Hi i have this sharp tv here and it will come on for a few seconds then turn off with flashing green led, i pulled the cover off and no visible bad caps and all of them except the primary caps are rubycons. there are similar models on here but none exact that i can find...could this be a case of bad ccfl? any input would be great and together hope we solve this problems thanks....
Sharp LC-32SB23U
Tags: None
Re: Sharp LC-32SB23U
Count the blinks on the power and OPC LED.
For example 5 blinks power 2 blinks OPC: 5-2 blink code.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
well power button used to respond now it does not, soon as you plug it it all you get is continuous green led flashing like this flash 1 second flash one second flash etc it keeps same pattern... i think its a board issue since button stopped responding perhaps main board what are your thoughts?Comment
Is it a genuine Sharp TV - or one of their rebadged models? Does it have an "OPC" LED?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Is there an indicator next to the power LED marked OPC?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
okay i see it duh guess i never noticed since it never lights up and still does not and the power button used to respond now it does not, soon as you plug it in the power led just flashes, i unplugged the power button board same results so its not a stuck button......and i have no stb voltage, and weird the ON pin does have 5.08 volts, so i think it safe to assume the bulbs are ok at this point, and the prob is either on power board or main/tcon integrated into one, this tv only has 4 boards, tuner, main board/tcon, power button board and power/inverter board. what would be the next thing to check? Thanks again for your help and patience for this greenhorn....Comment
You may want to download the service manual
http://elektrotanya.com/?q=showresul...oria=&kat2=allAttached FilesLast edited by budm; 10-24-2012, 11:11 AM.Never stop learning
Heavy i just repaired a Sharp LC32SB24U. Search this Model in forums. I would bet they are very similar if not the same. There is a cap you can jump on the back side that will help you find your problem. Plz remove it when you are done and clear the codes. For testing only.. Saved me lots of time. Thanks!! Hope this helps.Last edited by Jerry7591; 10-24-2012, 11:15 AM.Comment
cool a service manual good for parts reference but does not help with the issue. thanks very much i do appreciate it. may need it at some point.You may want to download the service manual
http://elektrotanya.com/?q=showresul...oria=&kat2=allComment
i looked it up there is only one other forum on this model and it shows it has bad bulbs and seems to be a different problem and at the tail end of that forum there is one guy mentioning something similar to what your talking about but it failed and he has even more issues..could you share more details on that? or maybe even give me the link to that forum? thanks for your reply i am open to suggestions, thanks....Heavy i just repaired a Sharp LC32SB24U. Search this Model in forums. I would bet they are very similar if not the same. There is a cap you can jump on the back side that will help you find your problem. Plz remove it when you are done and clear the codes. For testing only.. Saved me lots of time. Thanks!! Hope this helps.Comment
I was able to bring my set back to life by removing the C7558 capacitor and replacing it with a small jumper wire. This capacitor is on the backside of the inverter board (green side). It is located about an inch below the BD9883 chip. It is an extremely small, surface mount component. This keeps the inverter controller chip from getting the backlight error signal that shuts down the power board and initiates the annoying flashing green power LED issue. You will have to reset the error count after doing this by holding the power and input buttons down for a few seconds until the flashing green light is replaced by a steady red light. Definitely an "out of warranty" repair, but better than junking the whole TV. This is what i did and it fired up and showed what bulbs were bad. It's only for testing as this is not safe to leave in place. The cap is surface mount the size of a match head. This really helped me find the problem. Good Luck heavy. Cheers!!Last edited by Jerry7591; 10-25-2012, 05:56 AM.Comment
Ah, I remember that bad lamps problem now. https://www.badcaps.net/forum/showth...t=19796&page=2Never stop learning
That's very clear information, should be able to do that. been very busy haven't been able to get to it, workload been tremendous at work. But i will get to it. And cheers thanks alot.I was able to bring my set back to life by removing the C7558 capacitor and replacing it with a small jumper wire. This capacitor is on the backside of the inverter board (green side). It is located about an inch below the BD9883 chip. It is an extremely small, surface mount component. This keeps the inverter controller chip from getting the backlight error signal that shuts down the power board and initiates the annoying flashing green power LED issue. You will have to reset the error count after doing this by holding the power and input buttons down for a few seconds until the flashing green light is replaced by a steady red light. Definitely an "out of warranty" repair, but better than junking the whole TV. This is what i did and it fired up and showed what bulbs were bad. It's only for testing as this is not safe to leave in place. The cap is surface mount the size of a match head. This really helped me find the problem. Good Luck heavy. Cheers!!Comment
Thanks a million to you guys and this forum works like a charm now just need to order bulbs..This tv is actually pretty slick, socketed bulbs, the panel comes off without having to completely dismantle , its actually a very user serviceable tv...pretty slick...Comment
by beetle1303Sharp TV flashing green light 2x per second at constant rate. Various reset methods do not have any effect on it. Search here and found flashing green 2x per second indicate bad power supply, which I am quite certain now.
I am seeking help with basic trouble shooting to find the short-circuit on the secondary side that I believe is the cause:
The main PD connector:
PD-1 (PNL12V) : 0.02V
PD-2 (PNL12V) : 0.02V (fluctuating)
PD-3 (SGRN) : 0V
PD-4 (SGRN) : 0V
PD-5 (UR13.2V) : 0.05V (fluctuating)
PD-6 (UR13.2V) : 0.05V (fluctuating)... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by 0xxHi folks,
My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
I assumed that Windows Update was interrupted due to closing... -
by kyhoI have 46" Sharp TV LC-46D85U, recently it doesn't power on. It gives flashing one power light and OPC light together then flashing one on power light, then repeat the flashing pattern, I checked the forum and the error code for this pattern, it indicates the power supply board is faulty. I am not sure it is the power supply board or other boards. I measured the voltage on the PD connector, I have +2.99 DCV on pin 8 (AC_DET) and +5.01 DCV on pin 12 (BU5V), other pins and LB1, PL, LB2, LA connectors has 0 volt. I removed the power board and connected with BU 5V + 490 ohm resistor to pin 9...
by dmcabsHey guys,
I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
I'm a bit rusty but still have ability to dig right down.
I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about... - Loading...
