How to test a DLP Ballast
  • electronicsurplus
    • Jun 2012
    • 210
    Does anyone know how to check a ballast in a DLP or Inverter in a LCD?
    Is this even possible?
    What would I use to test the output? I have High Voltage Probe. The type we used to use to test old Flybacks in CRT
    Can anyone help shed some light on this?
    Since, currently, the only way we can test is to install in a known working television to verify.
    But, I am sure there must be some way to drive the Ballast or Inverter to test it's output and functionality
    I am sure this will help a lot of people
    Jon
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: How to test a DLP Ballast
    Moved out of a FAQ thread.
    It wasn't even on topic man... Unless you are a veteran member posting a legitimate and often asked for "How-to Guide" thread, Don't post in the FAQ.
    sigpic
    (Insert witty quote here)
      Use an LCR meter and measure inductance if you like, but the simplest test should be for continuity - it should be a short at DC.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        I dont think I have seen more than 3 posts re DLP Tvs on here. I did find a partial test for Ballast but nothing on testing the output. The input from the power supply should be in the region of 350-400vdc
        Pull the lamp housing
        Tie the door switch up to the closed position
        Turn on the TV
        All Fans should run, Color wheel should spin listen or shine a flashlight in the lamp side window to verify
        Watch at the left back side of the Ballast board for the starter to flash it will cycle flash three times
        Pull power cord from back of TV to shut off or it will continue to try the three attempt cycle.
        Regarding Inverter transformers other than spare bulbs or
        a tester (which is just a bulb) there doesnt seem to be
        a measurable output test.We tend to try and measure primary and secondary windings and check the input voltage.
          Most DLP lamps are around 20 to 50V, I thought... Maybe more for more recent ones?
          • electronicsurplus
            • Jun 2012
            • 210
            Thank you
            tom66 and selldoor for the input
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
            • khelane
              test active pfc power with lamp test
              by khelane
              Hello
              I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
              Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
              Is there a way...
              06-03-2025, 01:00 AM
            • chronic519
              Mats / mods: detected and repaired GPU fault. Cant seem to test after!
              by chronic519
              Hello.
              GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
              Found issue with a RAM block
              Replaced, green lines gone.
              Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
              Used a good card to test and same results low errors 32+.
              I am just search for some form of command to do a full test on the GPU.
              I just ran the mats command with my good GPU and passed after roughly 40 min.
              The repaired one, ran...
              05-20-2025, 07:56 PM
            • alltvrepairs
              Lg TCon test pins for screen test
              by alltvrepairs
              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
              Appreciate your help....
              06-13-2025, 06:33 AM
            • vampy999
              how to test lcd inverter transformer
              by vampy999
              i found this very helpful.
              https://jestineyong.com/test-lcd-inverter-transformer/
              02-28-2021, 07:52 PM
