Sylvania LC420SS8 shutting down on protect(?)
    Re: Sylvania LC420SS8 shutting down on protect(?)
    If it has 3.3V output and the input is 7.2V, that means it has 3.9V across it. So it depends on how much current is flowing through the regulator, that power will have to be dissipated by the regulator. The only way to find out is to measure the current draw which means you have to the DC AMP meter between the output of the regulator and the load to find out if the current exceeds the spec or not.
    • iKitsune
      • May 2010
      • 61
      #42
      I found another Funai-built set on a similar chassis: The slow-blink power LED is normal during power-on. The fast-blink happens when it would go solid, and I'm thinking it's a mainboard fault, since it happens when the other set goes to select the input. Oh well. Any thoughts on a good place to sell the panel? (I have no idea how to ship a 42" panel, though.)
      • beanboy33
        • Jan 2010
        • 17
        #43
        Anymore news?
        • iKitsune
          • May 2010
          • 61
          #44
          Originally posted by beanboy33
          Anymore news?
          Still propped up in my closet, current guess is inverters, but I'm not of a mind to go throwing a $70 set of inverters in it.
          • zvaniel4o
            • Feb 2014
            • 12
            • US
            #45
            Do you still have it?
            • zvaniel4o
              • Feb 2014
              • 12
              • US
              #46
              I changed one smt and one th diodes with mine... replaced - works like charm!
              • lemo5617
                • Jan 2015
                • 5
                • canada
                #47
                Which one of the smt diode did you replaced?is it on the main board?
                • x_orange90_x
                  Vizio E55-E1 bad backlights or bad inverter?
                  by x_orange90_x
                  I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                  I don't know how exactly to test the inverter itself. Is it...
                  01-29-2025, 09:24 PM
                • lostone
                  Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                  by lostone
                  Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                  First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                  When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                  05-19-2024, 11:40 AM
                • Gentian
                  APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                  by Gentian
                  I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                  It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                  03-06-2023, 07:07 AM
                • valvashon
                  Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                  by valvashon
                  For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                  History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                  01-04-2024, 01:44 PM
                • eccerr0r
                  A modified sine wave inverter + a grid tie inverter?
                  by eccerr0r
                  If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                  Next thing is trying to charge the batteries using solar power, but that's another issue ...
                  08-31-2023, 09:14 PM
