I recently got a Samsung LN32C530 from a friend because it did not turn on. When it is plugged in the standby light turns on, but when you hit the power button it just blinks 4 or 5 times and then turns off. The person who had it before me thought it was the capacitors so they replaced those and I thought it was the main board, but after replacing that the tv will still not turn on. I have attached pictures and would appreciate any help given.
Samsung LN32C530 will not turn on. Standby light just blinks
Re: Samsung LN32C530 will not turn on. Standby light just blinks
The capacitors that were used as replacements appear to be general purpose, and are completely insufficient for the application they are used in.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Panasonic FC, FM and FR are commonly suggested around here and can be acquired from Digi-Key for about $10 total. The question is - did the person replace all caps correctly, so are the specifications (uF and voltage) correct? You cannot be certain...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
No I can't say. I found the schematic for the board so I'll verify that the capacitors match that. Are those capacitors something that I can go to Radio Shack or somewhere to get or would I have to get them online?Comment
That looks like where your friend got those from. Go to DigiKey if you need help post back here. Make sure about the size, diameter and height it looks pretty crowded on the board.Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
Looks like Digikey has a better supply of FM's. Get the uf and voltage along with sizes and you want radial type caps. Try this URL:
http://www.digikey.com/product-searc...c%20Fm&stock=1
You should be able to get what you need. Get shipping by First Class Mail it will get there in 2-3 daysHave you ever stopped to think and then forget to start thinking again?
Ok sounds good. Thanks for all of your helpLooks like Digikey has a better supply of FM's. Get the uf and voltage along with sizes and you want radial type caps. Try this URL:
You should be able to get what you need. Get shipping by First Class Mail it will get there in 2-3 daysComment
So I replaced the capacitors with capacitors that matched the specifications off the schematic for the board and i am still getting the same issue. Any other ideas on what could be wrong?
ThanksComment
What happen if you disconnect the cables to the Inverter board? By the way, does it make that Samsung start up tone?Last edited by budm; 08-21-2012, 09:55 PM.Never stop learning
Sorry for the late reply. If I disconnect the inverter board the screen turns on and the Samsung start up sound does not happen when I attempt to turn it on.Comment
That usually indicates a problem with the main board but pictures are really not good enough for troubleshooting j- they should be a s clear as these
Examples of what is needed
https://www.badcaps.net/forum/attach...1&d=1290283049
https://www.badcaps.net/forum/attach...7&d=1280167246Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Are these pictures clear enough? I believe it is a problem with the Main Board also, but I can't narrow down the issue. I have already bought a new main board, but it is possible the new one has the same issue.Attached Filesif you find these attachements useful please consider making a small donation to the site
Check all regulators... https://www.badcaps.net/forum/showthread.php?t=22232Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I checked the regulators and they all seem to be working fine. These are the results I got.Check all regulators... https://www.badcaps.net/forum/showthread.php?t=22232
1117z right
pin 1 - 0
pin 2 - 1.26
pin 3 - 3.39
1117z left
pin 1 - 0.64
pin 2 - 1.9
pin 3 - 3.3
7805
pin 1 - 12.3
pin 2 - 0.01
pin 3 - 5.07
950T45
pin 1 - 3.4
pin 2 - 0.01
pin 3 - 2.5Comment
I have the exact same issue, with pretty much the same specs.I checked the regulators and they all seem to be working fine. These are the results I got.
1117z right
pin 1 - 0
pin 2 - 1.26
pin 3 - 3.39
1117z left
pin 1 - 0.64
pin 2 - 1.9
pin 3 - 3.3
7805
pin 1 - 12.3
pin 2 - 0.01
pin 3 - 5.07
950T45
pin 1 - 3.4
pin 2 - 0.01
pin 3 - 2.5
Any advice would be much appreciated.
I know there is a firmware update, but i can't apply it because i can't turn the TV on. I'm also not convinced it would do anything.Comment
I have researched this issue on the model extensively. The problem is almost always the Main PCB. So much so it is very difficult to find any supplier that has a new, refurbished, or even a used one.
Does anyone know of a shop that you can send these to for repair?Comment
by JackchingI know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
What I already found is that the 12.8V are not an the connector to the main board connector to the power... -
by Kaar3lTV: Samsung QLED QE65Q7FNAT
PSU: BN4400940A
MB: BN94-12832K
I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r... -
by NicktronicHey Everyone,
So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...03-27-2023, 07:01 PM -
by SJX1290I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
My main suspect is bad flash memory, ...
Any suggestions or can someone please check dump file, in the attachment
Thank you... - Loading...
