Neon C3298DVB stuck in standby
  • flocko
    • Nov 2012
    • 1121
    • uk
    #81
    Re: Neon C3298DVB stuck in standby
    Forgot to say i think this is just a rebadge of the Neon C3298DVB But this has the Megmeet mlt666T power board every thing else is the same. Tom, Multimeter, Ohm, i need your help please to sort this Thanks
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      #82
      what is the main board part number? CV106 ETC?
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • flocko
        • Nov 2012
        • 1121
        • uk
        #83
        Sorry should have put that in CV109H V2.1 Thanks Multimeter I have to pop out for a bit but will be back soon Flocko
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          #84
          the part you need is this one
          http://www.chsinteractive.co.uk/elec...x32vs-neon.htm
          bit cheaper than the c24 series ,still pricy though
          • flocko
            • Nov 2012
            • 1121
            • uk
            #85
            Thanks multimeter have you used these before and do they work? i did message Ohm about it but still waiting for reply.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              #86
              no i havent used them,i prefer to re-program my own chips,.
              i always replace the chip with a new one ,some you cant re-write beacause of the write protect pin,but most programmers can override this problem anyhow.
              always weary about pre-programmed chips some turn up blank possibly due to ESD handling etc .always use a ESD safe iron and ground strap on your wrist when installing them,they are quite sensitive to ESD
              • flocko
                • Nov 2012
                • 1121
                • uk
                #87
                I dont have ESD safe iron and ground strap, you must know whats coming next where are you as you sound like the man for the job,if i get the part and send the board would you do the repair i will pay you for your time. Flocko
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  #88
                  can you post up a pic of the main board first?,just so i can see and look for anything obvious i.e fuses etc
                  also to do a check to ground resistance readings of the voltage rails for shorts
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    #89
                    Will do
                    • OHM SUPPLIES
                      • Feb 2013
                      • 7
                      I've replied to your message.
                      regards
                      Andy
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        #91
                        photo of CV109H V2.1 have checked fuse and am now checking voltage rails will tell you if i find anything
                        • multimeter
                          • Jan 2011
                          • 739
                          • united kingdom
                          #92
                          where is the location of the flash chip?,it should be marked winbond 24c****,cant quite see properly in the pic,and should be a sot-8 package 8pin chip
                          • flocko
                            • Nov 2012
                            • 1121
                            • uk
                            #93
                            would think U6 bottom right corner of the card slot has green line on it,have run the meter over the power in rails on 200ohm all reading OL thats 12v/5v/24v/ inverter on and adj
                            • OHM SUPPLIES
                              • Feb 2013
                              • 7
                              You can electrically erase and program this read only memory, However eeprom is a very general term that doesn't really fit this ic. It's normally referred to as the eeprom as it's dos the job that a “normal” (24 x xx eeprom would do) also there are several eeproms on the board each doing their own job. If you call it the SPI flash, its correct but you start getting bogged down in terminology Please follow the link which explains a bit better:
                              http://www.atmel.com/products/memories/serial/spi.aspx
                              The file in U7 contains a program but also stores the channels etc.
                              On the 24X xx eeproms, although shorting can bring the set round, also fitting a blank, you can get other faults such as HDPC fail and a preprogramed ic will solve this.
                              The ic's are also not £17.00 each
                              Regards
                              Andy
                              • OHM SUPPLIES
                                • Feb 2013
                                • 7
                                Oops,
                                Not great with forms
                                regards
                                Andy
                                • flocko
                                  • Nov 2012
                                  • 1121
                                  • uk
                                  #96
                                  Hi Andy your message did not get though to my mail box
                                  • multimeter
                                    • Jan 2011
                                    • 739
                                    • united kingdom
                                    #97
                                    great,so we know there is no shorted rails on the main board,and the fuses confirm good on the main board.
                                    andy is right in saying there are eeproms on the board,what you need to do is to search all the 8 pin sot-8 chips via there data sheets on the net,the one you want will be the SPI flash chip,this one creates the standby fault your having,and stores the program for switching in/out of standby and some other things.
                                    when you find what "u"reference it is designated on the board we can go from there.
                                    the chip is normally very close to the card reader slot going by the 24" neon model.
                                    andy,cant remember what site i seen the chip on ,but it was def £17 + postage for the 24" version which is crazy for what it takes to program these chips if you have the programmer.
                                    floco,do you have a scope?,it will verify if the chip is functioning ,you should see a sine wave on the pins data/clock etc.
                                    also have a check to see if there is an input voltage going to the chip on the V-IN PIN if its there then it will be the faulty chip,if it isnt then there is another problem
                                    • flocko
                                      • Nov 2012
                                      • 1121
                                      • uk
                                      #98
                                      Hi I think Andy will confirm it is the u6 chip, Its in his add for the standby repair on CV109H V2.1. Sorry no scope,and the board is out of the set and on my desk can i not just check with a meter to see if the v-in pin has a supply< what pin and voltage am i looking for, all this with ESD if my iron is earthed and i am earthed even if i had to do the soldering in my pants would you not think that would be Ok. Sorry if that though put you of your tea, anyway back to you Flocko
                                      • OHM SUPPLIES
                                        • Feb 2013
                                        • 7
                                        Yes sorry, my mistake.
                                        CV109H CHASSIS,
                                        The spi flash/ eeprom CCT REF:
                                        V1.2 = U7
                                        V2.0 = u6
                                        V2.1 = U6
                                        V3.0 = U25
                                        regards
                                        Andy
                                        • multimeter
                                          • Jan 2011
                                          • 739
                                          • united kingdom
                                          #100
                                          you can get a ESD strap for a couple of quid .
                                          you will need to check V-IN with the main board connected ,tv plugged in ,and with standby led on.
                                          what is the part number of u6 ?
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • Rusenga
                                            Samsung UA39EH5003R Stuck on standby
                                            by Rusenga
                                            Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                            Connector CNM803:
                                            TV ON
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                            TV OFF
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                            09-18-2021, 11:51 AM
                                          • Ukdigger
                                            Samsung UE46f5000AK Stuck on Standby
                                            by Ukdigger
                                            When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                            PSU number bn44-00610A L46SF_dpn
                                            1 B13v 12.4
                                            3 B13v 12.4
                                            5 Vamp 12.4
                                            7 Vamp 12.4
                                            9 GND...
                                            08-08-2024, 09:17 AM
