Diagnosis of Luxor 32" LCD
  • cakeyb
    • Jun 2012
    • Scotland
    I have a 32" Luxor tv bought from ASDA (walmart) that has developed a fault.
    There is sound but no picture displayed.
    Upon switching the tv on you can faintly see a display like black images for a few seconds but then the tv screen goes black.
    I have replaced the inverter already but the problem persists.
    The tv was left on for a while and does come to life occasionally but goes off at random and can come back.
    I am looking for advice on diagnosing the problem further.
    I have checked the power board and there is no obvious signs of damage to capacitors or burnt out components, the av board is like wise.
    The LVDS (t-con) board has a blue light that comes on when the tv is turned on, but goes off after a few seconds.
    This was the next component i was considering replacing.
    The inverter that was replaced is an LG as is the LVDS pcb. I have found one fairly cheaply, so would consider giving it a shot.
    Just wondering if this is a viable option as next port of call.
    Thanks in advance.
  • JHOFFMAN
    Professional
    • Dec 2011
    • 9
    Re: Diagnosis of Luxor 32" LCD
    Do you have 24 volts going to the inverter?
    • cakeyb
      • Jun 2012
      • Scotland
      Need to try and pick up a cheap multimeter to test further i guess.
      Will try and get one at the weekend.
      And can take some pictures and upload them.
      • cakeyb
        • Jun 2012
        • Scotland
        Havent been able to get out to get a multimeter yet.
        Any indication from the description of the problem as to what could be causing this?
        Does it seem like a power issue? Not enough power getting to components?
        As I dont have any knowledge of repairing tv's, was just looking for some basic help and guidance on replacing components.
        I have experience in computer/laptop repair so dont have issues changing boards etc.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Hi - it could be lots of things without a meter and pictures it is pretty impossible to guess. It could be power supply or it could just be a cold solder joint symptom comes on warms up expands joint goes off cools down joint reconnects comes on.
          You need to be more specific in what you are telling us
          You say
          But
          What does that mean? Sound and full bright picture and how long for?
          When it goes off how far off.
          What does the power light do from plugging in - pressing power on- to
          the initial fault stage .When in fault status can you switch it off?
          • cakeyb
            • Jun 2012
            • Scotland
            TV turns on fine. Displays faint image then screen goes black.
            On occasion it will display a normal picture. It can last for 30 seconds or a few minutes then go off again.
            When the picture goes off the screen is completely black no display at all but still get sound.
            When plugged in power light comes on, and can switch the TV on, once on you get a blue glow from the LVDS or T-con board at the back, and a faint image on screen for a few seconds then it will go completely black.
            Will try and take some pictures tonight and post them up.
            • orfeous
              • Jun 2012
              • 17
              • Sverige
              Just got a question from a friend that have an old Luxor 42" LCD that he bought lile ~2003 or something..he told me that it was really expensive that days. Like ~3000 euro
              The symptom that he described is that he must turn on and off on and off on and off etc several times.. then the TV turns on and runs fine. I havent seen the tv and symptom in real life. It was what he told me. Any suggestion on that? He told me that it can be wurth of investigate because it doesnt feel good to throw away that old expensive tv
              Capacitor problem? powersupply problem? bad solders? im just guessing.
              Going to look at further in time
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Sounds likely perhaps start a new thread with pictures.
                First thing to try would be to take the back off and warm it up gently with a hair dryer and see if it comes on quicker. - Warmer caps work better unless they are completely dried out. Start with the Power supply board.
                Hopefully you will have caught it before further damage is caused.
                • eccerr0r
                  inverter H tree driver imbalance in an AC inverter
                  by eccerr0r
                  My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                  11-16-2025, 12:34 PM
                • x_orange90_x
                  Vizio E55-E1 bad backlights or bad inverter?
                  by x_orange90_x
                  I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                  I don't know how exactly to test the inverter itself. Is it...
                  01-29-2025, 09:24 PM
                • NolesFan
                  Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                  by NolesFan
                  Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                  10-24-2024, 06:36 PM
                • Gentian
                  APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                  by Gentian
                  I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                  It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                  03-06-2023, 07:07 AM
                • valvashon
                  Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                  by valvashon
                  For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                  History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                  01-04-2024, 01:44 PM
