Re: Factory Resets Listing
I've taken this page for my future needs.Thank a lot to uploader.
This is a sticky topic.
Vizio 28" D28hn
I am in search of a service menu code for this TV. The tv only has a power button on it so the code where you hold the channel buttons will obviously not work. I have tried the codes in this thread to no avail. Any help would be greatly appreciated.Leave a comment:
akai 32 lcd tv,,lta320ap02 standby problem only red light any helpLeave a comment:
How do I turn off child lock from my Nec tv without a remote (model: NLT-32HDB2) please?Leave a comment:
good day! i have an lg 55lw5600 need to know if going into service code can solve image problem. when image is displayin it starts giving horizontal lines from left to right after hours watching the image becomes nive and clear for a while the troubles again. when tv starts instead of showing the lg logo it displays horizontal white and purple stripes. then the lg block that moves across the screen has the lines after several hours the lines go away and you can tune chanels or go to smart tv programs.
i would like to know id reseting the tv with service code could restore damaged files and it would start correctly. or if i need to change a board or else.
thank you i apreciate you care about other people.Leave a comment:
not working up for service menu or firmware......Leave a comment:
devant 42mel100 chassis msd209 do u have firmware
panel:konka kpl +420b1c3e1
can you give firmware or service manual sir....
thanks in advance.....Leave a comment:
hello can you give me the service manual of devant 42mel100 or eeprom bacause i wanna update because the lcd screen is blurred or shadow or ghosting display....help me with this masters thanks in advance......Leave a comment:
It looks like you do need LG remote since I do not believe the universal will have the 'ADJ' button.Leave a comment:
so will you need the lg service remote control? The remote that came with the tv wont work.LG TV pictures upside down.
https://www.badcaps.net/forum/showpo...09&postcount=7
Thanks to dick_bartonLeave a comment:
Not sure if in this already or not:
SAMSUNG LE40M86BD
Thanks to Alastair E:
https://www.badcaps.net/forum/showpo...4&postcount=39
set in stdby, Info, Menu, Mute, Power, select options, then Panel type/size.
enter and go through list. select right one, then press enter.
Simples!Last edited by budm; 02-29-2016, 03:29 PM.Leave a comment:
I just did it on my my LG 50PG25 Plazma.
Hold down the MENU keys on both the remotes at the same time while the TV is on. Then enter 4 digit PIN code. Mine was 0000. There are others and they are listed on-line. Hope that helps.Leave a comment:
tevion factory menu found lcd 42031d
to access press vol set to 15,
then quickly press r,g,b,y,text buttons ,factory menu comes up ,
as does text so exit text with text button first.
unless theres another page to the f menu theres no lvds panel setting ,
like on the samsungs ,theres normaly more than one page in the s menu,
for pic geometry ect, but as yet cant find it, any ideas pleaseLeave a comment:
cleaned my glasses! now the panel number is:p/no, 303c4201073
MHDV4201ZC01-01B This is printed on board not on white paper label
thanks againLeave a comment:
The only hits on google relate too a tcon board maybe try to upload a picture of the board you will have to use imgur for now to upload the picture and maybe one of the more experieneced members may reconise the board and know a service codeLeave a comment:
i understand.
but both of these labels are on the main board
as you say the one with hdmi and tuner
thanks vinceLeave a comment:
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RRice25541So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
the color is all outa wack, like the settings have been corupted,
I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
so
The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
when i bring up the menu and type the pass codes to access either mode the menu disappears... -
by howardc64Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
- TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
- Service Menu shows many Bt/Wifi info missing
- Vizio app shows no WIFIVendor file
- Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
by dxzhowdy yall,
back in this last december i lost my svp for my thinkpad, then i found this technique and it worked successfully.
the only thing i found weird was that now in the bios menu, specifically under the secure boot configuration in the security tab, it went from mentioning microsoft windows 10 to now showing microsoft windows 8 when i scroll over the restore factory keys option.
and im wondering if my current problem is due to the flash/patch ive done:
im having a hard time activating windows 10 pro :lenovo thinkpad e480 that i purchased...-
Channel: BIOS Requests ONLY!
by Retro140Hello,
So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button... - Loading...
