Asus S410U no power: power on sequence on laptops?
  • tony359
    • Oct 2018
    • 259
    • United Kingdom
    HI all,
    I have an Asus S410U which is dead, no signs of life. The PSU is outputting 19V and it works when under load with an 8OHM resistor.
    On the motherboard, I have 19V in getting into the first mosfet and then nothing. I don't see obvious shorts though I haven't checked with thermal camera. I noticed that the rail going to the RAM reads 4 Ohm but that might be normal.
    First thing is: how does a laptop generate the "standby voltage"? I'd imagine the 19V is being stepped down into a lower voltage for the standby logic to work. Is there a controller for that and how is that powered considering that when power is plugged in you only have 19V available?
    The owner of the laptop claims that the laptop made a loud noise when a microphone was plugged into a connected USB audio interface. I didn't see any obvious damage on the board and I'm inclined to think it was just a coincidence - or maybe the speakers popping when power went off.
    Are there schematics for this machine?
    Thanks!
    Tony
  • mon2
    • Dec 2019
    • 14592
    Follow post # 3 here:
    https://www.badcaps.net/forum/troubl...987-asus-s410u
    Is your unit the same? What are the markings on the DCin mosfets?
    Is it QM3056 @ PQ8901?
    Carefully measure the voltage to ground on each of the pins on the DCin mosfets:
    source (1-2-3)
    gate (4)
    drain (5-6-7-8)
    Most likely gate voltage is not ~25V which is required to power on (enable) the N-Channel mosfets used by the BQ charger ICs. Driven by the ACDRV pin on the charger IC.
    • tony359
      • Oct 2018
      • 259
      • United Kingdom
      Thanks, I found the boardview!
      I'll open the laptop and let you know - meanwhile, for my own education, can you tell me how that works? 19V comes in and...? I've got an ATX PC in mind where the PSU is generating 5VSB. But there is no such thing on a laptop so what is the power on sequence?
      Thanks so far!
      • mon2
        • Dec 2019
        • 14592
        Review the sticky above on charger circuits by piernov. It is a must read. Openly, most of the cases here are documented in his in depth articles.
        • m1ch43lzm
          • Mar 2019
          • 659
          • Peru
          Thanks so far!
          Start here: https://www.badcaps.net/forum/troubl...arging-circuit
          The charging circuit either passes the 19V to the main power rail, or when the AC adapter is disconnected, it passes the battery voltage to the main rail
          After you get either the 19v from charger, or the battery voltage at the main power rail (AC_BAT_SYS), you have a DC/DC converter (PU8701, RT8249CGQW) with 3.3V and 5V buck outputs, and auxiliary 3.3V LDO and 5V LDO outputs (the LDOs are always on, the buck outputs are enabled by the EC)
          The 3.3V LDO powers the EC (embedded controller), some also call it SIO(Super I/O) or KBC (keyboard controller): the EC checks for the power button signal to turn on the remaining power rails, it also turns on the 3.3V and 5V buck outputs on standby
          • tony359
            • Oct 2018
            • 259
            • United Kingdom
            thanks - piernov post is amazing. I will study it with the board in front of me and report back πŸ™‚
            Cheers for now.
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
            • conghuyms
              Request for Help – ASUS G531GW Rev 1.6 – No Power On
              by conghuyms
              I need your support with an ASUS G531GW Rev 1.6 laptop.
              When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
              Here’s what I’ve checked so far:
              • Motherboard has been removed for inspection.
              • 3V and 5V always-on rails are present (3V/5V_ALW).
              • 1.8V and 1.09V at the PCH are present.
              • I don’t have the boardview/schematic, so troubleshooting is limited.
              • I tried checking the power button signal from the
              07-20-2025, 09:14 PM
            • Duranitron
              Asus x512dk rev 2.1 power on problem
              by Duranitron
              When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
              Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
              11-26-2024, 10:22 PM
