Panasonic tc-p50c2 1 blink
  • freakaftr8
    • Oct 2012
    • 3743
    Hey all! New member here but been reading the forum for a long time.
    So I finally became a member.
    Well so I repair plasma and LCD TV's for fun. It's a fun challenge.
    So I picked up a blinker panny. This ones throwing me off. Apparantly it seems that all the parts on the Internet there seems to be scarce on the a board and I know something is amiss here. I get one blink. This is a communication error with the panel id ic9003. The output 5v and 15v off the regulator ic9801 drops off immediately after power up. I'm getting f15v from p board no problem and u have disconnected sc and ss boards and still 1 blink. Panny training manual says communication error with ic 9003. That makes me wonder if the ic itself is defective or some defective dc regulator.
    All ohms tests on the regulators seem ok.
    This board is Apparantly famous for causing a 10 blink code.
    Anyone care to chime in?
    Thanks and good to finally be a member.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Panasonic tc-p50c2 1 blink
    Btw pin 7 panel main on is 3.2 momentarily then goes away shutting down the ps. At this time +15vs and +15vc drops off at the same time panel_main_on falls. I'm hot on Vsus until the drop off from a board
    • freakaftr8
      • Oct 2012
      • 3743
      New update. All the sudden pin 7 stays hot and power light stats enabled but vsus drops off with 15vc. Led on mainboard a optical audio stays lit. But hard reset and back to the one flash.
      • freakaftr8
        • Oct 2012
        • 3743
        Once again I have to correct myself. Pin 7 for panel_main_on goes away at this time the a board decides to stay on. So pin 7 going low shuts down vsus to the drives. All dc voltages are briefly there on the a board to mpu 9003. Everything I can drum up points to a communication error with mpu9003. This is the ic that deciphers what's going on and off everything is in spec. It's a 100 pin ic. Could this ic just plain ol go bad? The odd thing is this ic throws the codes to the front led. So if its not communicationg why the heck can it display a one flash to the front panel led? Oh btw the only way to get anything else besides a one blink is pulling a7 connector. Then I get an 8 blink.
          Try this - it's not the exact training guide for your set, but may give you a starting point on the 1 blink code:
          1 blink also has "No particular check point" which could be tricky I guess!
          • freakaftr8
            • Oct 2012
            • 3743
            Ok so here's the most obvious of what's going on. And thank you Tom66 for the guide. F+15v stable throughout power up. Even in SOS mode. But p15vc and p15vs off power supply momentArly comes up upon startup then immediately drops off.
              Check the power on signal from DA to P.
              • freakaftr8
                • Oct 2012
                • 3743
                Panel main on pin 7 is 3.2v upon startup. Then drops off before relay click and SOS pattern.
                  I would suspect the DA then.
                  But maybe it's sensing a short somewhere or it does have a comms problem.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    I went ahead and thought heck I got nothing to lose. So I jumpered f15v to +15vs/vc on p board. No change.
                    Panel_main_on still drops off. That almost eliminates p board from the equation. Also disconnected sc and ss. Still one blink
                      I think the comms error is where to look - maybe one mcu is not starting, check crystal and LDOs (never seen a panny with a bad one on here though), check reset controller etc.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Put some extensive testing into the a board last night. Voltages to all ldo's and ic's. but the ic9003 is sensing something shutting down p15v and the voltages to the top regulators
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Ok so I went all out. Jumpered f15v to p15vc and then it veld 15vcc at sustains. Then jumpered panel -main-on to a solid source and got vsus. Connected sustains and no pic not even any light. That bypasses ic9003. So something else is amiss on the board.
                          I would just replace the board but this is fun and also the boar is made from a rare earth deposit called obuntanium.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Ok, Joker. Am I getting this right??
                            obtainium
                            any item, found or obtained for free
                              obtainium
                              Unobtanium = a rare construction that no one seems to be able to acquire or sell, despite being made of otherwise obtainable parts.
                              • tw2005
                                • Oct 2011
                                • 6458
                                Damn, looks like i need a new dictionary or go back to a new age school.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Haha. Yes that it.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    So has anyone ever found a solution to this a board issue yet?
                                    Of course in short of just replacing it. Is it possible for ic9003 to go bad? Considering the fault is stb 5v sense and or ic9003 panel ic communication error. All voltages come up then drop briefly from 15vs and 15vc. F_15 stay up as well as 5v and from what I can tell all regulators are doing thier job.
