42lg3000-za No Picture but got sound
  • Jahson
    • May 2012
    • 245
    Re: 42lg3000-za No Picture but got sound
    master
    test1=0.00
    test2=0.00
    test3=0.00
    test4=0.00
    slave
    test5=0.00
    test6=0.00
    test7=0.00
    test8=0.00
    And the same results with probes in reverse order.
    Have not got to take the cover of t-con as yet, seems a bit tricky. will do tho
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #82
      can you post a pic of the t con and cover we may have some ideas on how they come off.
      was the readings taken with the meter set on 20kohms?
      • Jahson
        • May 2012
        • 245
        ok got the cover of, cable a bit more harder
        • Jahson
          • May 2012
          • 245
          yea meter was on 20k ohm
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            #85
            Can you see the fuse on the tcon - small white 3A
            Think you have tested transformers incorrectly
            Put on 2000ohms (Not 20k) and put one probe on pin12 then the other probe onto each of the other 3 pins on that end in turn
            • Jahson
              • May 2012
              • 245
              meter set to 2k
              Master
              Transformer T1
              test 1 = .000
              test 2 = .000
              test3 = .000
              Transformer T2
              test 1 = .000
              test 2 =-1 on left side
              test 3 = 1 on left side
              Slave
              transformer T200
              test 1 = .000
              test 2 = .000
              test 3 = .000
              tranformer T201
              test 1 = .000
              • Jahson
                • May 2012
                • 245
                Yea fuse on T-con checks as ok
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #88
                  i have not tested this type of invertor tranformer myself before i was just going by toms post 65? so not sure but at least you have posted the readings so someone should be able to comfirm for us.
                  • Jahson
                    • May 2012
                    • 245
                    Im really thankful for you guys help, i know its still early, in the diagnostic stages.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #90
                      I was hoping it wasnt.
                      Still dont think we have the correct test for the Transformers. They usually measure 400 -1500 ohms Some of them have one end of the secondary at one end and the other at the opposite end of the transformer. I have looked on line but cant find much on these transformers - but it is good I can read the part numbers in your pics.
                      The likelyhood of all secondaries being sorted or open is like winning the lottery.
                      Is there a problem with pics of the backs of the inverter boards
                      • Jahson
                        • May 2012
                        • 245
                        Theres nothing on the backs of inverters , sorry im not at the same place as the TV now.
                        • Jahson
                          • May 2012
                          • 245
                          Aint given up yet, im not at the same place as the tv, be greatful if someone can get me a close up of (vit71053.54 master) just yesday i had a real close look on mines aint sure but theres an area on my board that just dont seems right. Like someone tried soldering or them lil black rectangle bits missing.
                          I just want compare, my board with a good close up image.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #93
                            Which area are you talking about - give the board part designations - like Qxxx.
                            Not all positions are populated - they are just put on the board at design stage in case of need. Its easy to not use a position but difficult to add one later.
                            We are unlikely to find a picture if you cant - now you see why we ask for good clear pictures?
                            • Jahson
                              • May 2012
                              • 245
                              selldoor you see the pix in post#86
                              If you look in the center of board, it looks like bits of solder all over the gaff.
                              I know whot you saying but this looks kinda unprofessional.
                                Post #6
                                "pin 1 is a blue wire should be 24v
                                pin 2 is grey 24v
                                pin 3 is grey 24v
                                pin 4 is grey 24v
                                pin 5 is grey 24v
                                Then the next 6 to 10 are GND
                                pin 11 =BR1
                                pin 12 =on/off
                                pin 13 =pwd dim
                                pin 14 =error"
                                So do you get 2.9VDC (as indicated in post11) at the pin 12,
                                Pin 14?
                                By the way, what is the P/N of the Inverter controller IC?
                                • Jahson
                                  • May 2012
                                  • 245
                                  Budm
                                  post #11
                                  pin 10 on/off meter reads 2.9
                                  pin 11 pwm dim meter reads 0
                                  pin 12 n.c meter reads 0
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #97
                                    Ones I have looked at are just the same
                                    Here is one example
                                    http://flattvparts.co.uk index.php?main_page=product_info&products_id=7884
                                    - google the board number and you can find others
                                      Please see the redlined test points with reference to the chassis ground.
                                        By the way, do you see this?
                                        http://www.ohmsupplies.co.uk/REPAIR-...T7105354-LG-42
                                          Oops: duplicate
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
