Sanyo DP46840
+ More Options
Posts
    Re: Sanyo DP46840
    I looked at the the way the schematic is drawn, some connections as shown does not make sense at all.
    I will have to look at the PCB trace layouts to see the actual connections.
    As you can see (PAGE 45), IC800 PIN48 (it has 100K resistor to 5VSTBY pull up) will activate the P-FAILED signal when its input goes low, so any one of the Diodes (OR gate setup as shown on page 5) on the Cathode side will be low when the power supply does not work which will cause the Diode to be forward bias (ON, the Cathode side of the Diode will have resistor network to set the trip point, IE R1683 is set to have just enough voltage on it to keep the D1671 in reverse bias) and take pin 48 to be around 0.6Vdc. When all the power supplies are working, those Didoes will be reversed bias (OFF).
    So when the 13VDC output is only 3V or so, that is not enough to keep the Diode off.
    If you remove D1671 then that way the P FAIL will not be fed to the PIN 48 IC800, then the TV should come on but no sound.
    • kevinm34232
      • May 2012
      • 1884
      Re: Sanyo DP46840
      Hmm OK. So removing D1671 would be bypassing P FAIL for that circuit? If that's the case that's great, I will attempt to repair regulator and reconnect those traces on the amp and see what happens first. If not then I'll go that route.
        Re: Sanyo DP46840
        Yes.
        • kevinm34232
          • May 2012
          • 1884
          Re: Sanyo DP46840
          And maybe stupid question but I havent looked for it yet, guessing D1671 is a SMD, just heat it up and pull off the board?
            Re: Sanyo DP46840
            I add more solder to both ends and move your soldering tip back and forth real quick while using a small tweezer to lift the Diode off the board.
            • kevinm34232
              • May 2012
              • 1884
              Re: Sanyo DP46840
              If I remove that diode, and I do that regulator mod, will that affect anything if the mod works? Id like to try to get the audio working if possible.
                Re: Sanyo DP46840
                What we trying to do is to get the TV running without the sound first just to verify for sure that where the shutdown is coming from. Then we can do the mod or replace that bad IC.
                • kevinm34232
                  • May 2012
                  • 1884
                  Re: Sanyo DP46840
                  I tried removing this diode, (it's on the bottom of the board). But I couldn't get it to move, I tried adding more solder, wiggling with tweezers but no luck. Didn't want to break anything. Not sure if it's because both sides need to be heated at same time??
                    Re: Sanyo DP46840
                    It is a very small diode not sure why you are having a hard time removing it, I thought it is on the top side of the board, may be I seeing it incorrectly on the service manual.
                    • selldoor
                      Slow Learner
                      • 7870
                      #70
                      Re: Sanyo DP46840
                      The legs may be bent on the bottom side. If you have any solderwick remove as much solder as possible then you will see why it wont go through the hole. If no solderwick
                      just work one side get a cocktail stick or similar and lever up just a fraction as you melt the solder- keep the leverage on till the solder resets then do the other leg - just a fraction and so on till its out.
                        Re: Sanyo DP46840
                        I thought is it SMD type? I need to check the service manual for sure.
                        • catfish69
                          • Jul 2012
                          • usa
                          #72
                          Re: Sanyo DP46840
                          What would happen if i cut the power input to the ic1670? would that shut down the audio circuit completely and allow the tv to work without sound of course?..
                          • stupidstuff
                            • Sep 2012
                            • 3
                            • new england
                            #73
                            Re: Sanyo DP46840
                            Originally posted by selldoor
                            Ok Got SM Thanks - will see if I can split it up
                            Here are some BIG excerpts for budm.
                            Oh man. Can you get me a full schematic picture of the main board? I need all the capacitor locations and values. I de-soldered my caps to test them and the kittens got at my baggie with the caps and list I made up. I don't know what happened to my list so now I don't know where all the capacitors go back :-(
                            • stupidstuff
                              • Sep 2012
                              • 3
                              • new england
                              #74
                              Re: Sanyo DP46840
                              SM Split into 3 zipped sections - all need to be downloaded before it will work.
                              This is for a DP42840 not a DP46840. Does it matter? Can I use this manual to find capacitor locations and values for DP46840?
                              • lilmonk3
                                • Apr 2012
                                • 259
                                Re: Sanyo DP46840
                                Was this ever fixed? The fellas at the VFW just brought me their dp42840.. Hit power button, can hear cycle on power board and then it shuts down.. No backlights when it does this.. Just green power light and then a few seconds later click and it goes off.. Getting correct readings on PWB before it shuts down..
                                • lilmonk3
                                  • Apr 2012
                                  • 259
                                  Re: Sanyo DP46840
                                  They did say that the screen when Black and white a couple of weeks ago for a brief moment and now its doing this
                                  • lilmonk3
                                    • Apr 2012
                                    • 259
                                    Re: Sanyo DP46840
                                    Kevin??
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      Re: Sanyo DP46840
                                      Mine is "fixed". Audio circuit was bad and rather than replace the main board, with the help of others here and elsewhere, I cut traces going to the audio amp IC and also added a 15v voltage regulator as it appeared the original one was bad too. This keeps the TV from shutting down and I use my external home theater system for sound.. What model TV is yours and what chassis #?
                                      • lilmonk3
                                        • Apr 2012
                                        • 259
                                        Re: Sanyo DP46840
                                        Dp42540 Chass. P42840-01
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          Re: Sanyo DP46840
                                          Mine was chassis 00, did you get service manual??
                                          • cj_reha
                                            Mystery 80s Sanyo cap - perhaps polymer?
                                            by cj_reha
                                            Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                            01-06-2023, 09:24 AM
                                          • Srdjan01
                                            IPhone 12 ProMax - Thoughts of (not so young) apprentice
                                            by Srdjan01
                                            Hi guys.
                                            I'm working on my first board reballing.
                                            It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
                                            Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
                                            I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder...
                                            03-17-2025, 02:49 AM
                                          • toddw65
                                            Sanyo DP5834 - Gray Screen
                                            by toddw65
                                            Hey All,
                                            I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                                            Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                                            Thanks,...
                                            10-31-2024, 10:37 AM
                                          • zomi
                                            Manual cof bonding success rate ?/ feedback wanted
                                            by zomi
                                            Just wanted to get some feedback,
                                            whats peoples' success rate with cof bonding repairs.....
                                            09-23-2024, 12:45 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
