As soon as I power the tv on, it shows the Viore logo then it flicks off. The power light stays green.
Viore LED42VF80 automatic turns itself off
Re: Viore LED42VF80 automatic turns itself off
hey i know this thread is almost a year old. I know what's wrong with the tv 's if you look at the power supply where the panel plugs in, the one between 4 two wire plugs and the sound on the upper right. the one in the middle makes the led back panel brighter, if you unplug it you wont no more problem with it but it will be darker i have no bulged caps, if you plug it back in it will start to flicker again,then go out. so i know its either a bad cap but i can't figure out which one. Or the tranformer. I am a repair tech viore.Comment
I have this same LED. What is the actual fix for this! I have the exact problem y'all all have acknowledged! - Mike C.
Text me or email me what you found! seven2seven6923882
urbanpcguruAtGmail.comComment
Very few people will text or email responses. We prefer them to be kept public as much as possible, so others can use them too.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Thanks, that site doesn't have Voire listed as even a manufacturer of T.V.'s.
I tried unplugging that wire and the T.V. wouldn't turn on.
" the one in the middle makes the led back panel brighter, if you unplug it you wont no more problem with it but it will be darker" -scorchedwyndComment
That's part of my signature, and the reason Viore isn't listed on my site is because it is a re-badge name. The actual manufacturer will be some company in China, probably.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I bought the Power board and the main board, and still this TV turns off after awhile. It seems really weird because it will sometimes stay on for a good hour or two.. but eventually it goes off. I have moved it, just lifting it up and down a bit.. and it has gone off sooner.. Anyone have any idea's? They would be appreciated.
-Namaste
I still have this LED 42 inch.. the Guy never came back to get it because I couldn't get it fixed. I bought both the video mainboard and the power board. The TV won't even turn on now. The light is on.. turns green even. But the back light never kicks on. Does anyone know where to see a service manual for this TV? LED42VF80Comment
You are sure that those boards are OK which you have purchased?
I have just worked on a similar 32" one and I was ready to give up and I have just re-soldered the connector joints, transformers, I don't remember which IC but it was in the primary section, 16-20 pin IC?
To my surprise, the TV just turned on.
Did you try flexing the whole TV? I heard people doing this and the TV turns on.
This TV had image if I used a flashlight on the screen.
This TV, had the worst soldering that I have seen in my life. I think that were soldered on the boat by hand, while were shipped here.
I have this same problem but mine turns off and back on then off and back on and continues that cycle.What is the solution?Comment
Dead unit even with a new power supply, We have found that the problem is inside the LED panel, To be more specific the red B+ wire on the led strips is touching the aluminum ground plane on one or more LED strips, To verify without taking the panel apart just disconnect the 4 sockets and measure for a short across the pins, If shorted then the problem is inside the panel.
Reason of failure is the close manufacturing tolerances, The Plexiglas reflector is to big and the corners right on the top of the solder connections are pushing against the red B+ wire on the left and right strips thus creating a short.Comment
The order of the four 2 wire pins in the upper left of the power board makes a difference for start up. If the first two are out of order it will not turn on the display.I still have this LED 42 inch.. the Guy never came back to get it because I couldn't get it fixed. I bought both the video mainboard and the power board. The TV won't even turn on now. The light is on.. turns green even. But the back light never kicks on. Does anyone know where to see a service manual for this TV? LED42VF80Comment
Did you try to repair this or throw it away?Dead unit even with a new power supply, We have found that the problem is inside the LED panel, To be more specific the red B+ wire on the led strips is touching the aluminum ground plane on one or more LED strips, To verify without taking the panel apart just disconnect the 4 sockets and measure for a short across the pins, If shorted then the problem is inside the panel.
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
Hi.
I kindly ask you to help me solve the problem.
Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
The board turns on, there is no image.
Read more. When the power supply is connected, the front panel indicators light up briefly.
When you press the power button, the button indicator lights up. The board works
there is no image, there is no matrix initialization, there is no image on HDMI.
When turned on, the fans do not spin, but when they warm up they start spinning.
When you turn off the button, the fans spin up to full speed for a short... -
by Egidio85good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
This defect happens continuously, hearing the classic click of the relay every time.
Power supply board BN44-00636B
disconnecting the mains and lamps from the power board always causes the same problem.
Is it normal that without anything connected this power supply turns on and off cyclically?
any suggestions on what to check?
thanks in advance
- Loading...
