Emerson LC401EM2F
+ More Options
Posts
  • selldoor
    Slow Learner
    • 7870
    Re: Emerson LC401EM2F
    Originally posted by BFraley
    I dont have a schematic for the tv and i dont have any software to open any of the adobe files or pdf files on my computer. .
    Well there is one in the post above first download a reader
    http://www.adobe.com/products/reader.html
    Do not post in more than one thread - I suggest you go in the other one
    and edit it to say posted in error. - you cant delete it altogether.
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc. Please say also what tests you have carried out
    assuming you have read both the therads you have posted in.
    • BFraley
      • Feb 2013
      • 4
      Those are the pictures of the different boards
      • BFraley
        • Feb 2013
        • 4
        I took out a few diodes (D606, D1401, D1603, D1215) because of the weird readings they were giving me actualy connected in the board and all of them are good.
        • wrd0225
          • Apr 2014
          • 9
          How do I get the back off of the Emerson LC401EM2F? How many and which screws do I remove? I need to repair where the antenna connects.
          • wrd0225
            • Apr 2014
            • 9
            I worked on computers, and now my TV went out because a storm knocked my antenna down and pulled the cable sideways and damaged the connector on the back of the set. How do I get the back off of the Emerson LC401EM2F? How many and which screws do I remove? I need to repair where the antenna connects?
            • Alain Renteria
              LG OLED77G2PUA Not Powering On After Storm
              by Alain Renteria
              Got it for free on marketplace because it stopped working after a storm.
              When I began troubleshooting the power supply, I fried 2 fuses and a mosfet by shorting 2 pins on accident, but I've replaced those components.
              The tv had a soundbar connected, which was also killed by the storm. On the tv side I found a transistor shorted on the hdmi 2 (arc) and a lot of capacitors shorted on the main board.
              Disconnecting and reconnecting the psu to main board cable, while still being connected to 120 V AC, would wake things up, such as a red light from the optical...
              11-25-2024, 11:11 PM
            • bobbintb
              TCL Roku 55S403TCAA dead after storm
              by bobbintb
              I have a TCL Roku 55S403TCAA. It quit working after a storm. Other electronics quit working as well so I am pretty sure the storm had something to do with it. Anyway, I took a look at it, no obvious damage, blown components, scorch marks, etc. I am looking at the power board first, 40-L141H4-PWG1CG. I've repaired bad caps and blown components but nothing more extensive beyond that. I am trying to troubleshoot it, but I can't even find the fuse on this board. There are markings on the PCB saying "replace fuse as marking" however. I attached a photo of the board. I am also testing the...
              11-19-2023, 05:02 PM
            • Mustafa85
              Emerson PSU schematic
              by Mustafa85
              Hi guys,
              Any one has Emerson industrial PSU schematic, it has 3 electronics cards in one package please have a look at pics
              03-16-2024, 06:46 AM
            • DXseekerMO
              Emerson LF501EM5F, turns on, logo appears, shuts off, the perfect storm?
              by DXseekerMO
              Earlier this week I got an Emerson LF501EM5F that turns on, the logo comes up, a menu and the channel box come on and it immediately shuts down a split second later.
              This was bought new and went in a Laundromat. From there it was on from 7AM to 10PM every day.
              So why is this the perfect storm? A month ago I got an Emerson LF501EM4 and an EM4A, both will not turn on. The EM4A was struck by lightning and has a serial of DS1 The EM5F has a serial of DS5. The EM4 has a DS4 serial and the chirping transformer problem with a replaced power supply.
              The info...
              04-07-2018, 10:54 AM
            • littlejohn
              Emerson clock radio transformer
              by littlejohn
              Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
              08-30-2023, 07:13 PM
