Sanyo CRT, DS27780, hard to find dipped mica capacitor.
  • Poxy
    • Dec 2012
    • 4
    • U.S.A
    Does anybody know where I can buy about 3 of these caps online? I searched everywhere with no luck.
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Sanyo CRT, DS27780, hard to find dipped mica capacitor.
    Are you sure they are dipped mica? I think they are probably metallized polypropylene. Digikey.com has suitable replacements. What makes you think they are bad?
    • Poxy
      • Dec 2012
      • 4
      • U.S.A
      Well I thought it was the vertical IC I bought a new one and changed it out and it did not work. So I got my heat gun and warmed them up a little and the screen went back to normal within a few seconds. I searched Digikey and mouser, is their a alternative I can try?
        I think the two small lytics caps are bad, common failure in the vertical sweep circuits.
        • Poxy
          • Dec 2012
          • 4
          • U.S.A
          Yeah, I'll probable just have to recap the hole board. I have been also trying to find just the circuit board. If anybody will keep an eye out for a replacement board I would be grateful. Thanks!
            if all you have is just a single horizontal line, then those two caps should more likely to fix your vertical sweep for now.
            • Blargh523
              • Dec 2012
              • 46
              Film Capacitor (aka Polyester), 0.2uF, 200V
              It says 204 because that's the value in pF -- 200000, which is the same as 0.2uF.
              Apparently not a popular item with either Digi-key or Mouser.
              Closest I can find that's actually available (Digi-key) is Panasonic ECW-F4204JL which is a 400v instead of 200v, so may be too fat:
              Length: 15.5mm
              Thick: 8.6mm
              Height: 13.3mm
              I'll throw this out there and see what people make of it: It would be much easier to find a 0.22uF.
                If they're in parallel, you could use a 0.22 and 0.18, though it's very likely two 0.22 will still work. Might lead to a slightly different vertical size?
                • Blargh523
                  • Dec 2012
                  • 46
                  If you go with 0.22uF:
                  Cornell Dubilier: DME2P22K-F (0.22uf, 250v), 6mm thick x 12.5mm long x 10.5mm high, 10mm lead spacing, 125c
                  Panasonic: ECQ-E2224KF (0.22uf, 250v), 5.5mm thick x 12mm long x 10.5mm high, 10mm lead spacing, 105c
                  There are more, I just did a quick browse through the ones actually in-stock at Mouser. The Cornell-Dubiler's would be my personal choice as they have a higher operating temperature rating, YMMV.
                  Last edited by Blargh523; 12-18-2012, 02:45 AM. Reason: Removed Nichicons, not in stock.
                  • Poxy
                    • Dec 2012
                    • 4
                    • U.S.A
                    Thanks a bunch guys I think I will try Panasonic: ECQ-E2224KF (0.22uf, 250v) . I'll get back to you to let you know how it went.
