Westinghouse LD-4655VX - My First LED
+ More Options
Posts
  • asdfasdfasdf
    • 6
    • united states
    #61
    Re: Westinghouse LD-4655VX - My First LED
    arent these worth up to 150? Do you think I could get 100 for it?
      I don't think you'd get as much as that for it.
      • Eclectic
        • Feb 2013
        I have the same tv. It just went out right after the 1 year manufacture warranty. I opened up the back panel and didn't see any thing burned out or became loose,but still wiggle a few spots here and there. Then the TV came back to live. I let stay on for about 2hours, it went out again. I am assuming its the FFC problem that posted by braveally. I'm going open it up again and check the LED cables very carefully. Thanks for the post.
        • Tomcat25
          • Feb 2013
          • Usa
          #64
          Does anyone know where to get a replacement LED strip for this TV. I had the same issues and repaired it to a certain extent but manages to break off the cable locking tab in the process. I can't find any LED strips online. Maybe someone has some insight.
          • DakotaKid
            • Nov 2010
            • 165
            #65
            PM me. I have some LED strips removed from another TV. I was going to use them in a project but if they are what you need we can certainly work something out.
            DK
            • ilgen
              • Mar 2013
              This is the best info ever. I took the panel off and removed the LED strip. Unraveled the ribbon wire and put tape between the ribbon and the metal on the LED strip. The ribbon wire has cut through and shorted out on the LED strips. I would suggest you do this to both while you have it apart. Works great now. You guys are the best!!!!!!!!! I wish I could tell everyone that has this problem....
              • mnilsen
                • Mar 2013
                http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1102wt_1120
                LED went out on me today, currently only have full brightness on one side of the screen after removing the bad cable. Contacted the ebay seller and he was nice enough to create a new ebay posting. There are 9 more cables available that should solve the problem.
                Tv was never dropped or handled roughly so it must be due to bad parts, the cable was frayed and resting directly on a sharp aluminum edge. Hopefully I'll be able to pull the cable around the back instead of attempting to lift up the lcd display itself.
                Apparently this happens a lot to this model and I don't think I'll be purchasing another westinghouse anytime soon.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Protect the new cable with some thick electrical tape, or something similar, to prevent this from possibly happening again...
                  Muh-soggy-knee
                  • markhod
                    • Nov 2011
                    #69
                    do you have any of the light bars
                    • n24our
                      • Mar 2013
                      I had the EXACT same problem with my TV. Electrical tape around the ribbon fixed it. "Thank you" to everyone who posted on this tread.
                      • inothome
                        • Apr 2013
                        Excellent! I had someone bring me this TV, DOA. Found a burned up MOSFET "Q27" on the main board. Upon replacement you can hear the power supply cycle on and off, with the right side LED ribbon disconnected it would power up. Half screen dim of course. Did a search, found this thread, put some tape on the frame of the LED strip where the ribbon cable rubs and TV is now fully functional! Thanks guys!!
                        Not 100% sure if this is what caused the MOSFET to fail in the first place, or having the TV apart and moving it caused the ribbon cable to wear and short out. Regardless, it's working. When I received the TV the red light would light, but nothing else. After Q27 replacement it wouldn't do anything, but cycle the power supply, unless the right LED ribbon was unplugged.
                        • kev1n69
                          et1984
                          • Jul 2012
                          • 13
                          • usa
                          #72
                          yes shorted cable causes q27 to get hot and burn up eventualy
                          • Bholt77
                            • May 2013
                            • Usa
                            #73
                            Thank you to all that contributed to this thread. Was about to buy a replacement board because i could not power on my tv but came across this thread. Disconnected the left ribbon cable and it powered on. I took the entire tv apart and put electrical tape around both cables and the power came on with both LED strips on.
                            Unfortunately, after I completely reassembled the tv only the left side LED strip is turning on now. I'm not sure if I accidentally disconnected the ribbon during reassembly or what but I am thinking I have to completely tear it down again.
                            • kevinm34232
                              • May 2012
                              • 1884
                              It's very delicate and the ribbon may be damaged.
                              • Bholt77
                                • May 2013
                                • Usa
                                #75
                                Took it apart again and the little extra bulk from the electric tape caused the ribbon cable to be pulled out when putting the black plastic covering over the LED lamps. I cut out a portion of the black plastic covering where the cable connected and this fixed my problem. Tv working perfectly again! Thank you all again!
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have just picked up one of these for $40 and I have fixed it already.
                                  Thank you for pointing out where the problem is.
                                  I think that I may have found the real problem. The two ribbon cables at the LED strips wrap around the LED's aluminum strip and the ribbons short out right there.
                                  I have applied some tape under the ribbon cables and the TV runs perfectly.
                                  Remove only the bottom black plastic from under the panel, no need to take the whole screen apart. The metal clamps have to be removed also, because the panel has to be lifted a bit to remove that black plastic piece.
                                  Nice easy fix, using a bit of tape
                                    Darn, why do they keep making badly designed products like this TV?
                                      Because they break down and people have to buy a new one?
                                      The main reason is the brand "Westinghouse" is just a name that buys in cheap TVs made in China, that company behind the name will ditch the brand when customers lose all respect for it and go onto the next until that one is worthless, they repeat this for great success causing so many TVs to end up in landfill.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Maybe they are thinking about us too.
                                        When I flipped the ribbon over, I have noticed the two side traces had black spots on them.
                                        Most likely the insulation got cut through by the sharp aluminum strip.
                                        I don't understand why they had to wrap the whole LED assembly with the ribbon cable?
                                        I have never picked up Westinghouse, I try to deal with good brands, but I will have to look for these, because they are very new TVs and it's a very simple fix.
                                          Yes, perhaps I should not complain about the amount of waste due to faulty electronics, after all, it lets me get cheap stuff and fix it.
                                          But I should complain! Maybe it won't affect me so much but what about my children? And their children? The future will be screwed if we don't act responsibly now.
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • Shinju
                                            Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                            by Shinju
                                            Hey All!
                                            Long time forum member here with a problematic laptop issue!
                                            I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                            The laptop would not power on with the new battery installed without the power supply being plugged in.
                                            When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                            TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                            10-20-2021, 04:58 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • karatzdi
                                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                            by karatzdi
                                            I know some might say... just buy another one. Sell it as parts..!
                                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                            Spent some time downloading the Service...
                                            06-11-2024, 08:38 AM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
