Philips 52PFL5704D/F7 Sound and Backlight, No Video.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Philips 52PFL5704D/F7 Sound and Backlight, No Video.
    Mine doesn't show anything on the screen, just backlight.
    When it worked correctly for a couple of hours, first showed the Philips logo.
    So, with mine could be the mainboard?
    • kevinm34232
      • May 2012
      • 1884
      Yours is doing the same as mine did, it was the T-Con board that would not display Philips logo or a picture and on screen menu, etc., not the main board.. Are you getting the 12v at the t-con fuse?
      There has been a lot of T-con board issues posted online with this model and turns out to be a hard to find board..
      • tibimakai
        • Jan 2012
        • 3680
        I haven't tested yet anything, because yesterday I thought that I fixed it and then late in the night the screen went black again.
        I will measure it today and I will let you know.
        • tibimakai
          • Jan 2012
          • 3680
          I have 12V(11.96V) before and after both fuses.
          • kevinm34232
            • May 2012
            • 1884
            Are you getting anything at IC201, you should have 3.3v on top pin and 2.5v on bottom. I think when I had the blank screen with old board, I wasn't getting those voltages but fuse was good.
            • tibimakai
              • Jan 2012
              • 3680
              I have forgot to measure those voltages. Tomorrow.
              I have measured yesterday and today again, just to be sure and something it's weird with the PS_ON.
              When it's off it measures 3.4V and when it's on it measures only, 0.0042V.
              What's up with that?
              The stand by voltage is 3.4V on this TV?
              3.4VSB is the standby? What is 12VSSB?
              Picture made with my phone.
                Looks like active low PS-ON, that is fine. Some PSUs, especially Samsung, are like that.
                12VSSB is for 12V for Small Signal Board, i.e. main board.
                Perhaps it failed due to the fuse being underrated?
                • tibimakai
                  • Jan 2012
                  • 3680
                  My fuses are OK. That's what is weird.
                  So basically when I got it it showed as right now only backlight.
                  I have opened it and noticed that both panel ribbons were not in there correct position. I have reinstalled them correctly and the TV run beautifully for hours.
                  Then I turned it off to insert the USB stick with the updated firmware and the video signal it was gone, only audio it was on.
                  How come it run perfectly and then when I turned it off and then on the video it was gone? Maybe then something went bad?
                  I have tried heating the board, nothing happened.
                    Maybe updated firmware broke it?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I was thinking about that too, but it didn't have enough time to run through the firmware, it didn't have any image when I have turned it on.
                      When it fully turned on I could hear the movie that it was running previously, so it wasn't doing the update.
                      Do you think that I should stick the USB stick again and let it run for a while?
                        You have a scope, so post a picture of the LVDS connector on the T-con side and I'll show you where to probe to see if you are getting any differential TX signals for the high speed video (here is where 100 MHz is necessary), that way, you can either eliminate the main board or t-con.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Here is shopjimmy's picture.
                          Kevin, I have just remembered that I have checked the IC201 voltages yesterday and they were all 0V.
                            OK which end does video come in? That looks like a dual link (two video streams) T-con.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Both cables are hooked up to the main board. Not sure what are you asking. The right one goes to the main IC on the main board and the left one goes to a bunch of SMD components.
                                Which end does the main board connect to on the T-con. I'm not sure which end drives the LCD and which end receives the video from the main board.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Here is shopjimmy's picture:
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Tom, I haven't given up on that Sharp TV, I will send you that picture with the scope.
                                    Now this Philips TV takes the whole space on my workbench and I can't work on that one.
                                    How nice it would be if we could help each other through Skype.
                                      Sorry I'm lost. Which side of the T-con is connected to the main board.... I don't have the time for skype sorry, I am only doing this in my work breaks.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Both
                                          TOP or BOTTOM? I need to know where the video comes in from the main board to tell you where to probe...!
                                          • Max514
                                            Samsung UN55H8000 sound but no backlight no video
                                            by Max514
                                            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                            • Unplugging the main board cable at the power supply >>> backlights came on.
                                            • BLU_ON signal from the
                                            04-14-2022, 10:34 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • bohaboha
                                            PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                                            by bohaboha
                                            when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                                            Do I disconnect the plug from the power supply, no backlight
                                            Thought the backlight would light up when you remove the plug from the power supply but no
                                            What could be wrong if both halves work separately?​...
                                            03-07-2025, 09:45 AM
                                          • gl4709
                                            Samsung un55cu7000d with backlight and sound No Video / Picture
                                            by gl4709
                                            I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                            01-23-2025, 06:21 PM
