Service manuals available free
+ More Options
Posts
  • ginopilotino
    • Sep 2014
    • 9
    • italy
    #121
    Re: Service manuals available free
    Need service manual for 42w706b, please.
    • linksys1127
      • Sep 2016
      • 121
      Trying to find a service manual for a Pioneer RPTV one of the Elite series model # PRO-118. I know this is ancient but my in laws just love this set and have asked me to help repair it. Thank you
      • happyhour
        • Aug 2017
        • canada
        #123
        Hi
        Looking for service manual for Olevia 747i. Thanks
        • Gunther76
          • Dec 2017
          • Belgium
          #124
          Can someone help met with the following problem:
          Looking for a service manual/schematic for a samsung UE40F7000 with the following boards : power board BN44-0632B mainboard BN94-06860D
          When i press the power button the relais clicks between every click the red led lit 5 times, when i disconnect the minboard from the power board the background light lights up.
          This site is so great !!!
          • R_J
            • Jun 2012
            • 9535
            You can download the manual from elektrotanya.com but I don't think it will be much help
            • Gunther76
              • Dec 2017
              • Belgium
              #126
              Hello RJ, thank you for your quick reply, indeed i also find this but could not find a problem. Do you know what the "BLU ON" means, i only have a few mV on this pin but i have no idea what this should be or what this pin does?
              • R_J
                • Jun 2012
                • 9535
                I'm not sure, it could be backlight on, Page 37 of the manual says:
                How to distinguish if the problem is caused by Main Board or T CON
                -- No Video
                If the problem is No Video but BLU is on and Indication LED is blinking repeatedly and faster than nomal booting,
                replace the T-CON board.
                So that seems to point to a main board fault, maybe trace that line back on the main board, It could be a faulty transistor or maybe its not getting the turn on signal from the micro for whatever reason.
                • Gunther76
                  • Dec 2017
                  • Belgium
                  #128
                  when i disconnect the mainboard from the power board the backlight lit up.
                  the 3 blue leds on the T-con board light up steady (no blinking), is this a good sign?
                  i have no idea what "BLU" is ON means, i measure notthing on that pin on the power board(just a few mV). Should there be a higher voltage on this pin comming from the mainboard to start the tv?
                  • R_J
                    • Jun 2012
                    • 9535
                    I don't know, I don't have that model here. maybe its not even used on this model? maybe someone that has worked on this model might know
                    • flosspike
                      • Feb 2018
                      • Wales
                      #130
                      I wondered if there was somebody with service manuals. The original link provides a page with a forbidden message. I'm after a LG LE79 service manual. I have the 42" version, that sounds bad!, 42LE7900. I believe I have an main board issue, PS board seems to chuck out roughly what it should but there are 4 little bucks 1072 smt IC's. 3 work ok and have 0.8v on they're feedback pin, the last one is dead, no enable, no feedback, no output. A service manual would be very useful, obviously, I'm working with other LG manuals I've found. At least I have a schematic (typical) surrounding the bucks I've found but not that specific I can progress quicker.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #131
                        Hi if you post in the tv repair forum and include some good clear pictures of the boards used in your tv I'm sure we can help you fault find, i have had a search and cant locate a service manual for this set once we know the psu and mainboard numbers I'm sure we can help you more.
                        • BlazeClaw
                          • May 2018
                          Would anybody have a service manual for a Westinghouse WD40FL2480?
                          • dragonsbb16
                            • Nov 2018
                            • 37
                            Anyone happen to have service manual for a Vizio D58u-D3?
                            Mainly the LED strips and LED diode type.
                            • JohnNovak
                              • Nov 2018
                              • 72
                              • Slovenia
                              #134
                              Hi.
                              Why link is not active?
                              403 Forbidden
                              Request forbidden by administrative rules.
                              • burnvictim
                                • Jan 2014
                                looking for service manual for Vizio E55u-D2
                                • Cardioman
                                  • Aug 2020
                                  • 12
                                  Looking for a Toshiba 49L621U service manual, or power supply schematic for a led set that uses Power supply/LED driver PK101W1230I. Would purchase if required! Thanks!
                                  • thoma
                                    • Sep 2012
                                    • 268
                                    https://www.electronica-pt.com/esque...-tv/orderby,4/
                                    • thoma
                                      • Sep 2012
                                      • 268
                                      http://www.toshiba-om.net/tv_manuals.php
                                      TOSHIBA
                                      • thoma
                                        • Sep 2012
                                        • 268
                                        http://www.toshiba-om.net/index.php
                                        TOSHIBA
                                        • jimbofz
                                          • Apr 2013
                                          • 539
                                          • uk
                                          #140
                                          Hi can anyone help with main board circuit for Panasonic TX L24 X5B
                                          chassis t121
                                          board number 715g 5317 mof 000 004b
                                          or any cct using similar board many thanks
                                            LCD LED TV Service Menu Codes
                                            TCL LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            10-31-2024, 03:58 AM
                                          • RRice25541
                                            Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                                            by RRice25541
                                            So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                                            the color is all outa wack, like the settings have been corupted,
                                            I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                                            so
                                            The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                                            when i bring up the menu and type the pass codes to access either mode the menu disappears...
                                            05-13-2022, 10:44 PM
                                          • Med-Tech
                                            Medical Devices Service Manuals
                                            by Med-Tech
                                            Hallo, anybody know where to get service manuals for Medical devices (other than Franks hospital)? The problem I have is with a physiotherapy machine it shows nothing on the display and the green LED flickers.[
                                            Thanks in advance....
                                            05-24-2025, 05:43 AM
                                          • AustinCER
                                            Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                                            by AustinCER
                                            Hello, I currently have a Dell XPS 8940 in our office for repair.
                                            Service Tag: HG1Y673
                                            The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                                            Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                                            Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                                            Yesterday, 05:28 PM
                                          • Yanleb
                                            Panasonic part number in service manuals
                                            by Yanleb
                                            In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                            This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                            For an example, look at the attached PDF.
                                            Do you have a way to cross reference the Panasonic part number with the actual part number?
                                            Thanks....
                                            07-03-2023, 08:16 PM