                                    • Unspun01
                                      • Jun 2011
                                      • 341
                                      Hey freakaftr8: sorry to post so long afterwards, but did you ever find a problem to his issue? I have a 50" TC-50PX24 with 1 blink code. All other boards are good, and all voltages come up, but after a few seconds, always reverts to 1-blink.
                                      I have 2 scrap TNPH0831 "A-boards" from a TC-P42U2 and a TC-P50U2. Connections to panel are different, but they are good to test the Power board. Both let P-board TURN ON AND STAY ON. All voltages look good.
                                      The problem must be the A-board. But what is the problem?
                                      On the scrap boards, I measure 5V, 3.3V, 1.8V, 1.2V at the regulators... By comparison, on my TV's actual A-board, all of these voltages come up momentarily until the TV shuts down.
                                      Resistance and continuity measurements seem consistent between all 3 boards so I don't see any problems in the voltage regulation circuits. Although the 1.8V regulator circuit seems to measure very low resistance across a diode on ALL 3 boards...
                                      Therefore I treated this as a "communication error with IC9003" problem.
                                      However, when testing, I discovered something neat. On the scrap boards that actually turn on the power supply, during startup if I temporarily short pins5-6 (SDA and SCL) of the EEPROM IC9001 which interfaces with pins 7-8 of IC9003, then I can force a 1-blink code on each of the "scrap" boards. This has the effect of blocking communication because data cannot be read or transmitted from the EEPROM. This tells me that there is a communication error between the EEPROM and IC9003. But what is wrong? IC9003, or the EEPROM?
                                      I used a hot-air rework station and swapped the IC9003 (MNZSFH8K) from one of the scrap boards to my non-working one. The result? the scrap board works with the swapped IC9003, but the actual A-board from my TV still has 1-blink error code... Therefore I can rule out the IC9003 as being bad...
                                      What could be the issue? Does anyone else have any ideas?
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        probably EEPROMs?
                                        I recently made an accidental discovery with an A board conversion. The board TNPH0840 is a close relative of the 0831, same geneartion of TVs. It had SOS1.
                                        Mine is a P42X20A which has all the same boards as the P42C2 except the A-board.
                                        Here's my post. https://www.badcaps.net/forum/showthread.php?t=30054
                                        Basically I swapped all the EEPROMs and FLASH memory to turn a 50" new Zealand board to a 42" Aust.
                                        The SOS1 transferred across to the donor board.
                                        Turned out to be IC9304 (TVRR577) ADDR/DATA , FLASH I/F to the PD4 PDP control IC.
                                        It seems you have already proven a bad EEPROM can cause SOS1 by shutting down IC9001. Up to you where you start IC9001 or IC9304 but it was the latter in my case.
                                        IC9304 and the other 8pin EEPROMs are easy to work with, just watch out for very small SMD parts mounted close to some of these. I had a near disaster when I discovered a tiny SMD resistor stuck to my tip, very lucky I spotted it. It came from where i had just removed one of the EEPROMs.
                                        The scrap boards you are using are FHD models I believe but for the sake of fault finding you could start with swapping one of those EEPROMs across.
                                        Probably won't be much good for driving a HD panel but could help you advance your fault finding.
                                        I also had a scrap 42" FHD board, I'm pretty sure it booted up with that one and the 50" HD IC9304.
                                        When i did mine I taped the ICs to a sheet of cardboard and wrote down the model board and location next to each chip I had removed so I did not get them muddled up because you'll never work out which is which from their external appearance.
                                        For my testing i disconnected the 3 ribbons at the A and also disconnected everything/all power from the SN(SC), SS, and C boards.
                                        The A board will bootup and switch on the PSU with no SOS if it's fixed but I think you may have already worked this out.
                                        From what I've seen these are listed as available as spares. I know the US equivalent chip for mine was only $8 at SEARS, CCE?
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • nervx
                                          Panasonic TH-42PZ800 8-blink error mystery
                                          by nervx
                                          Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                                          Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                                          04-08-2022, 05:19 AM
                                        • SentraDude
                                          (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                          by SentraDude
                                          Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                          I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                          Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                          04-04-2023, 04:24 PM
                                        • rmacintosh
                                          Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                          by rmacintosh
                                          I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                          The symptoms of the tv ar as follows:
                                          • Plug AC in to back of TV
                                          • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                          • The 3 blink code is given by the power LED
                                          • If the TV is unplugged and then
                                          03-14-2020, 12:24 AM
