Panasonic TH-46PZ85U Power Issue
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    Re: Panasonic TH-46PZ85U Power Issue
    Originally posted by diif
    This one ?
    I have a board here from a 42" and it seems the values are different depending if its the MC301 or MC201.
    MC201 is 101 (100ohms) MC301 is 201 (1kohm)
    Nope, the one closest to the chip, by 3rd pin from top.
    maybe its not even a resister? idk
    Thanks tho
    • diif
      • Feb 2014
      • 6978
      • England
      Thanks tho
      It's a tiny black square thing, think it's a small capacitor. It measures 87.52uf.
      • sdinelli
        Sdinelli
        • Aug 2014
        • 152
        hmm.. so anyone else have any ideas? i cant find the schematics just trouble shooting procedures.
        what if i just leave it off?
        • sdinelli
          Sdinelli
          • Aug 2014
          • 152
          took the reading from the resistor in the same spot on mc301. its 4.7kohm
          i compared all the other resistors and they have the same values.
          • sdinelli
            Sdinelli
            • Aug 2014
            • 152
            replaced resistor and put the new chip on. shes working great. got this for free and spent 10$ to fix. love it
            • smartjohn
              • Feb 2013
              • 116
              So for this fix, I have definitely decided that LESS is MORE !! I have a TH-42PZ80u with 10 blinks. Tried the freeze test on MC201 and the set came on perfect! Should have listed to Tom and the others and probably only done the CAP replacement. But, no I tried both replacing the Cap and IC on both boards. Now still seeing the 10 blinks. Pulled them both and did find one resistor was shorted with a solder flake but a re-test got me the same result. No other parts are missing so I am stumped, not sure where to turn.
              Is there any way to test the entire SMPS OUT of SET with jumpers and light bulb loads to simplify the trouble shooting process? Thanks for any help!
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                The resitor that was shorted by accident may of now blown other parts its just finding where now, ive only done 1 of these sets and just replaced the two capacitors (what capacitors did you use) i used normal electrolytic capacitors so had to get the polarity right. Maybe one of your new chips or capacitors are bad? as you removed both boards to replace parts did you put them back in the right position? as i dont think these boards are the same.
                • smartjohn
                  • Feb 2013
                  • 116
                  Hi Vince. These are all good points. At first used the round metal SMD electrolytic caps like norcal715 used in the video, with minus toward the top of the board. I next tried a yellow tantalum like i saw in some of the shots here, thinking I may have a bad new cap. I did mark each board (201/301), I am really a details type guy so this is why i am really frustrated. The 10k resistor that was shorted could have blown that IC.....! I still have one good IC that was pulled and I could try it back on that board...
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #29
                    I used norcals video too and marked both my boards too just in case and yes you have the capacitors on rite minus to top my guess its something on the board you shorted but what? yes change the ic if you have it spare it will rule it out. just be carefull as you keep removing the boards/parts, as the traces can lift off the pcb.
                    • smartjohn
                      • Feb 2013
                      • 116
                      So after further review, I discovered F301 was blown, which means 1 or both of the 16n55g mosfets in the circuit are bad. I assume this happened when I had replaced the MC301 board with the shorted 10K resistor. An eBay seller, best4less303, who offers a repair service for MC201/301, tipped me off to check both F201 & F301. I am assuming that F301 feeds MC301. So off to eBay to buy new mosfets!
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        #31
                        May well need the TEA chip too--if the MOSFETS have shorted.
                        Quite possible for them to have spiked and killed it...
                        TELEFIX
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #32
                          It was nice of the ebay repair shop to give you that information for free a lot of places wont offer free advice/help so good on them.
                          • smartjohn
                            • Feb 2013
                            • 116
                            I absolutely agree! I was very happy that he helped me on the diagnosis. In fact I was looking on eBay for a source that carried the 16n55g mosfets (could not find them at DigiKey) and I found that he sold them at a reasonable price with US shipping. He was not even pushing me to buy his own. If I had found his listing in advance, I may have saved myself all the grief and had him do the chip swap and new caps. His total fee is about $40 US. Unfortunately, he does not do international. Maybe one of you chaps could start something similar on the other side of the pond! Not sure of the volume of demand though :>
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #34
                              His ebay shop prices seem very fair too be honest,i also wish i could find some more panasonics with this fault too fix but not many listed in the uk at the moment.
                              • smartjohn
                                • Feb 2013
                                • 116
                                So just a follow-up to close the loop. The problem was definitely MC201/301. I replaced the 301 section mosfets and was still getting 10 blinks. I decided to take the eBay guy (best4less303) up on his offer to re-do my boards with no guarantee that he could restore them after my attempt. Fortunately, he did an awesome job and had them back to me pronto. I stuck them back in and Bingo! She is up and running like new. Morale of this story, if you don't have the steady hand at soldering you used to 20 years ago, let someone else do it for $34.00 !! Also, he strongly recommends the metal caps. (I had used the orange mylar drops) Many thanks to best4less303 and I highly recommend his services if you need MC201/301 repairs.
                                • Ancient1
                                  I'm stuck . Panasonic TH-L32U20M panel's boards issue
                                  by Ancient1
                                  Hi
                                  The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
                                  Actions :
                                  1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
                                  1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
                                  Obviously the fault is from or on the Right, secondary board
                                  2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
                                  09-03-2023, 03:51 AM
                                • Ama Chur
                                  Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                                  by Ama Chur
                                  After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                                  02-21-2025, 08:12 PM
                                • ag63kry
                                  Panasonic TX-P50U30B power issue
                                  by ag63kry
                                  Hi
                                  Got my Panasonic plasma tv that stopped working suddenly.
                                  Took out the cover all the leads from the powr baord in the middle apart of the main 220AC. and measured Vsus and 15V DC on P2 and P11 connector. Found nothing. Concluded it is the board
                                  Replaced with a second hand one but still the same issue.
                                  Cannot see the 5V or the 15V on the board with or without all the other leads attached.
                                  Here is an example of what I have measured on P6 connector (see the image).
                                  3V DC on pin 6 (STBby 5V and
                                  0,3V DC on pin 7 (F_stdby_on)
                                  No lights on LED,...
                                  05-24-2023, 10:03 AM
                                • BigPete
                                  Panasonic Heatpump Dryer Repair
                                  by BigPete
                                  I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                  The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                  In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                  Unfortunately the whole machine has to come apart to fix it.
                                  I have...
                                  11-01-2025, 06:40 PM
                                • luis71
                                  PANASONIC TX-43HX580E VESTEL 17mb230 Boot Loop issue
                                  by luis71
                                  Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
                                  I have backed up PQ,SPI,and Profile if anyone want
                                  Which usb_auto_update_??.txt can i use to dump firmware?
                                  I would be grateful if anyone could help me to find the firmware for USB recovery.
                                  11-05-2023, 06:31 AM
