Philips 52PFL5704D/F7 Sound and Backlight, No Video.
  • ahardb0dy
    • Jan 2015
    • 24
    Re: Philips 52PFL5704D/F7 Sound and Backlight, No Video.
    Cleaned the ends of the ribbon cables and the sockets and picture is the same.
    • ahardb0dy
      • Jan 2015
      • 24
      Tv picture looks like this:
      • ahardb0dy
        • Jan 2015
        • 24
        Should I post my own thread on this?
        Any idea's on how the picture is? Would this still be the T-con causing this?
        • ahardb0dy
          • Jan 2015
          • 24
          anyone?
          • dcaron614
            • Apr 2014
            • 30
            • US
            #165
            Thanks to this post my 52pfl5704d/f7 ... just went out on me. I was watching the Tv went to the bathroom came back TV was sound no picture. When rebooting the TV it gave me the vertical line colors but only for top portion of the screen.
            I took the T-con board off and cleaned with 91% alcohol with very soft toothbrush the entire board gently front and back and ribbon cables both and both ends let dry and also peeled that plastic off that was on the top part of the pads before I reinstalled T-con and shield and TV works fine now.... fingers crossed on how long it will last
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8324
              err
              • jheinz
                • Dec 2011
                #167
                has anyone figured out how the voltages get from the fuse to the regulator ic201
                if I have 12v on both sides of the fuse - but 0volts on all pins of ic201 -I lifted the pins and still no voltages, does anyone have the schematics for this t-con?
                after the fuse on the way to ic201 there has to be a diode, ic, or transistor.
                  Any good clear pictures of YOUR T-CON board?
                  • jheinz
                    • Dec 2011
                    #169
                    if i have 12v on both sides of the fuse - but 0volts on all pins of ic201 -i lifted the pins and still no voltages, does anyone have the schematics for this t-con?
                    After the fuse on the way to ic201 there has to be a diode, ic, or transistor.
                      That is one expensive T-CON:
                      http://www.shopjimmy.com/sharp-cpwbx...-con-board.htm
                      Do you also get the 12VDC on the positive legs of those two electrolytic caps next to the fuse? Or on other electrolytics caps on that board.
                      What is the P/N of that IC201?
                      Pictures provided by SHOPJIMMY.
                      • jheinz
                        • Dec 2011
                        #171
                        The capacitors have 12v and also the coil marked in red - no where else
                        IC201 part # 25ka5
                          That inductor and the other 3 smaller inductors (with 10 nad 22 on top) are for the switching power supplies.
                          There is IC under that grey square next to those two caps is probably the SMPS IC. You need to see if you can get the P/N to look up the specsheet for it.
                          • dennis6790
                            • Feb 2016
                            • canada
                            #173
                            This is a complete list of components that are included in a repair kit sold by someone on eBay. For people that can source the components, they could probably beat the $30+$10shipping (usd) cost. Just thought I'd help other people that have been having trouble getting this expensive t-con board.
                            For the Philips 52PFL5704D/F7 Repair kit
                            T-con board RUNTK4107TPZA CPWBX4107TPZA CPWBX4107TP RUNTK4107TP
                            Please refer to the pictures.
                            • jackal68
                              • Mar 2014
                              • 91
                              Does it anyone have any updates on how to repair the no voltage in the ic201? I have 12v on both sides of the fuse as well as voltages on the 2 caps closest to the fuse, BUT no voltage in all the rest of the caps.
                              Any suggestions as to where I can check?
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                #175
                                You will have to run the traces back from ic201 with meter in diode beep mode till you find problem
                                • jackal68
                                  • Mar 2014
                                  • 91
                                  I took off ic201 and the pads are not shorted.
                                  I'm wondering if anyone has any input as there is a ic on the backside that control the power (ic200, part number THINE THV3056). Shop jimmy is selling a repair kit that has this ic, plus ic201 and the fuse.
                                  Could this be the solution?
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    #177
                                    Check pin 63 on ic200 for voltage.
                                    • jackal68
                                      • Mar 2014
                                      • 91
                                      with the tv on, I have 11.9v on pin63. I also get 11.9v on pins 62 and 64.
                                      • jackal68
                                        • Mar 2014
                                        • 91
                                        So I took the chance that the tcon would repair this tv that I picked up for free. i got the tcon and installed it but now I have an issue with the screen where the left side of the screen does not display properly. I am wondering if it is a bad connection to the cable or do you think the panel is gone? I have played around with the cable connection to the tcon but it doesn't seem to do much.
                                        Any ideas?
                                        http://i4.photobucket.com/albums/y14...ps8y1d75nd.jpg
                                        • jayPare
                                          • Jun 2017
                                          Any ideas?
                                          Got the same thing! I ordered a T-CON board on Ebay and replaced it but now I have no screen at all! Tried to put back the old T-CON board, still the same, no image. Also, sometime, the TV click, backlight up then goes off two time. Some other time, it goes on then off then on again and stays on. Can anyone help?
                                          • Max514
                                            Samsung UN55H8000 sound but no backlight no video
                                            by Max514
                                            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                            • Unplugging the main board cable at the power supply >>> backlights came on.
                                            • BLU_ON signal from the
                                            04-14-2022, 10:34 AM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • bohaboha
                                            PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                                            by bohaboha
                                            when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                                            Do I disconnect the plug from the power supply, no backlight
                                            Thought the backlight would light up when you remove the plug from the power supply but no
                                            What could be wrong if both halves work separately?​...
                                            03-07-2025, 09:45 AM
                                          • gl4709
                                            Samsung un55cu7000d with backlight and sound No Video / Picture
                                            by gl4709
                                            I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                            01-23-2025, 06:21 PM
