Philips 42PFL3704D/F7 Dead
    Re: Philips 42PFL3704D/F7 Dead
    That should not stop AC from being at the bridge rectifier unless the main fuse is blown, there is/are open trace/traces from the AC input to the Bridge AC pins some where.
    • kevinm34232
      • May 2012
      • 1884
      That's what I thought, I think Tom said the relay had to kick on first though..
      • kevinm34232
        • May 2012
        • 1884
        Will this block diagram help determine where I need to look at?? I'm stuck here, I would go from the fuse to the bridge rectifier normally but something in between here... I see RL1201 sending back to main bridge rectifier but goes to standby circuit first looks like..
          OK, there are more than one bridge rectifier, one has AC fed through the relay for the main power supply which I believe that the shorted out transistors are in or they are in the standby power supply section. The standby power supply is always on, the main board will turn on the relay to run the main power supply instead of using PS_ON to turn on the IC. . So if the standby does not work, the relay will not turn on.
          • kevinm34232
            • May 2012
            • 1884
            Is the standby the 3.3vL?
            • kevinm34232
              • May 2012
              • 1884
              What DC voltage should I have at the transformer T1201? I checked pins on primary side and getting about 76v.
              One more thing before bed, R1217 is a 820k resistor as is R1218 and R1219. R1217 measures about 860k the others around 824k. Is that one out of spec?
                You need to measure the DC voltage right across C1201 (47uF 350V), it should be around 170VDC, as you can see the negative leg of this filter cap is not the primary ground for this standby power supply. So this is the section that you had replaced the blown transistor/MOSFET.
                • kevinm34232
                  • May 2012
                  • 1884
                  Yes it has 166v
                  • kevinm34232
                    • May 2012
                    • 1884
                    I finally just replaced this power board and I got the TV to power on only to find the screen was cracked... It comes on for a few seconds and then shuts down. Is it normal for some TV's to shut down if panel is cracked or do I have another issue??..
                    BTW the problem was defientely in the standby power section. I was never able to isolate it, and finally 2 legs on the transformer burned up and that's when I gave up on it..
                      You probably have cracked bulbs in the panel from something hitting the screen pretty hard.
                      • MisterD
                        • Oct 2012
                        • 668
                        Just out of curiosity does it still shut down if you unplug the connector going to the T-Con Board? since the screen is cracked I was wondering if this could be a test for others dealing with a possible cracked screen but not knowing because it shuts down too fast to see, I realize that doing this is also eliminating the T-CON Board as well. Thanks.
                        • magneh
                          Is this some kind of fuse resistor ?
                          by magneh
                          Hello guys
                          Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                          Seem to me like some kind of fuse resistor?
                          After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                          They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                          The red band is larger than the 4 others, but I dont have much experience with these components.
                          Also one of the orange...
                          02-10-2025, 07:54 AM
                        • bobby4star
                          BN44-00517C dead - blown cap, resistor and fuse
                          by bobby4star
                          Hi All,
                          I have a UE32ES6540 which is dead, customer reported a pop and a puff of smoke. PSU is BN44-00517C and has blown 221k 1KV cap, next to this a blown resistor RM811. Board mains fuse is blown.
                          Has anyone seen this problem and will changing the cap, resistor and fuse likely fix it? One more ask, can anyone give me a 2nd opinion of this resistor rating of RM811? I think it's 0.24 Ohms but would like a 2nd opinion! See attached pic.
                          Thanks!
                          Bob...
                          11-12-2020, 12:46 AM
                        • kew1701
                          Philips taw6205 ambilight speaker STM32 mcu dead
                          by kew1701
                          Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                          04-09-2025, 03:59 AM
                        • dellxps15
                          macbook a1707 15 inch trackpad dead. blown fuse identification
                          by dellxps15
                          hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                          another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                          04-30-2024, 10:48 AM
                        • Acnologia
                          Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                          by Acnologia
                          Here is a pretty crazy one.
                          Step 1.
                          Laptop was brought to me as dead not working. Removed everything , cleared everything.
                          Step 2.
                          Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                          Step 3.
                          Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                          Step 4.
                          Lets ,dive into the board. I see the edp cable on the...
                          05-07-2025, 07:16 AM
