Re: 32" Dynex DXL3210A Won't Power On
I have the same model and it does a very similar thing. Yellow standby light--> turn on and it turns Blue ---> TV turns on for 2 minutes then turns off and speakers make a popping sound. BUT the light is still blue. If I click to turn off the light goes back to the yellow standby and I can repeat the same process over and over. Any ideas?
My model is a Dynex DX-L321-10A. Im disapointed and relieved at the same time. I will have to start a new thread. I was going mad looking for the components that matched the pictures in this thread and it dawned on me. One Digit off.Leave a comment:
Ok I will stop by my local radio shack and get one. Then I will open it back up and resume. Is it okay to work in this thread or should I open a new one?Leave a comment:
Quote:
Originally Posted by karkass View Post
Mine does not even power on. It used to shut off after ten minutes. I had it apart and was looking for bad capacitors. They looked fine. I don't have testing equipment and shamefully I do not know where the fuses are located. Looking around on the web it looked like a common defect and this thread was the closest to figuring it
Without one there is little we can do to help cheap one is less than US$6?Leave a comment:
Ok, do you have a multimeter though?Mine does not even power on. It used to shut off after ten minutes. I had it apart and was looking for bad capacitors. They looked fine. I don't have testing equipment and shamefully I do not know where the fuses are located. Looking around on the web it looked like a common defect and this thread was the closest to figuring it out.Leave a comment:
You have the exact same symptoms? B/c we couldn't figure out how to fix it, we just suspected the video processing chip was bad.
But, might aswell open it up, and test voltages, and fuses!Leave a comment:
I have the same model and problem. I however am not Savy enough to diagnose. I can follow a walkthrough to fix if anyone can find one.Leave a comment:
Well just put it on CL and i have an offer of 60$. Looks like i wont be working on this anymore
It can be real difficult some time to troubleshoot the problem without the service manual and the diagrams, good to take a break from it for now. May be I will run into one at the recycle place, then I will post back.Leave a comment:
Thanks for all the help though! It was a good learning experience.
We'll be back trying to fix it gain then, in a few weeks.
You could wait a while and see if elecronicsurplus finds a fix.Leave a comment:
Just checked them, they seem to be fine. Well, I'm giving up on this one. I'm gonna put it up for sale online for someone else who might have better luck.Leave a comment:
Looking at the Hotter caps pic reminded me -did you check the little orange zener diodesLeave a comment:
They will say something like
470
10v
CZ
One line will be the capacitance, one the voltage rating, and one the series (or date code)
That only applies for the ones on your board, in the provided pictures.
Some have the voltage and capacitance in one line, like "220A" which means 220uF, at 10v (the A = 10v)
However, those were only for one particular mfg, each one seems to have different marking styles
SMD capacitors are the problem when measuring with my meter.
How do read capacitance from the labels on the smd caps?Leave a comment:
Well, I measured the 3 caps 1000uf 35V out of circuit, and all have ESR of 0.04 ohms or less, 989.5uf, 1002 uf, and 1034 ufLeave a comment:
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by SkishyIshyHey All,
I have a Sony 65x900f that I purchased cheap because of a no-power issue.
I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate... -
by AleMontiHi everyone,
I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
After checking the basics I did the following:- I measured all voltages and as expected the only active supply is the 3.5V standby. It
by redbaron1007I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
S9 13.7V
Pwr Ry 0V
AC Det 9.1V
Mgnd 0V GND
The two pins on the transformer for the operation...7 Photos-
09-12-2024, 03:04 PM -
- Loading...
