Macbook Air A2337 820-02016-07 No sound problem
  • computeka
    • Apr 2021
    • 31
    • colombia
    How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound.
  • mon2
    • 14713
    Often this fault is from the headphone connector itself. Try blowing out the jack with compressed air to clean it out. If you disconnect the headphones, does the OS report that speakers are active?
    • computeka
      • Apr 2021
      • 31
      • colombia
      In fact, I changed the entire piece since the original one it came with was reaching very high temperatures... I already tried to clean it and I still have no sound from the speakers.
      • computeka
        • Apr 2021
        • 31
        • colombia
        originally this is how the first plate was
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue โ€“ Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck โ€” hoping someone here can shed some light.
          ๐Ÿ›  Original Issue
          The machine initially wouldn't negotiate 20V over USB-C โ€” stuck at 5V.
          โš ๏ธ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • Skrndelj
          Apple Macbook Air M1 A2337 Trackpad problem
          by Skrndelj
          Hello all,
          I am repairing a Macbook A2337 and i have a problem
          The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
          When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
          I inspected the whole board and everything seems fine.
          Can anyone help me as i didn't fiddle with trackpad...
          06-11-2024, 04:26 AM
        • Adogabriel100
          where to get trusted CD3217. Problem with A2337 Macbook Air
          by Adogabriel100
          Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
          The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
          09-06-2024, 12:06 PM
        • brockauly
          Macbook M1 A2337 EMC 3598 weird battery charging problem
          by brockauly
          Hi guys,
          If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
          Then if I unplug the charger and plug it back, it won't charge anymore.
          In the first case, main voltage is regulated at ~12.5V and charges the battery.
          After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
          After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
          I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
          02-05-2025, 10:51 AM
        • saisoni20
          MacBook Air A2337 820-02016-07 No sound ISSUE
          by saisoni20
          I have A2337 MacBook Air no sound issue.
          I have replaced new Audio Board but still same issue. I went through repair wiki and checked critical voltages.
          In terms of voltages, I have following voltages,
          1 PP1V25_AWAKE_IO - 1.2V
          2 PP1V25_AWAKE_IO - 1.8V
          3 SPKRAMP_A_OUTP_R - 0V
          โ€‹4 SPKRAMP_A_OUTN_R - 0V
          Am I missing any other critical voltages?
          07-28-2024, 05:53 PM
