Philips 52PFL5704D/F7 Sound and Backlight, No Video.
  • jayPare
    • Jun 2017
    Re: Philips 52PFL5704D/F7 Sound and Backlight, No Video.
    From the kit posted, they changed the cap rating to higher voltage. Therefore, I wanted to go ahead and replace them in addition to the fuse.
    I looked at the OEM capacitor and they seemed to be Panasonic SVPD (page 45). So I checked their footprint and ordered something similar:
    22uF, 25V x9
    33uF, 25V x2
    I also ordered the voltage regulator.
    I'll keep you posted with the results.
    • jayPare
      • Jun 2017
      The only thing I could be missing is the IC in this kit:
      https://www.shopjimmy.com/sharp-cpwb...repair-kit.htm
      I'm not able to identify it...
      Anyone?
      • webpanther
        • Jul 2016
        Clean the back side of the T-CON where the white thermal pad is and replace the thermal pad with a new one or a similar one scavenged from other TVs.
        • R_J
          • Jun 2012
          • 9633
          IC200 could be a THine THV3056
          • drp146
            • Dec 2014
            I know this is an old thread, but I'm trying to repair this same T-Con board. I was wondering if anyone knew if there would be a problem replacing the electrolytic capacitors with MLCC?
            • drp146
              • Dec 2014
              Just in case anyone finds themselves here needing to fix this tv by repairing or replacing the T-Con board, I wanted to leave the info that the original RUNTK 4107TP ZA Board can be replaced with the much easier to find and much cheaper Sharp RUNTK 4323TP ZZ. I have confirmed that this $40 dollar board is a compatible direct replacement. Connections are identical. I have also found out that the ZZ on the end of the number is important on this series of boards. They make this with other Z something endings on the number. Any other than ZZ may not work.
              • Max514
                Samsung UN55H8000 sound but no backlight no video
                by Max514
                Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                • Unplugging the main board cable at the power supply >>> backlights came on.
                • BLU_ON signal from the
                04-14-2022, 10:34 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • bohaboha
                PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                by bohaboha
                when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                Do I disconnect the plug from the power supply, no backlight
                Thought the backlight would light up when you remove the plug from the power supply but no
                What could be wrong if both halves work separately?​...
                03-07-2025, 09:45 AM
              • gl4709
                Samsung un55cu7000d with backlight and sound No Video / Picture
                by gl4709
                I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                01-23-2025, 06:21 PM
