor.
    Are you sure they are dipped mica? I think they are probably metallized polypropylene. Digikey.com has suitable replacements. What makes you think they are bad?
    • Poxy
      • Dec 2012
      • 4
      • U.S.A
      Well I thought it was the vertical IC I bought a new one and changed it out and it did not work. So I got my heat gun and warmed them up a little and the screen went back to normal within a few seconds. I searched Digikey and mouser, is their a alternative I can try?
        I think the two small lytics caps are bad, common failure in the vertical sweep circuits.
        • Poxy
          • Dec 2012
          • 4
          • U.S.A
          Yeah, I'll probable just have to recap the hole board. I have been also trying to find just the circuit board. If anybody will keep an eye out for a replacement board I would be grateful. Thanks!
            if all you have is just a single horizontal line, then those two caps should more likely to fix your vertical sweep for now.
            • Blargh523
              • Dec 2012
              • 46
              Film Capacitor (aka Polyester), 0.2uF, 200V
              It says 204 because that's the value in pF -- 200000, which is the same as 0.2uF.
              Apparently not a popular item with either Digi-key or Mouser.
              Closest I can find that's actually available (Digi-key) is Panasonic ECW-F4204JL which is a 400v instead of 200v, so may be too fat:
              Length: 15.5mm
              Thick: 8.6mm
              Height: 13.3mm
              I'll throw this out there and see what people make of it: It would be much easier to find a 0.22uF.
                If they're in parallel, you could use a 0.22 and 0.18, though it's very likely two 0.22 will still work. Might lead to a slightly different vertical size?
                • Blargh523
                  • Dec 2012
                  • 46
                  If you go with 0.22uF:
                  Cornell Dubilier: DME2P22K-F (0.22uf, 250v), 6mm thick x 12.5mm long x 10.5mm high, 10mm lead spacing, 125c
                  Panasonic: ECQ-E2224KF (0.22uf, 250v), 5.5mm thick x 12mm long x 10.5mm high, 10mm lead spacing, 105c
                  There are more, I just did a quick browse through the ones actually in-stock at Mouser. The Cornell-Dubiler's would be my personal choice as they have a higher operating temperature rating, YMMV.
                  Last edited by Blargh523; 12-18-2012, 02:45 AM. Reason: Removed Nichicons, not in stock.
                  • Poxy
                    • Dec 2012
                    • 4
                    • U.S.A
                    Thanks a bunch guys I think I will try Panasonic: ECQ-E2224KF (0.22uf, 250v) . I'll get back to you to let you know how it went.
                    • federalhouse
                      **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                      by federalhouse
                      I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                      **Background:**
                      I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                      **What I've Tried So Far:**
                      1. I accessed
                      08-01-2024, 07:03 PM
                    • Vesko356
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • ash91
                      Hp pavilion 15 not detect hard drive
                      by ash91
                      Hello gentelmen .... this is my first post and sorry for my bad english,
                      so my proplem is my laptop keep losing hard drive even if i but the
                      hard disk in the cady (the box that can replace the dvd rom with hard disk)
                      when i turn the laptop on the massage that said no boot media found pop on
                      the hard disk is fine and to be sure i try another hard
                      i also update my bios to the last update
                      the 5 volt is present on the hard connector on the motherboard
                      the dvd rom work fine when i but a windows dvd in it
                      also when i boot from flash...
                      06-07-2023, 01:45 PM
                    • madura2010
                      DAY11AM6E0 hard disk drive and optical disk drive not detected
                      by madura2010
                      Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                      i checked the connectivity of ribbon=good communication with hard and motherboard
                      changed hard disk and checked=3f0 error persist
                      sata power=+5v available
                      Then checked data capacitors=all good
                      Then checked data lines path connectivity to pch=all good
                      reflashed...
                      03-12-2023, 09:09 AM
                    • corrize
                      Where to find a very small fpc connector 0.3mm between 2 pins ?
                      by corrize
                      Hello, I search this connector (oxydated).
                      It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                      I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                      I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                      Do you know how to find this connector please ? What is the exact name for find it ?
                      08-06-2024, 05:25 PM
