Dell XPS 8940 | Manufacturing Mode? | No Service Tag
  • AustinCER
    • Apr 2025
    • 65
    Hello, I currently have a Dell XPS 8940 in our office for repair.
    Service Tag: HG1Y673
    The most recent BIOS is pictured below -- being available as an .exe on Dell website.
    Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
    Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message, as well as the Service Tag is not programmed. Due to not knowing the proper steps of implementing the Service Tag, I want to go ahead and wipe the BIOS and start over.
    Would anyone be able to steer me in the correct direction or supply me with a clean BIOS .bin file.
    I have searched the forums and came across this thread and was wondering if this .bin file is correct
    (https://www.badcaps.net/forum/troubl...ce=chatgpt.com)
    I will attach the .bin file that is mentioned from the thread above.
    Appreciate all and anyone who is able to help. Would like to get the Service Tag to stick so the customer does not have to deal with this menu every time the Desktop is powered on.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12710
    Here
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
    Subscribe to support us. It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • AustinCER
      • Apr 2025
      • 65
      Originally posted by hoaca388
      Here
      Appreciate your response! Will flash this BIOS and let you know the outcome!
      • AustinCER
        • Apr 2025
        • 65
        Here
        BIOS was re-flashed, not successful. Attached is a video of the status of the desktop -- fans spin at full speed upon power up, no display. I can try to re-flash chip again, but so far not good.
        • AustinCER
          • Apr 2025
          • 65
          Would attempting to flash the BIOS on the original motherboards BIOS chip work? The original motherboard BIOS chip is a winbond, while the new motherboard BIOS chip is not.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12710
            Flash chips in VSCC table:
            Winbond W25Q256
            Macronix MX25L256
            ​GigaDevice GD25x256C
            ​Micron N25Q256
            ​Macronix MX25L256
            • AustinCER
              • Apr 2025
              • 65
              Winbond W25Q256
              Macronix MX25L256
              ​Micron N25Q256
              ​Macronix MX25L256
              Appreciate it, will have to double check the original chip and then give it a try. The .bin file you provided has everything needed for the flash correct (like regions, etc?) I just need to execute the flash correctly. We use the CH314 and Neo/AsProgrammer.
              • AustinCER
                • Apr 2025
                • 65
                Winbond W25Q256
                Macronix MX25L256
                Micron N25Q256
                ​Macronix MX25L256
                Thank you so much! We flashed the original Winbond from the dead motherboard and successfully revived the PC. We were then able to stick the Service Tag and exit Manufacturing mode. We appreciate your knowledge! Attached is a video.
                • JoshCER
                  • Jul 2025
                  • 25
                  Winbond W25Q256
                  Macronix MX25L256
                  Micron N25Q256
                  ​Macronix MX25L256
                  Really appreciate your help and the great info, my friend!
                  • therookie1
                    • Jan 2023
                    Here
                    Thank you! This bios works great.
                    • dazras
                      • Aug 2026
                      Hello, I am having the same problem with my XPS 8940. Goes to manuf mode, won't remember service tag number put in BIOS. I replaced mobo after power surge with eBay purchased board. I don't fully understand how you fixed the issue... could someone please walk me through it? Thanks, greatly appreciated!
                      • AustinCER
                        • Apr 2025
                        • 65
                        if i recall, we had just flashed the BIOS with the provided bin file and after that the service tag was able to stick and exit manufacturer mode
                        • dazras
                          • Aug 2026
                          Thanks for the quick reply, AustinCER. Is the .bin part of the .exe I can download from the Dell support site? Is it just flashing the BIOS with an older version? I didn't see a .bin file in this thread. Thanks again for the help
                          • AustinCER
                            • Apr 2025
                            • 65
                            Download the .rar file from hoaca above, has the .bin file.
                            • dazras
                              • Aug 2026
                              Got the .bin. Now I need a BIOS programming tool and heat gun to remove the BIOS chip and program it? Or is there another way? Do I need anything from the old motherboard? Sorry, I haven't done this before... I appreciate the help!
                              • AustinCER
                                • Apr 2025
                                • 65
                                Correct, I use the CH341a programmer tool, which you can purchase on Amazon/Ebay. Depending on which type of BIOS chip it is depends on how you use the tool. Good practice to read the BIOS on the dead motherboard for backup dump in case of anything. Theres been a good amount of winbond BIOS chips that are just 8 pin and I use the Pogo tool.
                                • Boardview and Schematic Bot
                                  LCD LED TV Service Menu Codes
                                  TCL LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  10-31-2024, 03:58 AM
                                • dell_sadness
                                  Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                                  by dell_sadness
                                  BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                                  Have extracted the BIN and want to know how to rebuild a clean BIOS
                                  I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                                  I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                                  Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                                  11-12-2025, 02:54 PM
                                  DELL XPS 8940 XPS i9-10900K Specification for Upgrade or Repair
                                  This specification for the DELL XPS 8940 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPS 8940 boardview and XPS 8940 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 8940 is accurate,...
                                  09-12-2024, 03:36 PM
                                  DELL XPS 8940 XPS i7-10700 Specification for Upgrade or Repair
                                  09-12-2024, 03:28 PM
