Sylvania LC420SS8 shutting down on protect(?)
Re: Sylvania LC420SS8 shutting down on protect(?)
That is way too low, you can see that it has 100K (R3117) resistor between the protect pins (64) and ground. You are testing it with the TV unplug?
It can be bad MLCC (MULTI-LAYER-CERAMIC-CAP) C1111 (1000pF) that is connected on pin 64.
Oh by the way, what do you read on the Anode side of that Diode?
I think we are getting close.Last edited by budm; 11-30-2012, 01:36 AM.Never stop learning
Yes, the set is unplugged when I'm doing resistance testing. The measurement was between pin 64 of the IC and the frame ground.Comment
I suspect bad c1111 or worst case, internal short in the IC. I would try removing the cap.
Something is really loading down this line.Never stop learning
Another interesting find on this model.
https://www.badcaps.net/forum/showth...SS8#post253049Never stop learning
Wellp, I'm retarded. My meter had a dead battery, so all the resistance values are out the window. Retest with a fresh battery: 99.34 kOhm.Comment
https://www.badcaps.net/forum/showth...SS8#post253049Comment
That is just for the buzzing problem, not relate to what you are working on, I just point that out for FYI.
So you need to check to check the DC reading again then on Portect 1,2,3,5,6.Never stop learning
I comprehensively rechecked all the voltages I'd measured yesterday.
PROTECT1: 2.57
PROTECT2: 0.88
PROTECT3: 2.97
(spent half an hour looking for protect4, lol)
PROTECT5: 3.25
PROTECT6: 2.99
VT+33v: 31.8
LCD+12v: 11.99
+6v: 7.28
+2.7v: 2.17
AL+3.3v: 3.19
P-ON+6v: 5.48
P-ON+9v: 8.84
+3v: 3.07
+4v: 3.87
+24v: 23.1
I was looking at the schematic again, and on page 33, the voltage chart for CN201 says PROTECT2 should be 0.9v, which is pretty close to what I'm reading.Comment
OK, it looks like we ned to look at the Protect 3 (24v present detection), you can lift one end of the detector diode D757 and see if you will still get error condition, it the error is gone then we can concentrate on the 24v power supply circuits next.Attached FilesNever stop learning
Fault remains with D757 lifted.Comment
So it still flashing the code? So far I do not see any info on the flashing error code in the service manual. Something else is triggering the error some where. I hope it is not corrupted EEPROM problem.Never stop learning
Opinion time: If it is the mainboard (and assume I'm not set up to do PQFP or BGA rework), would this set be worth putting an eBay / ShopJimmy mainboard in, or should I just haunt Craigslist and look for one someone smashed the LCD on? Looks like a mainboard on ShopJimmy is around $135.Comment
As an aside, I've already tried "obvious" things, like separating the T-con from the digital board, and separating the panel from the T-con with the T-con still connected to the digital board, to see if that changed the fault.Comment
Not sure either for 42" TV to be worht it or not.Never stop learning
Or one of the inputs to it does. Something coming across the power board from CN202 could be forcing it down; disconnecting CN202 (which only carries audio and a couple control signals) changes the behavior - the only thing so far that has! The unit blinks 3 times and then promptly shuts down instead of sitting there for 10 seconds blinking and trying to start up. For as lovely as this service manual is, a list of blink codes would help me out.
Edit: Durp, bet it's PROTECT3.
Edit edit: PROTECT6, I can't read. That shoots down my theory of it being a PROTECT line triggering either way.
Edit edit edit: 10 seconds, not minutes.Last edited by iKitsune; 11-30-2012, 04:59 PM.Comment
I'm back to thinking regulation; I accidentally bumped my thumb against the tab of the AL+3.3v regulator on the power board, and it was alarmingly hot. (IC220). Any thoughts on if this could be a regulation issue? The input feeding the 3.3v regulator was almost 20% high. Most of the voltages are right on the edge of being 10% out of spec, some are more.Comment
It should be too hot to touch, if you cannot leave the finger on it for mare tha 10 seconds, that will be hot. How high is the input voltage?Never stop learning
The schematic and the datasheet for the regulator say it should be 6.3v. I'm reading 7.2v.Comment
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by ManiackkHi,
I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
The cooling system has been cleaned, thermal...09-03-2025, 09:32 AM -
by lostoneHello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...-
by GentianI have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...03-06-2023, 07:07 AM -
by valvashonFor some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...1 Photo - Loading...
