32" Dynex DXL3210A Won't Power On
  • tieny
    • Feb 2012
    • 478
    Re: 32" Dynex DXL3210A Won't Power On
    I've been trying but still having a really hard time finding one.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Have you checked to see if it goes down the left side, under the plastic of the connector?
      Muh-soggy-knee
      • tieny
        • Feb 2012
        • 478
        Alright I think we're finally getting somewhere! I finally found where the trace leads. It leads to what I think is an smd transistor. It just might be the bad component, but is there a way of testing it?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          First we need to draw out the circuit right there to see what we need to check.
          Both transistors in question have the marking "1Et", which is a BC847A.
          Muh-soggy-knee
          • tieny
            • Feb 2012
            • 478
            So how do we draw out the circuit?
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              We trace the tracks, and draw it out. I use a special circuit-designing program to draw them out on.
              You can try using just a simple paint program, since it will take a while to install more programs...
              On your picture, the transistor that is circled in red, where do the bottom two pins goto? I think one of them will go to ground. The other I think leads to R684.
              Muh-soggy-knee
                Whcih pin that the trace (PSON) is connected to on that transistor (left, middle (top tab), right)
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Top tab. (Collector)
                  its an NPN transistor.
                  Im thinking that is the pull-down transistor for the P_ON signal.
                  Muh-soggy-knee
                  • tieny
                    • Feb 2012
                    • 478
                    Heres what i traced using the continutity function.
                    I forgot one line, but the two SMD capacitors seem to be in parallel.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      So, if im right, this yellow trace should goto a power source? (probably 5vsb)
                      Muh-soggy-knee
                      • tieny
                        • Feb 2012
                        • 478
                        Yep it leads back to the pin labeled 5VT, back on the connectors.
                          Then you should check the voltage between the Emitter (right pin) and Base (left pin) to see if it has about 0.6~07Vdc, if not, that means the processor is not sending the signal to the base to keep this transistor on (this will cause the PSON to stay lo) when the TV is not on.
                          • tieny
                            • Feb 2012
                            • 478
                            Component V604, With red probe on the emitter and black probe on the base, I get a reading of 0.035V. So does this means that the transistor is bad and is the cause?
                            VS02, I did the same measurement and got 0.683V so just comparing the differences.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Do you think the other transistor pulls it high then?
                              Im kinda thinking the other transistor has to do with this one too. Like maybe they are hooked up as a buffer? (Two inverters)
                              Muh-soggy-knee
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                I'm thinking this is where the signal from some control chip comes from!
                                Muh-soggy-knee
                                • tieny
                                  • Feb 2012
                                  • 478
                                  Heres what i found going through the trace
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    You've made a mistake, it doesn't go to the resistor, it goes right under the chip in the corner.
                                    EDIT: oh, you switched from one track to the other, and back again, I see now.
                                    Strange that it connects to the crystal, unless it is supposed to be powered on when the tv is turned on.
                                    Measure the voltage from ground to each end of RS34 back near the two transistors.
                                    Muh-soggy-knee
                                      The soldered joint near the crystal is to reduce EMI by connecting the case of the crystal to ground creating an RF shield around the crystal.
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Im not sure about it though. The white overlay makes it hard to see the traces around there.
                                        It is possible that when the TV is turned on, the PS_ON goes high, and it starts up the crystal oscillator.
                                        Muh-soggy-knee
                                        • tieny
                                          • Feb 2012
                                          • 478
                                          What is the function of crystals?
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
