Replaced T-con board and now getting vertical lines
  • shanusmarty
    • May 2013
    • 19
    • India
    Re: Replaced T-con board and now getting vertical lines
    all the pics! please some one help out!
      Any one of the whole chassis?
      • shanusmarty
        • May 2013
        • 19
        • India
        Originally posted by tom66
        any one of the whole chassis?
        sure!
        • shanusmarty
          • May 2013
          • 19
          • India
          have checked the voltage on TCON, its good!
          idk what could be the fault ? :/
          • shanusmarty
            • May 2013
            • 19
            • India
            havent played with bond tabs yet, n scared to try eveN!
            • 1supertech
              • Apr 2012
              • 384
              fourth pic of main board polymers caps look like they are starting to bulge 100uf 6.3v & 47uf 16v
              • shanusmarty
                • May 2013
                • 19
                • India
                #27
                sir can u mark it out in the pic and attach the pic ?
                but i think the main board is working fine, coz there is sound and the buttons and remote is functioning well..
                need your suggestions ?
                ok i located, how can it be checked?
                i have a multi meter, i checked , they have continuity with out power!
                • 1supertech
                  • Apr 2012
                  • 384
                  I put red circles around caps
                  • shanusmarty
                    • May 2013
                    • 19
                    • India
                    #29
                    • 1supertech
                      • Apr 2012
                      • 384
                      You would need a ESR meter that is capable of testing on board or take them out to test.
                      • shanusmarty
                        • May 2013
                        • 19
                        • India
                        #31
                        but they are not bulged, though it may seem in the pic!
                        • shanusmarty
                          • May 2013
                          • 19
                          • India
                          #32
                          and if main board is at fault, can the tv switched on, and all sounds and buttons are working fine ?
                          • 1supertech
                            • Apr 2012
                            • 384
                            Even thou it may look like it's bulged in the picture and it's not
                            capacitors don't have to bulge to be bad I test all my caps to find a problem
                            • shanusmarty
                              • May 2013
                              • 19
                              • India
                              #34
                              sir if the main board is bad(faulty), can the tv function properly ?
                              all buttons and sounds working good!
                              • 1supertech
                                • Apr 2012
                                • 384
                                Here is a cheap capacitance meter
                                http://compare.ebay.com/like/1308375...Types&var=sbar
                                • 1supertech
                                  • Apr 2012
                                  • 384
                                  I would say so but I could be wrong may be someone else out their with more TV experience can suggest some more ideas?
                                  • shanusmarty
                                    • May 2013
                                    • 19
                                    • India
                                    #37
                                    i have checked by replacing the main board once.. the results were same!
                                    • 1supertech
                                      • Apr 2012
                                      • 384
                                      If you tried a good mainboard & Tcon then it may be the panel
                                      their may be a fuse on the Tconn did you check
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        This is purely unscientific, but Sony LCD TVs are notorious for panel and main board issues. If you've tried a known working main board, you probably have a bad panel. Do the vertical lines on the screen in your pic show up like that when it's first turned on, or do they gradually appear?
                                        LG Plasma Mal-Discharge Correction Service
                                        • shanusmarty
                                          • May 2013
                                          • 19
                                          • India
                                          #40
                                          they are very less at starting and grow more.. then fill up.. then very light when the cfl is on full brightness.. u can see the full video.. in my earlier post
                                          • Stanley1843
                                            by Stanley1843
                                            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesnโ€™t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                            06-29-2024, 11:54 AM
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed๐Ÿ™
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • gpo23
                                            Sony KDL-40V3000 - Vertical lines
                                            by gpo23
                                            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                            With the new t-con the color are good but there are vertical lines on all the screen :
                                            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                            Is there a way to fix the vertical lines on the new t-con ?
                                            Thank you for your help
                                            gpo23...
                                            10-04-2023, 09:11 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
