Panasonic tc-p50c2 1 blink
+ More Options
Posts
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tc-p50c2 1 blink
    IC9304 https://cceparts.com/productdetail.a...y=PPTVRR222AAS
    IC9001 https://cceparts.com/productdetail.a...y=PPTVRR214AAS
    IC9304 http://www.partsimple.com/tvrr222aas-msc-n-13.html
    IC9001 http://www.partsimple.com/tvrr214aas-msc-n-13.html
    IC9304 http://www.searspartsdirect.com/part...art=TVRR222AAS
    IC9001 http://www.searspartsdirect.com/part...art=TVRR214AAS
    • Unspun01
      • Jun 2011
      • 335
      Hi tw2005:
      Thank you for your quick reply, and a lot of useful information in your post - I never thought about ic9304 before.
      I decided to swap the ic9001 eeprom and ic9304 flash chips between my bad a-board, and one of the "scrap" a-boards just to do some troubleshooting.
      First I only swapped ic9001 between the two boards. Upon power up, BOTH boards displayed 1-blink error, so I wasn't sure what to make of it except that perhaps ic9001 and ic9304 must work together...
      So my next step was to swap ic9304 between the boards... Same result. 1-blink error on both boards.
      What other chip(s) would need to be swapped at the same time as part of the communication chain? It seems that swapping only the 2 chips has resulted in 1-blink error because of possible mismatch with other components?
      Let me know what you think. I'm anxious to see what discoveries we can make to assist others with this problem.
      Thanks.
      • ChicagoWilly
        • Jul 2013
        First, this is my first post. Hello, and thanks for the information I've read already.
        I have a 1 blink problem with a Panasonic TC-P42X1 that appears similar to the problem in this thread, so I hope it isn't considered a hijack.
        I can sometimes start the TV by pressing the power button for about three seconds and releasing. This appears to clear the SOS. It may take two or ten times, but the TV will eventually power on. The SOS can also be cleared by unplugging and holding the power button for three seconds. I'm sure most know that already.
        I have entered service mode and checked the service tool, and get OK for all parameters listed.
        I opened the set and using the Panasonic Technical Guide, verified the Standby Circuit Operation (STB5V seems OK). Following the Power On Operation, I hear the relays click on, and then the trouble begins. From the Guide, "The Panel CPU on the A board outputs the “PANEL_MAIN_ON” Command (3.2V) to pin 11 of connector P25 on the P board." The 3.2V will appear for a second, then drop out, and a few seconds later the relays drop out and the 1 blink code starts. Of course, when the 3.2V appears and holds, the TV will start and operate normally.
        So is it indeed a "communication error with IC9003" or something else? Is that a way of saying bad connection? I have removed the power board and looked for any obvious problems visually. I expected to find a fractured solder joint on a large component like a cap, due to vibration from the speakers, but it looked OK. The A board has few such components and I haven't removed it yet. Any ideas?
        Thanks in advance,
        Bill
        • tw2005
          • Oct 2011
          • 6458
          Originally posted by Unspun01
          Hi tw2005:
          Thanks.
          Well that ruins my theory a little. I thought along the same lines that maybe there'd be a checksum or something between the chips.
          Did you try with the original 9001 and swap just the 9304?
          Other than that I have no idea really, what I found was just by chance really.
          • ChicagoWilly
            • Jul 2013
            From the Technical Guide: "The CPU on the A board outputs the “TV_SUB_ON” Command (3.2V) and the PANEL_STB_ON” command (3.2V). The “TV_SUB_ON” command is provided to pin 6 of connector P7 of the power supply through pin 14 of connector A6 of the A board to develop the F_STB+15V. At this time the relays on the power supply are triggered and a “click” sound can be heard."
            I tried to jumper the TV_SUB_ON pin over to the PANEL_MAIN_ON pin on the P board to see if the loss of the 3.2V at that pin was causing the TV to shut down. It didn't work. The TV still may or may not remain on, and when it does not remain on I still get the 1 blink code.
            The manuals don't seem to fully explain what causes the 1 blink code, but I think there must be something other than a communication problem.
            One other thing I noticed is the power to the A board for the Sub-Voltages is on the high side. They are shown as 14.6V, which is rather specific, or 15V nominal, but I measure 15.5V at P6 pins 7,8,9.
            Any help on this would be appreciated.
            Bill
            • Unspun01
              • Jun 2011
              • 335
              Hi tw2005:
              I think swapping only ic9304 will be my next course of action.
              As I indicated:
              1) I first swapped only ic9001 between the 2 boards: 1 blink error on both boards.
              2) in addition to ic9001, I then swapped ic9304 between the 2 boards: 1 blink error on both boards. I did not try the original ic9001 and just swapping ic9304.
              I'll report back when I get the chance to test this.
              Thanks.
              • tw2005
                • Oct 2011
                • 6458
                Hi tw2005:
                As I indicated:
                Thanks.
                Yes it's an intersting fault which I'd love to see someone have a go at working out.
