Sanyo DP26746 LCD TV-sound,no picture,lamps are on.
  • walking
    • 28
    • usa
    Re: Sanyo DP26746 LCD TV-sound,no picture,lamps are on.
    Originally posted by retiredcaps
    Take this diode and retest it out of circuit.
    Tests good with dmm and with load.
    • retiredcaps
      • Apr 2010
      • 9271
      What are the readings?
      --- begin sig file ---
      --- end sig file ---
      • walking
        • 28
        • usa
        .335
        L
        I put a new one in its place. One from NTE. 89 cents only.
        There are several smd diodes on the foil side of this board at and near the ICs tested. All but one test L and .5XX-.6XX. One tests .524 & 1.89 (D1692 red arrow picture). On the component side of the board there are more and they all test out .5xx & L.
        http://www.datasheetarchive.com/1SS3...datasheet.html
        I guess I should pull that smd and check it off board? Looking this weekend for some junk board to practice on removing and soldering smds. Looks kinda ez on youtube.
        I read these can be tested on board but I can't find anything about if there is a short will it cause the later smd diode to give that kind of a reading, as in current going around it?, or if that diode is the bad shorted component. I'm guessing/hoping the later.
        • RON_CET
          • 217
          looking at front panel screen is it just "white" background with no video when turn on?
          Ron Driver,BSEE,CET,ISCET,NESDA
          • retiredcaps
            • Apr 2010
            • 9271
            I never seen a multimeter just display "L" for out of range. The most common is "0L" and if you have a radioshack model, it might be "0F". Getting these things correct is important because we cannot see what you are reading.
            D1692 is good. Depending on your multimeter, some of them don't display "0L" until the voltage is > 2V or 3V. 1.89 is "close enough" to 0L.
            • walking
              • 28
              • usa
              #26
              Opps, sorry.
              It displays 'l' , I just assumed it was an 'L' and didn't want 'l' to be mistaken for '1'.
              If D1692 is good then I'm back at square one with the possibly shorted @ shottky diode
              • sattech200
                • Aug 2012
                • 59
                I have been searching for this service manual. Any chance you could send it to me? It would be extremely helpful right now.
                Thank you
                [COLOR="Blue"]D1691 - Out of circuit.
                Oh, and someone sent me a Service Manual for this unit I just don't know if I can upload it here and not get in trouble.
                thanks.
                • hipmusicman
                  • Oct 2013
                  • us
                  #28
                  i have the same issue with this same exact tv. i dont have any idea what the voltages are suppose to be from the power board. any ideas. i pulled those 2 820uF capacitors because mine were also a little bulged and they are about 50uF - 100uF too low. not sure if that's a big deal though. also i have checked all of the diodes and they seem to be ok.
                  • Keshetisrael
                    Tech-N-Training
                    • 72
                    So everyone knows, I found the manual : Sanyo_DP26746
                    I have half of my screen looks white with horizontal lines and the other is completely dark black. I'm going to be working on it today. -M.C.
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
                    • netgearnetgear
                      TCL 43S423 TCON OR PANEL FAULTY???
                      by netgearnetgear
                      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                      08-20-2025, 06:04 PM
