Symptoms=
Red led when plugged into wall
Steady green flashing led when power button is pushed
Steady green flashing led stays after pushing power button to turn off
Visual inspection=
found 2 slightly puffed caps on power supply & heat signs around transformer.
Replaced the 2 caps,symptoms did not change.
I tested for shorts on all large mosfets and bridge rectifier(none found)
Tested for shorts on 4 large diodes (none found)
Tested the 4 rectifiers and all 4 test for a short,But looking at how there in circuit, that could be the way they would test in circuit, but im not sure on that.
I also hunted for a fuse but cannot find one.
I tested for voltages on pins going to main board and to inverter
found 5v on two pins going to main board
(actual voltages on my pics)
Do you guys think the two pins going to the main board that i found 5v on are standby for the main board and a signal voltage coming back from the main board to tell power supply to turn on??
Should i replace the rest of the caps on the power supply??
Should i pull the 4 rectifiers out of circuit to test??(I can post pic of how there in circuit if needed)
I dont know how to test the transformer.
Any help on what i should test next would greatly be apprecieted!!!
Visual inspection=
