Liquid accidents are repairable?
  • tibimakai
    • Jan 2012
    • 3680
    It's possible?
    I have a Vizio TV that I could pick up.
    This is what the owner states:
    "I have this 42" Vizio LED TV as stated above. I spilled water on the front of it and now the picture is messed up.
    Hazy picture and solid white lines going through the display.
    I don't know what else to do with it I don't have the time or resources to fix it.
    Maybe someone knows better than I what to do with it."
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Liquid accidents are repairable?
    Repairing liquid damage to electronics is a pretty iffy prospect. It is easiest and most often successful if you begin IMMEDIATELY after the spill occurs. If the liquid and or residue has been left in the electronics for any length of time, corrosion to connections, component leads etc. quickly sets in. Repairing that kind of damage is time consuming, and often not worth the trouble. If the corrosion has reached the point that is affecting circuit operation. there is often corrosion damage to many components, and often further component damage due to being operated with corrosion in the circuits. From what you are describing, the LCD panel is probably shot.
    • XmouseX
      • Aug 2011
      • 158
      • US
      I second that...lol
      • tibimakai
        • Jan 2012
        • 3680
        I had another 42" LED Vizio with some kind of white powdery substance on the T-con connection and after cleaning it up the TV showed a nice picture, but it had a thin blue vertical line right on the center.
        I guess, this on is in a similar shape.
        Thanks.
          Not repairable 90% of cases:
          http://www.youtube.com/watch?v=yqcqD...=results_video
          What I wonder, how do people get their TVs wet? Do you have a drink with it?
          • tibimakai
            • Jan 2012
            • 3680
            ...probably partying or they are drunk.
            • mattpd
              • Oct 2012
              • 302
              For a TV that expensive I would at least attempt to mend the tab with some jumpers. I would probably need glasses by the time I finished...
                Good luck with 0.2mm pin pitch and no copper left to solder. TV tech in this case is paid to do work, which is not economical for such a tricky job.
                • mattpd
                  • Oct 2012
                  • 302
                  It looks like all the damaged traces have at least a little copper left. Some fine grit sand paper should expose the tiny piece of copper that is left in the tab and as long as its big enough for a tiny wire, it should be easy to find a place on the board to attach it.
                  Its worth a try, but defiantly in your spare time.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I'm trying to solder some very tiny traces in a Samsung Vibrant cell phone, (when I removed the charging port I have ripped two traces off) and I couldn't(yet). The two traces are so close to each other and the second problem is that I'm having a hard time making the wire to stick to those tiny traces.
                    To solder something so fine, we shouldn't use some smaller solder iron?
                    Sandpaper is the way to go on these ribbons.
                    • mattpd
                      • Oct 2012
                      • 302
                      A pad so small would have to be super clean and fluxed well to get anything to stick. It would require a very tiny soldering tip also. Tin the pad, tin the wire, clean the tip very well and go to work.
                      Hopefully you get it right on the first try because I can see ruining the tab completely if you tried too many times.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        The wire is so short that when I finish one side it will melt when I'm trying to solder the other side.
                        I think that I will put some kepton tape on the two wires to hold them in place.
                        • mattpd
                          • Oct 2012
                          • 302
                          Yeah I have had that problem too. They make heatsinks that clip on wires to prevent this, but the wire is probably too small to clip it on. Can you use a longer flexible wire and tuck it away after you get both ends soldered?
                          • MisterD
                            • Oct 2012
                            • 668
                            Take an old power cord and strip some of the insulation off it leaving some pieces longer than what you need, then separate the strands of wire and pull one strand aside, this is the strand you will use, tin it with solder, you can then hold the insulation with your hand and get the one end soldered after that you cut the wire just slightly longer that what you need and solder the other end.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Thanks, I will try that way. I have very small gage copper wire, but that one has enamel on it and it's not easy to clean it well without braking it.
                              I'm starting to repair cell phones, laptops, next to TVs and monitors. I'm doing these when the TV "business" slows down.
                              • severach
                                • Aug 2007
                                • 1055
                                I get my repair strips from stranded wire in power supplies. Soldering the strands to fine pitch traces doesn't require a new iron, it requires new skills with an Xacto knife. The knife performs 3 duties.
                                0) The first side of the strand is soldered in place still attached to the full insulated wire as a handle. No knife here.
                                1) Once the full wire has been pushed around to where the strand sits above the trace on the other side, hold the knife in the middle of the strand to press down, steady position, and block the heat. Only a strands worth of heat is coming through and it doesn't take much to block it.
                                2) Once the strand is soldered and can stand up to a little beating from the knife, cut the strand off the full wire. So long as only one side pops loose you can redo quickly as above. If both sides come off discard the stub and use another stand from the full wire.
                                3) If successive traces need to be fixed, place the razor along the previous trace to solder the first side which blocks the iron from desoldering the old trace and spaces the new trace properly.
                                Don't screw up. It's easy to get careless and have your iron remove all the repaired traces like a bull in a china shop.
                                sig files are for morons
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Thank you, I will try it this way first.
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • SS454
                                    vizio e650i-a2 backlight flashes then turns off
                                    by SS454
                                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                    panel: au optronics T650HVN05.4
                                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                    08-20-2020, 03:57 PM
                                  • mrtek
                                    Vizio M65-C1
                                    by mrtek
                                    Hi.
                                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                    07-14-2025, 07:28 PM
                                  • silver60618
                                    How to clean Liquid Metal from under CPU?
                                    by silver60618
                                    Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
                                    The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
                                    Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
                                    07-11-2025, 01:47 PM
                                  • howardc64
                                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                    by howardc64
                                    Failure Symptom
                                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                    Where is the short?
                                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                    05-27-2025, 02:56 PM
