Olevia 242TFHD-T11 42" TV Start Up Problem
  • broacke
    • Aug 2012
    • 6
    Re: Olevia 242TFHD-T11 42" TV Start Up Problem
    Alright. Thanks for the help! I will be able to work on it some tomorrow!
    • broacke
      • Aug 2012
      • 6
      How do I remove these clips? I don't wanna yank em and mess it up...
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        They are lock/latch style connecters you can pull them off, might have to wiggle. If you still can't get them off, use a small flat head screwdriver and wedge between the latches and then pull again. Also would be easier if you had the screws in on the board.
        • broacke
          • Aug 2012
          • 6
          Got em thanks.
          • broacke
            • Aug 2012
            • 6
            http://www.amazon.com/Repair-Olevia-.../dp/B005PT5FII
            Would I be ok going with this kit??
              Avoid, a rip off and problematic. Simply make a note of each of the caps you have on the board and order Panasonic FC, FM or FR from DigiKey. Total cost, including shipping, will be less than $10 and you can be guaranteed they'll work perfectly. Manufacturers often change boards mid version because of supply or price reasons, so the caps in that kit could be incorrect. Also, no mention of quality - cheap generic caps will die in short order.
              • Mikef12
                • Apr 2012
                • 14
                That's the one on ebay that I also purchased. There was one wire on the new ps harnese that was placed in the wrong pin hole slot on the invertor plug next to the ps. Just match all your wires for the new ps. Mine works great. Color and detail have greatly improved as well. I think my Olevia is a top notch tv and didn't want to give up on it. The back is easy to remove and the ps is simple to change. No soldering required.
                  How do better caps improve picture quality and colour??
                  • Mikef12
                    • Apr 2012
                    • 14
                    It really did. Picture was blocking before until it warmed up and the colors were no way near as bright.
                      I remain skeptical. Bad caps can cause stuff like greyscale video (dropping analog supply), digtal glitches (freezing picture, lines, etc.) Maybe brightness if 24V was low. But improvement of colours?
                      • Mikef12
                        • Apr 2012
                        • 14
                        You've got to remember I had just also replaced the mother board just a week before the new ps and it wasn't just the caps, it was a completely factory fresh new ps.
                        • n3kf99
                          • Sep 2012
                          • 4
                          How difficult is it to get the back cover off of this set? Can it become while standing up or must it be laying down? Thanks. I want to work on mine, but due to a spine issue it would be much easier if I could do it with it on the stand. Thanks.
                          • Mikef12
                            • Apr 2012
                            • 14
                            I laid mine on a towel face down on the dinning room table with my wifes help and a bad back as well. I wouldn't recommend trying it up right.
                            • overlord
                              • Sep 2012
                              • 17
                              I'm fairly certian you will be able to remove the back cover off with the plasma upright, but it would most likely be easier with it lying flat. I'm not familiar with this model but the handful ive come across have just been a decent amount of screws to remove.
                              Can even hang the stand off the edge of the table if you dont want to remove it, while it is lying flat.
                              I'm fairly certian that you can work on it upright (can help if you want to be able to glance over and see if there is any life on the screen, in my case recently)
                              But for removing boards, etc - lying flat is signficantly easier.
                              • robert317
                                • 3
                                Basically have the same model and proble. Changed c-21, 22. Lights on main board light up, blue power light comes on for about 2 seconds then goes out. TV doesn't come on. What next???
                                • donit
                                  • Oct 2013
                                  Hi all, Just replaced the power supply in my set and it works great thanks to this thread. You guys are awesome, and saved me the price of a new TV vs 50 bucks for the power supply.
                                  Thank you all!!!
                                  • BeholdTheBiscuit
                                    • Oct 2013
                                    • 4
                                    I have the same model TV and am experiencing a similar problem. Glad I saw this thread: THANK YOU tom66 for the advice on cap ordering as I was *just about* to place an order for that Amazon kit. I will start a new thread this afternoon so I can post pictures of the power board. I would like to confirm my suspicions that my only problem is bad caps.
                                    See y'all soon!
                                    -Biscuit
                                    • hugocarmo
                                      Panasonic TX-24A1UN CRT Sound and Input problem.
                                      by hugocarmo
                                      Hi.
                                      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                                      It is imaculate inside, almost no dust or debris inside.
                                      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                                      So I started to look for a service manual, I found one, and started from the beginning.
                                      Most of the times the caps are the problem so I orderer all the caps for all boards,...
                                      04-26-2025, 07:45 PM
                                    • computeka
                                      Macbook Air A2337 820-02016-07 No sound problem
                                      by computeka
                                      How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
                                      05-08-2024, 10:26 AM
                                    • Rofix
                                      Problem HP Main Board DAG3DCMBCC0 REV C
                                      by Rofix
                                      Hello everyone I wanted to kindly ask you for advice I have a problem with this HP Main Board DAG3DCMBCC0 REV C motherboard, the PC does not turn on, the power connector works, 19V arrives, on the first three mosfets there are 19V, the main voltages such as 3.3V and 5V are on the various coils, on the power button 3.3V arrives, I checked the power button and it works, but the PC does not turn on, moreover when I connect the power supply to charge the battery it does not charge, no LED lights up at the moment as the voltage is at 14.7V, the nominal voltage written on the battery is 15.4V, I also...
                                      12-19-2024, 02:10 PM
                                    • JohnML1975
                                      Samsung UA50TU8000W no picture and no sound
                                      by JohnML1975
                                      Hello All
                                      have seen posts on this model in here but my problem sounded different so thought i would create a thread
                                      TV will not turn on
                                      There is no standby light
                                      When I press ON button for remote the red standby light does flash but no picture and no sound
                                      From the back of the TV I can see the red light on the back of the mother board
                                      Holding torch to the screen I cannot see a picture
                                      I removed the back cover
                                      Observing the boards I cannot see any damage
                                      I disconnected the main board from the power supply
                                      the back...
                                      08-30-2025, 09:40 PM
                                    • Audeze
                                      Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                      by Audeze
                                      I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                      Does...
                                      10-06-2024, 08:54 PM
