Vizio VM60P HDTV10A No signs of life except speaker pop when unplugged
  • vinceroger69
    • Mar 2012
    • 6714
    #81
    Re: Vizio VM60P HDTV10A No signs of life except speaker pop when unplugged
    in post 65 you mentioned mosfet testing so i sent you that link but when i just re read the whole posts and googled the number it says k2865 is a transistor not sure why it passed the mosfet test though. whats the part number on the long ic thats blown as these power supplies seem very expesive.
    have you tested the k2865 out of circuit also has your new resistor now gone open circuit as well?
    • heavymachines
      • Mar 2011
      • 1028
      weird but new resister still test 10 ohms, my gut tells me there is a prob elsewhere, the number on long ic is kia339p the longer ic is l4981a. yeah there not cheap found one for 60 somthin hope he takes the offer.
      • heavymachines
        • Mar 2011
        • 1028
        will have to retest the transistor however when it fried it took a few things with it a resistor for sure and not sure bout those ic's and the diode's are suspect as well it smells fried sky high.
        • vinceroger69
          • Mar 2012
          • 6714
          #84
          the kia339p is quiet cheap http://www.ebay.co.uk/itm/KIA339P-Ma...item19d16f259b
          but the problem is what else has gone wrong
          • cheebster
            • May 2008
            • 373
            #85
            hi there. just a little input on this..
            here's the pdf for the datasheet of this ic :
            https://cdn.badcaps-static.com/pdfs/...3af77752b5.pdf
            and here's a replacement that seems to be fine in stock at digikey.. cross refs as a
            http://www.digikey.com/scripts/dksea...LM339N&stock=1
            lm339n or others.. see link
            http://www.allxref.com/kec/kia339p.htm
            have a nice one
              LM339 is nearly indestructible as far as ICs go. It is just an analog comparator.
              • heavymachines
                • Mar 2011
                • 1028
                well i darn thing went to pcb heaven the resistor was definitely part of the prob but there was more bad components in store for me and it went poof could be cause of that transistor which i thought was a mosfet, i gave the part number to verify and well it was verified too late as a transistor. well the internet sucks cause i put that part number in and the doofy thing said mosfet, later, oleboy said its a transistor LOL. blah now there are several fried components its like bah just replace the pos, and go from there, now what i am afraid to death of is there something on the other supply that is bad that can cause a repeat of this frying venture? i have no real way of telling and when it comes down to components well i am a greenhorn, rookie, however you like to word it, and yes i have fixed displays but that's because they already figured it out for me or because i just replaced what i knew was the offending board. only one time did i manage to figure out on my own was a pos hanns g 22" and i figured out it had bad bulbs did that with no help at all but that's one time. this thing has 3 power boards and i know for sure the lower one is shot and stinks now lol, not fantastic on identifying components nor reading schematics again a greenhorn LOL. now caps and some resistors i can test fine however resistor with color bands, transistor, mosfets ,hybrid i am lost, however i can follow instruction with some good illustration,but if i throw a part number out and call it a mosfet PLEASE correct me before i misdiagnose the darn thing lol ,well resistor fixed part of it but now there is a bigger prob then i started with shoot.
                  Hmm, I am pretty sure your line filter is OK, and it cannot damage the other two.
                  Your second lower board is only converting the 115V/230V rectified DC into approx 400V for the rest of the TV. A failure here would damage the lower board, but would be very unlikely to take out the top board; it'd blow the fuse first.
                  It's only really when you get to plasma sustains and buffers that one board can damage others.
                  • heavymachines
                    • Mar 2011
                    • 1028
                    so you don't think there is anything in the upper power board that can damage the lower power board? where it fried is right by that plug coming from the upper power board.
                      I think at worst it would blow the fuse. You should be able to check the lower board without the upper board connected; the TV should stay in standby, and pressing the power button (might) make the relays click. That's as far as it would go. I say it might click the relays because they could be controlled from the bigger board.
                      • heavymachines
                        • Mar 2011
                        • 1028
                        well the power button is connected directly to the mainboard, when i connected it after putting in that resistor in i only hooked up those three power boards and left everything else disconnected and was about to test for standby voltages and before that could happen there was a flash and smoke within 10 seconds after connecting power. kinda glad i did it that way cause it could have taken more with it. only way that power button gonna work if i connect the mainboard, but i want to check everything before i do that to prevent what happened today it going up in smoke. in theory there should be standby voltage present for the mainboard to tell it to fully power on. look at that manual in the beginning of the thread there it will tell you the block diagram on page 6-1. take a look at it, it does not show every connection but it gives you a good idea on my layout.
                          My instructions only apply when the lower board is functional.
                          • heavymachines
                            • Mar 2011
                            • 1028
                            there has to be a way to test the upper board for shorts so i don't cook the new board when i put it in cause i doubt the guy is gonna refund me for a fried power board, but yeah this time i will test with just the line filter and the lower, and be scared as hell to connect the upper power board.
                              You can check the MOSFETs on it all for short circuits. You can simply test from source to drain, that is adequate for 99% of all MOSFETs.
                              • heavymachines
                                • Mar 2011
                                • 1028
                                also looking at this thing both mainboard and upper power board must be connected in order to get relay clicks cause #1 power button is directly connected to the mainboard, #2 there is a 2 er 3 small wire plug that runs from the upper power board to the filterboard right next to the relays, #3 the heavy wire plugs run from the filter board to the lower then from lower to upper.
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  then there is a bunch of small wire plugs conjoining the lower and upper in unison.
                                    In which case you should still get standby power even if it won't go further than that. It could possibly be an idea to test with a new lower board, and same upper board, but without main power connector plugged into the upper board.
                                    That way you'd still get relay clicks, but there's much more limited potential for damage as the rest is low voltage, low current.
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      perhaps i drew this out to give u a good idea how i think it works please correct me, and yes i think that may be a good idea.
                                        I think you've got it nailed. The red/blue connector going from the small board to the larger one (not the line filter) should be OK to disconnect and try the TV without temporarily when the lower board is replaced/repaired.
                                        • heavymachines
                                          • Mar 2011
                                          • 1028
                                          so just leave the high voltage disconnected from lower to upper and the low voltage connected, that may work, just leave the one high voltage from the filter to the lower connected.
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • howardc64
                                            Vizio SmartCast TV software bug that looks like hardware
                                            by howardc64
                                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                            11-16-2024, 05:17 PM
