Philips 42PFL7403D Doesnt turn on
  • pacmyc
    • Aug 2012
    • 41
    • Sweden
    Philips LCD 42 inch TV (42PFL7403D/10)
    Chassis Q529 1E LA.
    TV only power on sometimes. I cant find any bad caps on the power supply.
    When TV is connected to mains moste of the time nothing happens. When pressing buttons on remote control the red led on the front side flashes shortly once each time i press a button.
    I checked the voltages on the PSU, and I got nothing except on the standby 3.3V. It was "flashing" (cheap multimeter) between 3.06 V - 3.25 V (service manual says should be 3.3 V). When pressing a button on the remote control the standby voltage drops to about 2,6 V for about a second, and then goes back to 3.06 - 3.25 V.
    The TV seems to start fine in the morning but not in the evening!?
    Also when I disconnect TV from mains I get a small chock if I touch the power cable withing 10 seconds.
    The PSU has number 310432852762.
    I cant attach servicemanual due to too large filesize, but it's downloadable from here http://elektrotanya.com/philips_chas.../download.html
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Philips 42PFL7403D Doesnt turn on
    Chassis Q529 1E LA.
    You get a shock from the cable? dam! thats VERY dangerous!
    I think there must be something VERY wrong with the PFC circuits on your PSU!
    pics?
    Muh-soggy-knee
    • pacmyc
      • Aug 2012
      • 41
      • Sweden
      pics?
      Well, I survived
      See attached pics.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Couple of things - Transformer top left in pic one looks cracked in half - is it loose?
        Id change the 3 small caps in the primary(hot) section 2 blue and one green
        one is likely to be the startup cap. If it is the one between the heatsinks it will be well cooked.
        • pacmyc
          • Aug 2012
          • 41
          • Sweden
          Allright, you mean these right?
          Well, if you think it's worth a try I'll do it.
          What about the pending (jumping) standby voltage (3.1V-3.2V) ?
          • pacmyc
            • Aug 2012
            • 41
            • Sweden
            When replacing cap 2105 the service manual say says in the
            print 47 uF 50V, but in the replace part list it says 22uF 50V, and
            the old cap is a 100 uF 25 V!
            Is it OK to replace a 100uF 25V with a 47 uF 50 V?
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              If the cap you are replacing looks like an original factory fitted then you should fit the same. If not it is than a bit of a problem. Could anyone have messed with it?
              It is usually possible to go to a step higher uf and a step higher voltage without ill effects but never go lower on uf or voltage.
              I"s it OK to replace a 100uF 25V with a 47 uF 50 V? " - No
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Well, If it is in the startup circuit, then a larger cap will make it take much longer to turn on.
                I'd check for voltage on that big black capacitor in the middle. It should be about 165v (cap is rated for 200v)
                Muh-soggy-knee
                • pacmyc
                  • Aug 2012
                  • 41
                  • Sweden
                  The transformer seems fine. Not loose at all.
                  I have now replaced the three caps as you suggested, problem remain.
                  • pacmyc
                    • Aug 2012
                    • 41
                    • Sweden
                    OK. How do you suggest that I measure it?
                    Should I solder a cable under the backside of the PSU on the + side of the cap and measure voltage to ground while trying to start the TV ?
                    • pacmyc
                      • Aug 2012
                      • 41
                      • Sweden
                      OK, thanks for quick answer.
                      Yes it really looked like a factory fit, it was also of the same brand as other caps on the board. Finnaly I found a cap with the same F and V and replaced it. However still the same problem.
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        Hmm! careful high voltage Ben7 have you remembered that OP is in Stockholm mains voltage is 230VAC - cant get my brain around why cap is only 200.
                        OP - was this an import from US does it run on a voltage adapter?
                        • pacmyc
                          • Aug 2012
                          • 41
                          • Sweden
                          No it's sold in Sweden. It's rated 220-240 V 50-60 Hz.
                          In the service manual it also says 200 V on this cap.
