Neon C3298DVB stuck in standby
  • sienoki
    sienoki
    • Jan 2012
    • 314
    #41
    Re: Neon C3298DVB stuck in standby
    Originally posted by sienoki
    A pic ok underside psu
    Heres 1 with wires attached..not sure which 1s 2 put a jumper on..thx
    • sienoki
      sienoki
      • Jan 2012
      • 314
      #42
      I took a reading on the big cap & got 230 on the ac/dc meter & 0 when switched off..the big heat shield also measured that?..is it supposed 2 measure that..thx
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        #43
        primary side heatsinks will normally be at line voltage so 230v will be on the heatsink,but your large filter cap should be around 320-340v if the pfc front end is working when tv is powerd on.
        disconnect main board,jumper 5v to on/off pin,do other voltages come up?,the 12v to main board,and 24v to inverter?something i think on the main board is putting the psu in to protection.
        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        • sienoki
          sienoki
          • Jan 2012
          • 314
          #44
          I jumpered the 5v from the stnby pin to on/off pin & still no other voltages..i will get some pics off main board both sides when ive some time off work..thx
          • sienoki
            sienoki
            • Jan 2012
            • 314
            #45
            I jumped them pins with nowt connected 2 mainboard & 12v/24v appeared..sorry 4 not doing correct 1st time..some pics of mainboard..if you need underside let me know..theres no smd devices on the underside..thx
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              #46
              check the fuse ive marked in red,this problem is either a corrupt new eeprom flash that you put in,or the crystal to the cpu has failed or the cpu has failed both of these are under the large sheild ,your power supply seems fine.
              check that fuse
              if fuse good,take resistance reading on the connector pins of the mainboard(the one where the power comes from the psu),just the ones that are marked with a voltage,the readings should be very high resistance,if they are low ie about 30 ish ohms,then it points to a short on that rail which will need investigating.
              if all good then you will need to take off that large sheild and look up the datasheet for the cpu ic,confirm what the voltage into the cpu is and what pin it is,and then test that pin to see if the correct voltage is there,if you dont have a scope then you wont be able to test the crystal,it should show a steady sine wave on a scope.
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                #47
                also,now you have everything disconnected,plug connectors in one at a time,whilst jumping 5v to on,and monitor the voltages if they dissapear again then what ever you plugged in may have a short on it,im positive more or less its the main board though
                • sienoki
                  sienoki
                  • Jan 2012
                  • 314
                  #48
                  Fuse tested ok..do i black probe screw chassis n red probe power i pins on mainboard on continuity setting?
                  Took the shield off & cant seem to find any info on the ic..thx
                  • multimeter
                    • Jan 2011
                    • 739
                    • united kingdom
                    #49
                    for dc voltage testing with power on,dc setting 20v 0n multimeter,black on chassis screw,red on individual out pins on connector.
                    for resistance /fuse testing power off,either on 200 ohm range or diode test function for continuity.
                    you will need to remove the heat sink on the cpu chip,should just twist off gently,you will need to get some thermal bonding glue to put back on ,both surfaces must be spotless and dry,use isopropynal alcohol.
                    the ic will have its part number under the heatsink.
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      #50
                      on u6 the flash chip you replaced,did you not use flux(no clean)?,those pins look a bit shaky,id have a check for continuity on each pin,find a nearby solder pad that connects to each pin and check they have continuity,do for every pin.pin 7 dosent look like its on its pad properly,or its the picture,not sure.
                      • sienoki
                        sienoki
                        • Jan 2012
                        • 314
                        #51
                        Hey up fella..thx again for sticking by me..with the jumper pin in place & everything connected up & switched on i get
                        5.09v
                        5.09v
                        5.09v
                        5.09v
                        12.07v
                        12.07v
                        on the main power pins from the mainboard
                        I used non clean flux for the eeprom..i looked over chip with jewellers eye n they look fine..it looks better under scope..gonna do them other readings now..thx
                        • sienoki
                          sienoki
                          • Jan 2012
                          • 314
                          #52
                          5.09v
                          5.09v
                          5.09v
                          5.09v
                          12.07v
                          12.07v
                          Cant get that heat sink off its stuck solid
                          • sienoki
                            sienoki
                            • Jan 2012
                            • 314
                            #53
                            I dont think this board is repairable & it dont look like theres 1 about at the moment..the screen is a samsung LTA320AP02..will this screen be compatible with most 32" lcds?
                              Only with TVs using Samsung panels.
                              • sienoki
                                sienoki
                                • Jan 2012
                                • 314
                                #55
                                Got the heatsink off
                                MSD106CL-LF-Z1
                                A6MFN29J
                                0933B
                                • multimeter
                                  • Jan 2011
                                  • 739
                                  • united kingdom
                                  #56
                                  MSD106CL-LF-Z1
                                  A6MFN29J
                                  0933B
                                  ok,cant find any info on this chip no datasheet,would have been good to find VCC to at least see if the chip is getting its voltage,if you have a scope ,we could see if the crystal is working,it should show a stable sine wave.very rare these fail though.
                                  there are a couple of voltage regulators on this board,prefixed "bm" you could check those and see if they are working,but if they work through the main cpu they may not activate until the cpu sends the correct signal.
                                  the voltages you had taken are correct and within spec,you can rule out the psu.
                                  hopefullly someone might pipe in and show a link to a datasheet for the chip.but i cant find one.
                                  if no joy i would keep an eye out for a mainboard on ebay or elsewhere you may get lucky
                                  • multimeter
                                    • Jan 2011
                                    • 739
                                    • united kingdom
                                    #57
                                    by the way did you follow the steps in post#46 about resistance testing on the disconnected main board?if you havent...
                                    set your meter to 20k,black probe to chassis screw,red probe to each individual line voltage pin (no need to do the ground pins),coming into the main board from the psu,the readings should be very high resistance anything around 30ohms indicates a short on that rail.
                                    the main board has a short somewhere that is shutting the psu down,confirmed by jumping the pins as you did with nothing connected,if you find the rail thats shorted,you can trace along and check components along the trace thats affected,(leakseeker would be good for this)
                                    • sienoki
                                      sienoki
                                      • Jan 2012
                                      • 314
                                      #58
                                      Took 20k setting readings on the power in pins & the 2 5vins pins were a reading of 0.28..the others were high..this was done with nothing plugged into the mainboard nothing jumpered & not switched on..thx
                                      • sienoki
                                        sienoki
                                        • Jan 2012
                                        • 314
                                        #59
                                        Took readings of the vdo,s in pic 3 post45 the 1s closest to the power pins & only got the correct voltages with the jumper in..so can i rule them 4 vdos out?
                                        All the vdos give correct voltages with only the jumper pin inplace
                                        • sienoki
                                          sienoki
                                          • Jan 2012
                                          • 314
                                          #60
                                          So could the fault perhaps be something with the 2 5vins with only having 0.28..so something on them rails?https://www.badcaps.net/forum/attach...6&d=1345298168
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • Rusenga
                                            Samsung UA39EH5003R Stuck on standby
                                            by Rusenga
                                            Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                            Connector CNM803:
                                            TV ON
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                            TV OFF
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                            09-18-2021, 11:51 AM
