Akai PDP42Z5TA 42" Plasma TV, input text keep flash
  • Sevenqi
    • Jul 2011
    • 292
    Akai PDP42Z5TA 42" Plasma TV, the input text screen keep flash (about 3-5 times a second), but the picture and sound is good.
    When I press menu or volumn button, it popup, but is interrupted by the input screen and disappear when the input flash cycle com back.
    I tried to plug out the manaul control board and used remote control to power up, the same problem.
    Any one has idea on how to fix it ?
    Re: Akai PDP42Z5TA 42" Plasma TV, input text keep flash
    Check the buttons on the side or bottom panel on the TV aren't stuck, use some contact cleaner and spray it in there to clean them.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      He said he tried unplugging the button board and it had no effect, so it must be something else. Could be a weird motherboard glitch, maybe bad caps?
      I assume there is an input switch on the button board. I would try and trace that to the pin it connects to, then with the board removed (since you say it's still doing it), see if the voltage on that pin fluctuates according to the text flashes. If so, it's a potential simple fix, if not, you'll have to dig deeper.
      A working TV? How boring!
      • Sevenqi
        • Jul 2011
        • 292
        I unplug the buttons board (on the riht side of the front panel), and only use the remote control to power up, the same problem.
        • JimmysTGP
          • May 2012
          • 45
          • US
          Doesnt seem like much is really wrong with the set just seems like it might need an firmware upgrade. You would need to find out if this could be one the (list of problems) to a fix on an upgrade.
          • electronicsurplus
            • Jun 2012
            • 210
            Anyone know where to find firmware update for this television?
            This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
            Help keep these from the landfills
            • RON_CET
              • Jun 2012
              • 217
              I think this model was built by LG,but to find the correct firmware version might be a challenge and may come closer just changing main board
              Ron Driver,BSEE,CET,ISCET,NESDA
              • Sevenqi
                • Jul 2011
                • 292
                Main Board is expensive, it's not worth replacing it.
                If can't figure out what's the root cause, I'll send it to recycle yard.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I know this is probably really late. The set in question is likely recycled by now. I had the same set with the same issue. In my case, it turned out to be a cracked plug on the LVDS cable at the main board. Three of the wires were making contact with each other. This set has LG internals. The cable from an LG with the same PDP42X3 panel fixed the problem. Weird, I know.
                  • ekozeko333
                    by ekozeko333
                    🧠 What I’ve Done So Far
                    Flashed...
                    06-21-2025, 02:48 AM
                  • corrize
                    Nikon D800 camera - flash don’t work and capacitor don’t charge
                    by corrize
                    Hello, I'm stuck in troubleshooting…
                    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                    10-01-2022, 10:02 AM
                  • spmetroil
                    Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                    by spmetroil
                    I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                    The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                    I have a CH341A programmer and I already attempted the following steps:
                    1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                    2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                    3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                    08-19-2025, 09:23 AM
                  • abajor
                    Canon VIXIA HF S10 A read data from inernal flash memory.
                    by abajor
                    Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                    Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                    The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                    I think my best shot is to figure out a way to read the internal flash memory outside...
                    07-20-2024, 12:04 AM
                  • Ihandyrepair
                    4 red flash led 65X950G boot Sony and android logo but then black
                    by Ihandyrepair
                    HI guys
                    I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                    here is the issue
                    I have Sony and android logo. but then 4 led red flash lights front of the tv
                    I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                    but then I get black screen and 4 red flash light at the front LED
                    but I get 3 led flash on the LED driver board.
                    I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                    so I tried...
                    07-11-2024, 01:45 AM
