Vizio 42" LCD VU42LFHDTV10A Bad panel?
  • Cosmo66
    • Nov 2012
    • 87
    I was thinking of picking up this TV, the guy wants $40 for it. He is telling me that it only has problems when using certain inputs, which I don't really believe because looking at the picture that doesn't seem to make sense.
    What concerns me are the vertical lines. That looks like a failing panel. Am I correct to make that assumption? or should I take a chance on this thing?
  • Mr Bill
    • Nov 2011
    • 648
    Re: Vizio 42" LCD VU42LFHDTV10A Bad panel?
    here is an example of a 32" samsung that had a bad tcon board. The picture is blurry but you'll see it had lines in it too.
    • drpj23
      • May 2012
      • 528
      If it is only on certain inputs, ask him to prove it since he knows somehow.
      • Cosmo66
        • Nov 2012
        • 87
        I'm gonna go get it, he'll take $20 and it's only 15 min away. I need a good project
        • Mr Bill
          • Nov 2011
          • 648
          The boards are worth more than $20 incase the panel really is defective.
          • Cosmo66
            • Nov 2012
            • 87
            I got the TV. The problem is on all inputs. The vertical lines disappear within 3 minutes. Once the TV warms up the horizontal anomalies go away also, and the picture looks great.
            I don't have time now to open up the TV, but when I do will post back with info and pictures if I find anything interesting
            • Mr Bill
              • Nov 2011
              • 648
              For giggles when you do open it up, clean and reseat the connectors going to the tcon board. It might just be something simple.
              • Cosmo66
                • Nov 2012
                • 87
                Ok thanks. That would definitely make me giggle a little bit. By the way, that picture you posted of the tcon failure looks so similar I'm pretty convinced that's the issue
                • drpj23
                  • May 2012
                  • 528
                  If the reseating doesn't work, then hot air or cold spray will probably confirm the TCON failure.
                  • Cosmo66
                    • Nov 2012
                    • 87
                    Ok, so I opened up the TV and reseated the connectors to the tcon and the problem persists.
                    However, I can make the problem go away if I twist the panel. This leads me to believe the problem is where the ribbon cables connect to the panel.
                    My question is, does anyone know if these ribbon cables are connected to the panel via a connector, or are they part of the panel like plasmas? I'm gonna have to take this apart all the way to the panel to find out
                    • Mr Bill
                      • Nov 2011
                      • 648
                      They are bonded to the panel. You can put something that is squishy yet firm and place that under the loose ribbon. Others will probably chime in on what works best.
                      **EDIT**
                      The ribbons in the picture you uploaded should have a connector. The 1" board that runs on top of the panel is what is bonded to the screen. Does the image change if you press on the ribbons from you picture?
                      • Cosmo66
                        • Nov 2012
                        • 87
                        No, pressing on the cable doesn't do anything, only twisting the panel
                        • Cosmo66
                          • Nov 2012
                          • 87
                          I forgot to mention one of those shields that go around the ribbons had broke free and was hanging loose. I'm assuming that is the ribbon causing the trouble
                          • Cosmo66
                            • Nov 2012
                            • 87
                            So do these 4 cables coming off the tcon board go into another connector? I really hope they aren't attached to the panel.
                            It looks like I'll have to take this completely apart to have access to them
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Those go directly to the boards that go directly to the panel. There are no removable connections.
                              • Cosmo66
                                • Nov 2012
                                • 87
                                I'm starting to think maybe this is a backlight or some other issue. Basically the problem only affects the top 5-6 inches of the screen, horizontally. As I twist/move the panel around the problem flickers/ goes away. I can make it go away completely if I hold the TV in just the right spot.
                                The only thing that points to the tcon ribbon cables is the vertical lines that appear at first on the left, but disappear right away
                                Here it is so you can see it
                                http://www.youtube.com/watch?v=HQsLr...ature=youtu.be
                                (there is no color on the menu, because I just swapped out the tcon board from a TV that had a "no color" problem)
                                • Mr Bill
                                  • Nov 2011
                                  • 648
                                  To me it looks like a loose TAB ribbon. The only way to know is take the front cabinet half off the panel. Lay the tv screen side up and take the metal trim off that goes around the panel to acess the ribbons. Turn the tv on and start applying pressure to the ribbons with a stick, plastic pen, anything that won't conduct electricity and see if the image improves.
                                  • Cosmo66
                                    • Nov 2012
                                    • 87
                                    I was having a good night until I read this
                                      It looks like this:
                                      http://s807.photobucket.com/albums/y...20KDL-52VL150/
                                      • Cosmo66
                                        • Nov 2012
                                        • 87
                                        Wow great photos thanks.
                                        The problem is the way these vizio's are built, I have to remove the metal plate that the power supply and main board sit on, and the entire front panel cover first. Then I can remove the metal trim.
                                        Basically I have to strip the whole thing down to just the panel. It's gonna be a weekend project
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
                                          by howardc64
                                          Failure Symptom
                                          No Display. Just random blocks of grouped vertical red lines.
                                          Disconnect right 1/2 panel (rear view), left 1/2 displays properly
                                          Masking T-Con Signal Diagnostic
                                          Reduced masking to 5 signals on right 1/2 panel and get perfect picture
                                          Pins are
                                          1 GND
                                          2 VGHD
                                          3 XON
                                          4 VSSQ
                                          5 LC2
                                          6 LC1
                                          VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
                                          Pictures and Schematic
                                          XON, LC2, LC1 are on AUO s302-21 32pin QFN...
                                          10-14-2024, 01:30 PM
                                        • frannyjunk
                                          Putting LCD panel from Vizio TV into another brand TV
                                          by frannyjunk
                                          I have a Vizio P502UI-B1 50" tv and baked the main board a little too much (to reflow BGA) resulting in a dead tv. I would like to use the Vizio LCD panel in another tv. Someone in the P502UI-B1 thread said he/she was able to take that Vizio LCD panel and put it into an LG 50UH5530 and it worked. Looking at the Tcon boards from the 2 tv's show different model boards (LG = EAMDJ2S55 while the Vizio tcon = V500DK2-CKS2). I have since looked up tv's that uses the V500DK2-CKS2 Tcon board (Hisense 50H7GB, Vizio P502-B1E & M50-C1, Westinghouse WD50UT4490, and a few others). Does this mean any...
                                          07-27-2021, 04:14 PM
                                        • NSkyLab
                                          Vizio D43f-J04 is panel dead?
                                          by NSkyLab
                                          TV Model: Vizio D43f-J04
                                          Main Board: TPD.MT5583.PB751 (60103-00876)
                                          T-Con: BOE_CC430LV2D_43001 V1.0
                                          Panel: BOEI430WU1
                                          The video of the defect is here: https://photos.app.goo.gl/fzfvmUqGXW3c1Nrg9
                                          This is a dumpster find, don't know if it was hit, there are no visible cracks...
                                          I though there may be something wrong with the panel voltages.
                                          Those I managed to find on the T-Con board. Does it seem normal?
                                          12V: 12.27v
                                          VCC33: 3.28v
                                          1.2V: 1.25v
                                          VGL: -5.87v
                                          AVDD: 16v
                                          HAVDD: 7.47v
                                          VCOM: 7.0v...
                                          01-29-2023, 08:18 PM
                                        • howardc64
                                          LG 49UJ6500 LCD panel lighter band that goes away
                                          by howardc64
                                          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                          02-19-2023, 12:13 AM
