Neon C3298DVB stuck in standby
    Hi guys n gals..been a while since last on site..ive bought this set cheap hoping for just bad caps..upon inspection alls good inside..the psu is giving the correct voltages so started searching on net for info.
    This brand of tv is also made by CELLO..after much searching there seems to be many known cases of the eprom being corrupt.
    The main board is BOARD No: CV109H V2.1 & the eprom is IC REF: U6...25X32VSIG..0932
    I have no knowledge or equipment in programming & flashing etc..i was hoping it was just caps that need replacing..so im hoping you guys might point me in the right direction..thx
    Re: Neon C3298DVB stuck in standby
    What is the model of the main board?
    Have you tried the pin 5/6 shorting trick which works on Samsung TVs?
      Hi tom thx for reply..the main board model is mentioned in my post fella..never done a eprom short before..is there an easy way of doing this..thx
        just use a watch flat screwdriver,short the pins together ,then power on the tv, pull the screwdriver out ,i think ive got the BIN file for cello tvs somewhere if you get a programmer
        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
          I have a little board I made up for programming EEPROMs (uses a PICkit 2) - so if you need a programmed EEPROM (SMD or through hole), let me know. Multimeter, do mind sending me that .BIN; I could upload it?
            yeah no worries,its on my computer,il dig for it,and send it on pm if you want
              tom send me yr email addy,found it
                My camera is playing up & i cant take a decent pic of the chip..im not sure which is pin 5/6 sorry..& tom if i muck this up could i get a reprogramed 1 off you plz..thx
                  on the eeprom chip you will see a hollow dot on it,count the pins around anti clockwise until you get to pins 5 and 6 (where the dot is thats pin 1)
                    Thx multimeter..located the 2 pins put small flat srewdriver on both & switched on at switch at the side waited 2secs & still same..is this a matter of trying longer or this cant be done..thx
                      no,you done it right,on these eeproms there storage is very weak,any little power outage/surge will corrupt the eeprom,it will proberly be a case of re/writing the eeprom,you can get the blank 24c/25c winbond eeproms fairly easily,they normally have SIG written on there part number.
                        and one thing,some watch screwdrivers have a black coating on them,make sure that you use one with a clean bare metal blade or it wont make the correct contact with pins 5/6
                          Thx fella thought 2secs was enough after doing a little research..im hoping maybe on the remote there is service menu to bring out of standby..the pioneer i bought was done that way but im having no joy finding the sequence
                            When you going 2 uni fella?..where will i get 1 of these chips from?..& could you program it 4 me..thx
                              not sure on the service menu there can be lots of different codes and orders that have to be enterd.
                              im sure there is a service code but i dont know that one sorry,someone may pick up on this thread and chime in hopefully.
                                http://www.ebay.co.uk/sch/i.html?_tr...2VSIG&_sacat=0
                                  If it's one of those, I can't program it, sorry. That's a flash chip - not an EEPROM.
                                    Thx 4 link mucka..didnt think it be that simple 2 look on ebay..doh..sun stroke i think..im gonna google my head off & see if theres a sequence out there..maybe if i get in contact with cello they may provide but i doubt it..thx for help guys
                                      How much would i be looking at from a shop 2 do it?..ive 20quid in it so far
                                        I have no idea where you could get that done, sorry.