                In my case, unfortunately I could only prove the SOS 1 came across to the other board and IC9304 was part of that problem. I've stripped and damage to old board so I can't reverse what I did and to prove it was just that.
                • paul85
                  • Apr 2012
                  • 13
                  I can't find a reasonably priced A board to save my life. I have the dreaded 1 blink and from what I've read here and online, the A board is the culprit.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Tw2005 is correct. Its was an eeprom issue. . Sometimes this happens to these all in one a boards. My guess is some kind of static discharge or something like that.
                    • tw2005
                      • Oct 2011
                      • 6458
                      I am? So did you repair one of these ordering a replacement chip?
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        I tried a replacement eeprom from another a board. Cant remember exactly what model it was but I got a picture but it was all mal discharge looking. I gave u p and replaced the board
                        • tw2005
                          • Oct 2011
                          • 6458
                          Did you get a photo? I'd be interested since that's where I ended up with mine too. ordered the exact dead eeprom for my model too so a big waste of $$ except the learning that SOS1 is potentially a simple eeprom replacement.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            No never snapped a photo. Wish I did
                            • Jeff Pepin
                              • Jun 2014
                              • 103
                              • CANADA
                              #34
                              so .. in facts , for years , we search for an STB 5V SENSE TIME-OUT , but that seems to not have an STB 5V SENSE anywhere on our boards ,
                              the best similar thing i have found in the schematic is the pin 38 of IC1100 '' SUB 5V sense '' ?
                              or i have just not yet find him .. i will go check somes test point if i can help , i will do it
                              ''my setup is an TC-p42x1 With 1Blink SOS problem started after a brutal lost of electricity problem started occasionally then more and more frequent . now the set up just wont start anymore ,, only 1 blink sos ''
                              -possibly Switching transistor not working good
                              • Unspun01
                                • Jun 2011
                                • 335
                                Hi Everyone:
                                Sorry to resurrect this thread, but I promised to write back one day with my findings regarding my 50" Panasonic Plasma TV (TC-50PX24) with 1x blink code in case this information helps someone else.
                                I repaired my board by replacing IC9304 (an 8 pin FLASH chip) on the bottom of my A-board TNPH0831 (suffix AS).
                                RECAP DETAILS:
                                Original A-board TNPH0831 (suffix AS) had standby power but any attempt to turn on the TV would shut TV down with 1X blink code. Extensive troubleshooting did not yield an answer, so I was planning to replace the entire board.
                                My plasma model is not common and I could not find a suitable replacement, but the 720p panel in my TV (MC127H36U13) is also in 50" plasma model TC-P50C2 so I thought I could use an A-board from that TV and cope without having a VGA connector... I never ended up doing that but it might work if someone needed an alternative...
                                My fix: I bought a non-working TNPH0831 board (suffix AS) on eBay for $20. It had no power and would not turn on the TV at all. I found 56 pin IC8502 (ST M29W128GL) had an internal short which brought down the 3.3V standby supply and hence why the TV was completely dead. Knowing IC8502 was bad, I assumed the other ICs and EEPROMS may be ok. I desoldered IC9304 from both my original 1x blink board, and the defective replacement board.
                                After I swapped IC9304 from the eBay board into my original board and re-installed the board into my TV for testing, it turned on. SUCCESS. It works great.
                                If you can't get one from a spare board, you can buy it here:
                                I hope this helps anyone else troubleshooting a Panasonic Plasma with 1x blink code. And Thank you to TW2005 who first pointed me in the direction of IC9304.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Hi Everyone:
                                  RECAP DETAILS:
                                  Nce, every now and then we get lucky. i've fixed a couple of the 2010 series now with a reflash from a working board. Had one where I fixed it, then flashed the original file to break it again and then back to working for fun. Did a comparison from a dump and a single character or values was incorrect in the file.
                                  Best bit, the baords are not avaialble otherwise it was toast , but what a waste, nothing electrically wrong just crap data which cost me nothing to reload. Moved on now away from Plasmas, still have a couple of favourites tucked away
                                  • cloo
                                    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                    by cloo
                                    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                    After doing a factory reset this problem was gone and the picture was back to...
                                    01-06-2025, 06:02 AM
                                  • Vebririon
                                    panasonic TX-P50V10E 6 blink led problem
                                    by Vebririon
                                    I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                    Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                    I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                    05-17-2025, 10:16 AM
                                  • nervx
                                    Panasonic TH-42PZ800 8-blink error mystery
                                    by nervx
                                    Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                                    Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                                    04-08-2022, 05:19 AM
                                  • SentraDude
                                    (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                    by SentraDude
                                    Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                    I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                    Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                    04-04-2023, 04:24 PM
                                  • rmacintosh
                                    Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                    by rmacintosh
                                    I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                    The symptoms of the tv ar as follows:
                                    • Plug AC in to back of TV
                                    • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                    • The 3 blink code is given by the power LED
                                    • If the TV is unplugged and then
                                    03-14-2020, 12:24 AM
