Vizio L32 HDTV 10a No power, no standby LEd Nothing.
  • Ziggazam
    • Sep 2012
    • 22
    I am Currently working on a Vizio HDTV that isn't giving me any sort of response. when plugged in. I have no Lights for standby or any form of sound or anything from the set. It seems to not be getting any power. I am assuming that It is the power supply, But I Need to be sure. All other connections and boards look normal. Does anyone have any insight on what This Could be. I Have provided a Picture of the Supply board to the Vizio.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio L32 HDTV 10a No power, no standby LEd Nothing.
    1) Do you get 5V standby on the power board?
    2) If yes, then check your voltage regulators on the main board as per my sig file below.
    --- begin sig file ---
    --- end sig file ---
    • drpj23
      • May 2012
      • 528
      If #1 is no, is the main AC line fuse OK?
      • Ziggazam
        • Sep 2012
        • 22
        The main fuse is ok . I tested it first.
        • Ziggazam
          • Sep 2012
          • 22
          the Power cord also is fine I tested two power cords & it actually uses the same voltage power cord as a Xbox 360 power supply. and it powers normal and there are no shorts or misses in the cable.
            Have you tested the 5V standby? If you post a closer shot of the connectors going from the power supply to the main board (which has HDMI etc on it) we can highlight the places to test. If there is a legend such as 5VSB next to a pin, that probably is the 5V standby voltage.
              Check these pins on the connector: or post the closed up pictures of your connectors.
              My board may not be the same as yours.
              http://s807.photobucket.com/albums/y...t=DSC00335.jpg
              • Ziggazam
                • Sep 2012
                • 22
                close up of some connectors
                  Can you get a pic of the others? You could also just list them on the forum and we can tell you which to test.
                  • Ziggazam
                    • Sep 2012
                    • 22
                    More photos
                      Can you get a pic of the other connectors - the ones at the top of the PSU.
                        OK, put the black meter probe of the DC Volt meter to the metal chassis, the Red probe on the terminal that is labeled with '5V' and see if you do have that standby 5V coming out.
                        Please also take CLEAR AND FOCUSED pictures of the connectors front view so we can read all the lables on the connectors.
                        • Ziggazam
                          • Sep 2012
                          • 22
                          The other photos
                            Do you get the 5v on the connector? How about the pictures of th 3 DC output connectors?
                            • Ziggazam
                              • Sep 2012
                              • 22
                              one more, much better photo
                                Thanks, that is much better. So check that 5v OUTPUT.
                                • Ziggazam
                                  • Sep 2012
                                  • 22
                                  I checked that 5v output And it not giving me anything. Over 000.0 on the multimeter that was dc
                                    OK, so the PSU is dead. There is a white ceramic fuse here. With the power to the board unplugged (very important) test the resistance across it - should be close to zero ohms.
                                    • blazer
                                      • Sep 2014
                                      so pls what is the next step after this ?
                                        @blazer, so you also do not have 5V STANDBY either? Fuse is good? if so, then with just the power supply by itself, check and see if you do have about 160~170VDC RIGHT AT THE TWO LEGS OF THE MAIN FILTER cap (the big cap with 450VDC rating).
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
