Arion AD-LC 42"F popping noise then powered off
  • tieny
    • Feb 2012
    • 478
    Alright guys so i recently bought this used LCD tv and used it for only about a day. This happened just now, The TV had been on for several hours and I heard a popping sound from the TV and the picture flinched for a second and went back to normal. About 5 seconds later the TV turned off completely and I immediately unplugged the power cable to prevent any futher damage.
    I removed the back panel expecting that maybe it had been just a bad cap on the power board that blew but I do not see any obvious blown caps. So just wondering what else could make that popping sound?
  • selldoor
    Slow Learner
    • 7870
    Re: Arion AD-LC 42"F popping noise then powered off
    Fuse? what is the board model number pictures are too grainy for trouble shooting and need to see the backs- please can you update your profile with country and mains voltage.
    • tieny
      • Feb 2012
      • 478
      I checked one of the fuses, was only able to find one, but it had a reading of 10.4 ohms. Not sure about the fuse type I usually expect an open fuse. I'll upload newer pictures in a bit.
      • tieny
        • Feb 2012
        • 478
        Heres the back of the power supply board
        • tieny
          • Feb 2012
          • 478
          better pictures
          • selldoor
            Slow Learner
            • 7870
            I can only see one fuse on the ps - is it the black sheathed one you have checked?
            Next check the voltage on the big caps HIGH voltage so care and observe polarity
            Red lead on positive leg Black lead on Negative leg - meter on 600VDC.
            Do not touch heat sinks.
            Also found this which might help http://www.ccl-la.com/blog/index.php...-tv/#more-2121
            • tieny
              • Feb 2012
              • 478
              Yes that was the fuse that I checked with 10 ohms. Both capcitors read 163 Volts in standby. Well this is weird, I just turned on the TV now and it seems to be working fine? Not sure how long it would last though I'm guessing the problem would eventually pop up again. Any ideas about this? Hoping I could fix it before it completely dies.
              I might try replacing the caps as shown from the link you gave me. Maybe it might fix it?
              • selldoor
                Slow Learner
                • 7870
                Great - perhaps resolder the big caps pins?
                It does seem a known problem with caps and where they are, they will be well cooked
                so a pre emptive move to replace may save further problems by knock on damage
                in future.
                • tieny
                  • Feb 2012
                  • 478
                  I just made the order for the repair kit. I'm just curious to what couldve made that popping sound and caused the TV to go off.
                  • selldoor
                    Slow Learner
                    • 7870
                    I was not promoting the kit in the link , if thats what you ordered- I didnt even look at it closely as I normally recommend making up your own set. Sometimes the kits use inferior brands of caps without low esr.
                    • tieny
                      • Feb 2012
                      • 478
                      Hmm, well I was able to cancel that order. What do you recommend I replace? I'm looking at Digikey but its kind of confusing to me. Should I replace all the caps on the power board? Should I stay with the same voltages and which caps are best for low esr?
                        Often on a sudden power off of a TV, the speakers will make a click/pop sound - so something on the PSU probably suddenly shut down, too quickly for the rest of the TV to react and mute the speakers.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          See (regulars may skip)
                          https://www.badcaps.net/forum/showpo...4&postcount=19
                          --- begin sig file ---
                          --- end sig file ---
                          • selldoor
                            Slow Learner
                            • 7870
                            @retiredcaps- Thanks for catching that - think I read toms post and missed it.
                            • tieny
                              • Feb 2012
                              • 478
                              Alright heres an update, So far I'm suspect this is an overheating problem. I left off the back panel and was just watching the TV normally as i do. I wanted to see if the problem comes again, but and I was able to actually leave the set on all day without any problems at all (i did this for about 2 days i think.) Then I decided to finally screw on the back panel and leave it as it is and after i think 1-2 hours, the TV once again shuts itself off. I'm able to turn on the TV once again and it is actually still working.
                              Is there some kind of safety mechanism trigger in the circuit which shuts down the TV as it overheats? if so what components cause this?
                              And how would i go about fixing this, i'm guessing installing fans could work but would rather try something else.
                              • tieny
                                • Feb 2012
                                • 478
                                I turned on the TV again to see if it was still working and left it on for awhile, this time the picture got fuzzy, the picture was kinda covered with pinkish noise (i got this similar problem from another monitor where i didn't fully plug in the dvi cable) The sound also become loud and only static was only heard (like turning on the tv without any cables plugged in).
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  The characteristics of many components change with heat. Bad caps can contribute to overheating by affecting other components.
                                  The longer you put off changing the caps the more collateral damage may occur.
                                  • tieny
                                    • Feb 2012
                                    • 478
                                    Alright so I'm thinking about getting these
                                    https://www.badcaps.net/store/produc...roducts_id=150
                                    https://www.badcaps.net/store/produc...roducts_id=114
                                    Is it also recommended that I replace the two largest caps?
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      They would be ok providing the physical size is the same or smaller.
                                      Not sure why you are not using same brand for both but it doesnt matter.
                                      We do not usually say to change the big caps UNLESS you can see any signs of damage,bulging or leaking. They are not undert he same pressure as the smaller caps.
                                      • tieny
                                        • Feb 2012
                                        • 478
                                        Okay Thanks, I wasn't able to find 470 uF capacitors of the brand rubyon, but Samxon was the only brand that had them.
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • tony359
                                          Asus S410U no power: power on sequence on laptops?
                                          by tony359
                                          HI all,
                                          I have an Asus S410U which is dead, no signs of life. The PSU is outputting 19V and it works when under load with an 8OHM resistor.
                                          On the motherboard, I have 19V in getting into the first mosfet and then nothing. I don't see obvious shorts though I haven't checked with thermal camera. I noticed that the rail going to the RAM reads 4 Ohm but that might be normal.
                                          First thing is: how does a laptop generate the "standby voltage"? I'd imagine the 19V is being stepped down into a lower voltage for the standby logic to work. Is there a controller...
                                          07-17-2025, 09:32 AM
