Dynex dx-22ld150a11 LCD TV No Power Dead
  • arman960
    • Sep 2012
    • 129
    totally dead. When I push the power button ,nothing happens. No light. No sign of power.
    I checked the fuse on power board. Fuse is ok. I checked the resistance of the transformer pins S1 & S2 =972 Ohm
    S3 & S4 =972 Ohm
    Whoever replies thanks for that.
    Re: Dynex dx-22ld150a11 LCD TV No Power Dead
    Do you have about 165vdc on that large brown cap?
    Any 5vstby?
    Also good pictures of this power supply/inverter board both sides and also good closed up in 1/4 section each so I can trace the copper tracks
    • arman960
      • Sep 2012
      • 129
      Any 5vstby?
      I get 172.4 VDC from that big brown caps.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        That is good. Infact, your line voltage seems a bit high. But it's not dangerously so.
        Does the white transformer make a ticking sound when you try to turn it on?
        Muh-soggy-knee
        • arman960
          • Sep 2012
          • 129
          There is no sound or clicking noise. No LED anywhere. when I push the power button, nothing happens.
          This main board is connected to DVD player. This TV basically has powerboard integrated with Inverter and main board. Basically two boards and dvd player
            As you can see in picture #3 in your post #1, see if the you have 5V on that pin (pin #3 from the right).
            • arman960
              • Sep 2012
              • 129
              There is no 5 volts or 12 volts. The unit is dead.
              It has one section primary and other section secondary.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                The smps IC is an SG6742MR
                Check the voltage:
                1. From GND to pin 4 (Vstart)
                2. From GND to pin 6 (VDD)
                Please report back your findings.
                Muh-soggy-knee
                • arman960
                  • Sep 2012
                  • 129
                  Check the voltage:
                  GND to PIN 4 = 8.2 VDC
                  do you think the IC is bad?
                  GND to PIN 6 = 0 VDC
                  • lti
                    • May 2011
                    • 2551
                    VDD is pin 7, not pin 6.
                    The voltage on pin 4 seems low. I would check the components connected to pin 4 and the resistance from pin 4 to ground, but someone else might have a better idea.
                    • arman960
                      • Sep 2012
                      • 129
                      I get 0 vdc from 6 and 7 pins.
                        When HV is applied to pin 4, the DC voltage at pin7 VDD should start rising, when it reaches the VDD-ON (15.5V), the Gate drive signal will appear at pin8 Gate drive to drive the MOSFET, when the drive happens the DC will be generate by the rectifier diode that is connected to the Aux winding of the standby switching transformer which will keep itself running and the IC will no longer use the HV voltage. Since pin4 is reading only about 8V, that will not be enough to start up the IC. If you look at the app note, the circuits used in your TV will be really close to what is shown.
                        So take the resistance reading at pin4 as suggested by lti, also take the resistance reading at pin 7 also. Check the resistor and cap that supplies the power to pin4 also.
                        • arman960
                          • Sep 2012
                          • 129
                          I do not have Multimeter to measure capacitance. So I just use multimeter's Mega Ohm to see if the capacitor charging or not. But I can check those capacitor and ressitors that supplies power to pin 4.
                          when you said to measure resistance at pin 4 and 7, did you mean resistance between pin GND and pin 4?
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Sorry about the pin messup.
                            I think, the chip could be bad - but first you should measure the resistance of pin 7 (from pin 7 to ground). Make sure the board is unplugged and the giant filter capacitor is discharged first!
                            Muh-soggy-knee
                              Sorry for not being clear:
                              4 and Gnd, 7 and Gnd.
                              Does the app notes circuit match pretty close to your board?
                              • arman960
                                • Sep 2012
                                • 129
                                Yes the circuit close to the IC looks like this. But I am not good at reading the trace circuit diagram though. The pictures are in Primary power supply section
                                The resistance between 4 and GND is open
                                resistance between 7 and GND is only 3.5 Ohm
                                is this normal?
                                  That is NOT normal at all on pin7. You will have to carefully unsolder and lift pin7, then take the reading again.
                                  Can you take good clear pictures of the board in the IC area so I can see how the traces are connected? Pin 7 looks like it is connected to a jumper wire.
                                  • arman960
                                    • Sep 2012
                                    • 129
                                    Here is the picture of top bottom and lower section of the board
                                      OK, much better pictures with less reflection.
                                      Correction! I look real close at the picture, pin 7 is connected to J7 jumper, and it is ALSO connected to C104 to ground and also ZD101 to ground.
                                      So best thing to do is to lift pin 7 off the board.
                                      So the short can be the IC, C104, or ZD101.
                                      • arman960
                                        • Sep 2012
                                        • 129
                                        Ok removed the J7 jumper and than measured the resistance.
                                        GND and pin 4= open or very high resistance (above 2M Ohm)
                                        GND and 7= 3.5 Ohm
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