                          • pacmyc
                            • Aug 2012
                            • 41
                            • Sweden
                            Also, I forgot to tell in the first post. I get some voltage on the PSON on the PSU (It's pendnig quickly (flashing on my cheap digital multimeter) between 0.8 - 2.5 V.. (Connector 1M95)
                            And also about 0.3 V on BL-ON (connector 1M99)
                            Also, I cant hear any relea switching when mains are connected (neither when the TV is working nor its not)
                            • pacmyc
                              • Aug 2012
                              • 41
                              • Sweden
                              Update: Sometimes when I connect the powercord to the TV the red led on the front flashes twice. According to the sm this is a SSB error. I will try to get the set in SDM mode to get the layer2 fault-code.
                              • pacmyc
                                • Aug 2012
                                • 41
                                • Sweden
                                When cable on connector 1M95 id disconnected I get 3.4 steady voltage on 3v3 standby out from PSU. Also the 12 V supplies goes up for half a second, then they are shut down. Standby voltage remains.
                                • pacmyc
                                  • Aug 2012
                                  • 41
                                  • Sweden
                                  Re: Philips 42PFL7403D Doesnt turn on, breakthrough or not!??
                                  UPDATE:
                                  PSU starts up just fine if I just disconnect the LED panel control from the SSB. (connector 1M20 on picture).
                                  Stable 3.4 V (standby 3V3) and stable 12V. After about 10 seconds PSU shuts down the 12 V but continoes to deliver standby 3.4 V.
                                  How is this possible? Could there be a short some where in the led panel control?
                                  Attached schematics for led panel control + pics.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    UPDATE:
                                    Yes there has been a one found in that last few days cant remember if it was a short or an open but totally messed with the whole tv.
                                    I think it was in desperation that he/she ohmed out the led cable and found it.
                                    • pacmyc
                                      • Aug 2012
                                      • 41
                                      • Sweden
                                      So I guess I can now rule out that it is PSU / and or SSB that is not working right?
                                      Is there anything I can do with the led panel control to fix it (its 2 layers, and damn small components) or should I start asking around for a replacement board?
                                      • pacmyc
                                        • Aug 2012
                                        • 41
                                        • Sweden
                                        Just got the TV working!
                                        I connect the mains with the led panel control disconnected.
                                        Then I slowly press down the cable into the connector, and there it goes, starts working. TV is on, everything works great.. But if i turn it off I'll have to disconnect the led panel control to get the TV on again.. :S
                                        • JorKsX
                                          Philips 47pfl6008s wont turn on
                                          by JorKsX
                                          Hello. Got my hands on Philips 47pfl6008s/12.
                                          Problem is that it does not turn on. Last owner said the problem came slowly.
                                          One day did not respond to remote, had to unplug from AC and then back and it worked. next day had to disconnect 3-4 times before it turned on.
                                          And then it went into hours of unplugging and replugging until it turned on.
                                          When I plug AC into tv, it does not respond to "turn on" button or anything else.
                                          After 10-15minutes the TV starts blinking red LED twice.
                                          So it blinks twice, then waits 3 seconds, then again twice...
                                          02-13-2022, 03:36 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • ovrax
                                          Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                          by ovrax
                                          First of all, please excuse me as I'm quite new to this field.
                                          I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                          I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                          The Ambilight works perfectly and stays on.
                                          No sounds.
                                          Thanks in advance.
                                          08-25-2024, 04:33 AM
                                        • Henke
                                          Philips 55POS9002/12 shorted mains
                                          by Henke
                                          Hi.
                                          I have a Philips tv where the two main fuses are blown. I found a bad cap. I removed it, and now it seems to work. But i have to replace the cap. I do not have the exact same one at home. What's the purpose for it and what values can i use instead?
                                          Its placed across the Drain and Source on a N/Channel MOS
                                          The blown one is 101K, 1KV (check picture). I have 221K, 1KV at home, can i use that?...
                                          08-06-2024, 03:51 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
