Re: Service manuals available free
thanks for your help but sadly as above
everthing about the tv except what you need,
ie: no cct diagram or even board layout ,
makes me wonder if the manufacturers are trying to encourage throw away and buy newComment
No, manafacturers replace boards under warranty, there's no need to provide schematics for their engineers.Comment
sign of the times ,replacement board is fine under 12 months gtee ,but what happens then ?.
i will have to accept that my skills, fault finding down to component level ,
from the last 45 years are now redundantComment
Looking for Service Manual
LG 84UB980T 84" 4K LED TV .
Any help will be greatly appreciated.Comment
Any service manual for UN55H6350? I believe any screen size will work.Comment
Ok, guess I forgot to google it, I do hope u will forgive me.
Newb here! I downloaded a service manual (42RV503U), but it requires Zeus software to view. It looks like Zeus requires an older version of IE (like 6.0). I'm running Windows 10 on a 64-bit system, and IE6 won't install. Is there some type of workaround to getting this to work on a modern PC?Comment
Are you sure about that model number?Newb here! I downloaded a service manual (42RV503U), but it requires Zeus software to view. It looks like Zeus requires an older version of IE (like 6.0). I'm running Windows 10 on a 64-bit system, and IE6 won't install. Is there some type of workaround to getting this to work on a modern PC?Comment
Hi bro,… Ian looking for schematics for my LG 42PW451, I found training pdfs, but there are no schematics for power delivery (zsus and ysus). I think two diodes are bad,.. it I can’t read the part number. Maybe 8310, 8G10, 3610 or 3G10??? The EBR number ist: EBR68342001 / EAX62081002.
Can u help me Someone or has a board?
Best regards from HHAttached Filesif you find these attachements useful please consider making a small donation to the site
thx man,.. me too,.. but cant find a component
@EazyBone & @ThommyX
can anybody tell me, how i can adjust voltages from all boards of a LG 42pw451 Plasma ??
I have a bad picture with red snow,...
if i set the VS (201V) set to 220V, the snow disappear“s, but this cant be rightLast edited by chuckjuggernaut; 11-14-2023, 02:50 AM.Comment
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RRice25541So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
the color is all outa wack, like the settings have been corupted,
I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
so
The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
when i bring up the menu and type the pass codes to access either mode the menu disappears... -
by Med-TechHallo, anybody know where to get service manuals for Medical devices (other than Franks hospital)? The problem I have is with a physiotherapy machine it shows nothing on the display and the green LED flickers.[
Thanks in advance.... -
by AustinCERHello, I currently have a Dell XPS 8940 in our office for repair.
Service Tag: HG1Y673
The most recent BIOS is pictured below -- being available as an .exe on Dell website.
Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...4 Photos-
by YanlebIn the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
For an example, look at the attached PDF.
Do you have a way to cross reference the Panasonic part number with the actual part number?
Thanks....07-03-2023, 08:16 PM - Loading...
